Re: [bolger] 15' Small Workskiff
The proverbial,pic worth a thousand words.
Harry, that's a pretty boat.  How's it worked out for your use ?
These things tend to work themselves out in this forum, denaldel01.
And ‘the Chief’ speaks from his own experience doing work-skiffs out of nearly anything he can lay his hands on...
It looks like he does not always need plans to get on the water.
Thanks all.
Susanne Altenburger, PB&F
P.S.: Design-Column #502 in MAIB is headed for the printers as we speak.
Sent:Monday, July 04, 2016 7:14 PM
Subject:Re: [bolger] 15' Small Workskiff
I'm should have been more specific.  I'm interested in reviews and commentary about Phils design #618 Work Skiff.  Thanks
I built the 15' version but even shorter.  I built it on 10.5in centers rather than 12 to fit a shorter  deck space, came out at 13 something. I built it with a outboard well , something I think is feature in a small outboard powered skiff. Pics attached of under construction, finished and in use,
bolger@yahoogroups.com
To:
<bolger@yahoogroups.com>
Cc:
Sent:
04 Jul 2016 11:20:51 -0700
Subject:
Has anyone built a small Workskiff?  I'm considering it.  Lots of 18' Clamskiffs but I'm having problems finding much info on the 15' X 4' skiff.
I've built a skiff.  Will you sail,row,motor. ? That matters. Building a Flat Iron skiff is more tricky.  Totally flat bottom is seldom needed.  Length effects bottom curve. Net weight and expcted cargo effect design.  A generic design would be pointed bow rise 5 or 6 inches width midship 40 to 48 inches. Transom pinched in about 3 inches each side. Aft rocker 3 or 4 inches.  Sides flair effects bottom rocker.  Need some rocker fore and aft  to sail well.
Flat bottom last 1/3 for motors. I suggest you find a boat similar to what you want.  Take photos measurements and draw up your own boat.  Chief
The Gods gifted me with a dozen cookies. There was 13 in the box.  Chiefredelk
On Jul 4, 2016 13:32, "denandel01@...[bolger]" <bolger@yahoogroups.com> wrote:
