RE: [Bolger] Hobie Cat Mast for Oldshoe - naah, there's better options
See, for just one (of many suppliers)  on-line example:https://www.flagpolesetc.com/flagpoles/aluminum/aluminum-residential-external-halyard-flagpoles
Where a fifteen-footer with eighth-inch wall-thickness is $412, a twenty-footer same specs is $475 – and those prices are delivered, as freight is included.  Not bad.
But not as cheep as a split 2x8, eh? Even including the epoxy to join it together…   aaaah, aluminum or wood, THAT is the question!  (but then isn’t the REST of this almost-Oldshoe all-aluminum?)
Wayne Gilham
From:bolger@yahoogroups.com <bolger@yahoogroups.com>
Sent:Saturday, April 14, 2018 9:53 PM
Subject:RE: [Bolger] Hobbie Cat Mast for Oldshoe
If aluminum is the order of the day, look at tapered “spun” aluminum flagpoles, light poles, etc… that was the perfect replacement when I “folded” the mast on my 20’ Marshall Cape CodCatboat, by snagging its forestay on a passing boat, many years ago.  And since it’s NOT “marine” but from an industry that has lots more production, pricing should be much more reasonable.
Wayne Gilham
Prior owner of a Bolger Black Skimmer
Current owner of Bernie Wolfard -built (first ever!) Bolger Idaho power sharpie
From:bolger@yahoogroups.com<bolger@yahoogroups.com>
Sent:Saturday, April 14, 2018 5:46 PM
Subject:Re: [bolger] Hobbie Cat Mast for Oldshoe
I would steer clear of the Hobie masts. They’re highly aerofoil shaped, designed to rotate at the base, and are designed for a stainless wire halyard with a narrow sheave at the top.
Go for something like a Laser with high quality aluminum.
You could also use a lug, gaff, or Gunter rig with a shorter, stout unstayed mast.
Andy
On Sat, Apr 14, 2018 at 16:58BllFs6@...[bolger] <bolger@yahoogroups.com> wrote:
Hi all,
My "Bolger Olshoe insprired" (the builder only followed the general shape of the hull and the sail sizes and layout) has a eyeball engineered aluminum tube mast. Well, it did not take long to bend it about 20 degrees (and IMO I did not feel like I was pushing any limits at the time). Well, I managed to unbend it fairly well, flipped top for bottom and inserted some steel piping going up a good distance. It is HEAVY now.
Reengineering the mast is gonna be kinda pricey. 20 foot aluminum tubing is not cheap. And I probably need an insert in that that goes up up a good ways and then a 2nd insert in the first insert that goes up a good ways in 1st insert.
Well, I just happened to notice a hobbie cat mast for sale cheep on Craigs list.
Would that work as a mast?
Any thoughts?
take care
Buddy
