Re: Weldwood split from Good Wood
It wasn't when or how they were laminated that was the problem. It
was
afterwards after the varnished-finished masts had been exposed to
the summer sun & heat. In one case, my Zephyr mast delaminated
after it had been left at a repair shop after the trailer axle broke.
The boat and mast sat in the sun on a blacktop parking lot for a week
in the summer and most of the seams let go. The second mast on my
19-foot catboat) was never exposed to quite that extreme, but had the
disconcerting habit of letting go while the boat was under sail,
although fortunately the mast never broke. I don't think it had
anything to do with how the glue was applied -- it was mixed normally
and spead without difficulty -- but rather the heat and humidity it
was exposed to later.
Gary
--- Inbolger@egroups.com, Mark Albanese <marka@o...> wrote:
> Gary,
> Having had good luck with it, I'm really interested in this
> question of Weldwood failure? Do you remember how hot the
> temperature actually was when you laminated your masts, or
> how humid the Florida air? Was the glue too gummy to spread
> well with a paint brush?
> Mark
> "Mary Ann, Gary" wrote:
> > One additonal
> > thought, since like me you live in the hot climes, I would avoid
> > laminating with Weldwood Plastic Resin glue. Maybe I'm using it
> > wrong,
> > but I've had two different varnished masts delaminate with that.
No
> > problems with epoxy or Titebond II.
> > Gary Blankenship
> > Tallahassee, FL
> > --- Inbolger@egroups.com, chris@b... wrote:
> > > Hello Group,
> > > I'm still in the early stages of my restoration project sanding,
> > > patching, and acquiring supplies.
> > > I live in the burbs of Dallas Texas, and can't seem to get my
> > > hands
> > > on "good wood".
> > > Payson calls for the use of Spruce or Fur as Tiny Cat's
> > > 15'4" mast.
> > > My Pop originally used pine and it eventually failed (more like
> > > snapped).
> > > What I'm looking for is 4x4x16 clear tight grained stock.
> > > I have called about and found no spruce, and limited fur.
> > > The fur they had in 4x4 was of very poor quality.
> > > The best candidate is a 6x6x17 fur, seems like an excessive
waste
> > of
> > > good wood?
> > > Any feedback would be greatly appreciated.
> > > -Chris
> > - no cursing
> > - stay on topic
> > - use punctuation
> > - add some content: send "thanks!" and "ditto!" posts off-list.
Gary,
> One additonal
> wrong,
> but I've had two different varnished masts delaminate with that. No
> Gary Blankenship
> Tallahassee, FL
> > Hello Group,
> > hands
> > on "good wood".
> > 15'4" mast.
> > snapped).
> > The best candidate is a 6x6x17 fur, seems like an excessive waste
> of
> > good wood?
> > -Chris
> - no cursing
> - stay on topic
> - use punctuation
