Re: [bolger] AS-38 Stability Diagram
Susanne,
Thank you for your reply. Can you tell me what the Angle of Vanishing Stability is for the AS-38?
Thanks, John
Thanks, John
Phil did Design #576 before routine PC-based assessments were doable.
In his judgement however she does fall within his preferred range of attributes, such as high shoulders per given beam on shallow draft, wooden mast, etc.
Susanne Altenburger, PB&F
Sent:Wednesday, October 19, 2016 9:16 PM
Subject:[bolger] AS-38 Stability Diagram
I'm looking for a stability diagram for an AS-38 (Loose Moose II). Has one
ever been calculated by CAD, or by hand, or by an actual inclination
test?
John
test?
John
I'm looking for a stability diagram for an AS-38 (Loose Moose II). Has one ever been calculated by CAD, or by hand, or by an actual inclination test?
John
John
