Re: steel plate on sharpie bottom
https://groups.yahoo.com/neo/groups/bolger/conversations/messages/62025
https://en.wikipedia.org/wiki/Percy_Wyn-Harris#Retirement_and_death
https://www.boatdesign.net/threads/nautical-miles-on-new-french-svs.35026/#post408562
https://www.boatdesign.net/threads/larger-steel-version-of-paradox.54334/page-2#post-759461
Spurwing
Hereunder a note on Spurwing’s journeyings in 1966 from Sir Percy Wyn Harris and some parts of his personal log of Spurwing’s voyage:http://www.alcyone-archive.org/newsletter-nr-8-february-1967
A pity they are now so rare. None were owner built and increasing yard production costs killed them, apparently.
Maybe the thing to do is build in the style of "Lion's Paw" (BWAOM)..
One could hire a company that builds water tanks to CNC cut/weld sides
and the bottom. Steel sides could come up to the shear line. Build
frames to support the sides during the welding process. I'd likely hire
a pro to do the chine seam with TIG welding gear to get a leak free
seam. Then build up the interior, and deck with wood. A cheap wire
feed welder would secure angle steel tabs to bolt wood pieces in as
needed. Many of the sharpies could be build this way,
From: philbolger@... [bolger] <bolger@yahoogroups.com>
To: bolger <bolger@yahoogroups.com>
Sent: Wed, Jun 6, 2018 2:48 pm
Subject: Re: [bolger] Re: steel plate on sharpie bottom
My Old Shoe (not built by me...) has a full aluminum hull.
From: Don Schultzdaschultz8275@...[bolger] <bolger@yahoogroups.com>
Sent: Mon, Jun 4, 2018 5:22 pm
Subject: [bolger] Re: steel plate on sharpie bottom
I really hadn't considered expansion of a 25' armor/ballast to be a
problem for a plywood boat. Thank you Susan, for the careful
engineering. I had thought to use carriage bolts through oversize
fiberglass clad holes and 5200 to fill the gap. My thought is to build a
Martha Jane without water ballast. So 4' sections could maybe be done
with a gap to allow for size changes.
needed. Many of the sharpies could be build this way, Black
Skimmer/Gauntlet, Martha Jane, AS- x, Old Shoe, etc. Not that an open
boat like Old Shoe should be steel. A simple inconvenient knock down
becomes a total loss.
Don Schultz
From: Don Schultz daschultz8275@... [bolger] <bolger@yahoogroups.com>
Don Schultz
Don Schultz
On Jun 4, 2018, at 18:22, Don Schultzdaschultz8275@...[bolger] <bolger@yahoogroups.com> wrote:
x
Don Schultz
Across such temperature-extremes, you’d likely see the metal hull move differently more than the ply-deck, and thus the bulkhead-connections, the ply-to-steel seam, etc.
As you suggest, 39’ LION’s PAW (in 30-ODD Boats) was indeed built this way, however in Florida to be cruised in Southern climes – meaning no major changes beyond the rare snow-flakes ’down south’.
2. LION’s PAW did have likely ‘problem-areas’ built into her with each steel-to-ply joint, where temperature-related movement and condensation will offer serious hard-to-repair grief, from fasteners moving, water-excluding seam-glob aging, with potentially whole bulkheads and deck-areas affected by wood-rot, with serious marinating of the ply in nasty chemicals possible to keep this way off, except that many of those may eat the steel faster... and at least may never paint well.
x
maybe be done
Maybe the thing
One
and the
frames to
a pro to
seam. Then
feed welder
needed. Many
becomes a total
loss.
Don Schultz
Don Schultz
We’ve limited the total length to manageable 4’ length to see next to no expansion/contraction issues.
We covered this in an MAIB piece on the occasion of an LM-2 build in Quebec that integrated this option into her hull.
Not yet any bad news many years later.
For ice-duty, we’d add separate pieces through the topsides to indeed extend well above the waterline.
From:"a.sobriquet@... [bolger]" <bolger@yahoogroups.com>
Sent:Thursday, May 24, 2018 10:17 PM
Subject:Re: [bolger] steel plate on sharpie bottom
Susanne Altenburger, PB&F
---In bolger@yahoogroups.com, <philbolger@...> wrote :
It was successfully applied during the LM-2 (#576) project in Montreal.
To summarize:
- countersunk holes through steel-plate with through-bolts bedded in 3M 5200 in plate and through slightly oversized holes in the hull-bottom-proper;
- on inside of hull-bottom use of washers and fender-washers for least wood-crushing, all bedded with 3M 5200;
- all pieces pre-curved by the same local metal-shop that supplied you with the steel by following the hull-design in its definition of its bottom-curve;
- galvanizing is one option via a local/regional ‘hot-dip’ galvanizing facility;
- you’d want to round over all corners and edges to reduce risk of cracking of coating;
- or forever if you could afford straight copper...or bronze...assuming its gauge will be adjusted to arrive at the same weight as the steel;
To summarize:
Dreaming is good. ‘Dream-‘ and ‘Paper’-Boats can be therapeutic when life gets too demanding...
Zero-in on your priorities, make that list, revise it endlessly, and eventually you are likely to at least know what you’d want if you could.
Let me know if and when.
Sent:Thursday, May 24, 2018 2:00:32 PM
Subject:Re: [bolger] Phil Bolger died on May 24th 2009
Yes, indeed, a double-jointer like LCU-F.
But since giving her that chronologically-correct Design Number, we had second and third thoughts towards reducing the inherent liabilities of such a radical geometry... under sail !!
So, by mid-2018, the third approach remains ‘on ice’, but aging gracefully, awaiting an opening amidst the must-dos, to finally get her finished with a foot more beam, 4+ bunks, a hard-dinghy in her bow-module, cockpit in her stern-module, and 50/60HP large-prop outboard and all the heavy stuff around that ‘wild’ pivoting wing-keel that should keep the whole mania upright with reasonable plausibilities.
Apart from this ‘maximum trailer-sailer’, you may want to define your particular wish-list, contact this office, and then see whether we could kick this around some...
Sent:Thursday, May 24, 2018 11:58:04 AM
Also check out PROCEEDINGS of June’14 in US Marine Corps boss GEN Amos’ article on ‘The Connector-Gap’, a Letter in the Dec.‘15 issue, and most recently the Nov’17 piece by USMC’s Col. King.
The fisheries-challenges in MAIB across too many issues.
However, in MAIB mostly more design-concepts to come.
The place may never feel ‘right’.
Well over 100 articles in MAIB, the ‘disruptive’ LCU-F for the US Navy, the ever-so-hands-on 39’ SACPAS-3/GADABOUT boat-building exercise, Fisheries-politics, local Port-politics, etc.
And certainly more ‘lifting’ ongoing and on the schedule, with quite a bit certainly way overdue.
Good thing that major distractions and energy black-holes have been resolved, or are being wrapped up.
The working assumption is – at it has been for so long – that ‘full-steam’ ahead will actual come to indeed mean what it implies on matters Bolger Archive, -books, further opening up of design-work never published.
So, there is only the optimistic way ahead, with lots of intriguing and satisfying projects as far as the eye can see.
Susanne Altenburger, widow to Phil Bolger, collaborator in design and politics between 1994 and 2009.
And under sail, there is the least-draft ‘chine-sailing’ option for broad-teaching across truly skinny waters – impossible in any other hull-type, without an additional shallow keel and thus more draft.
Naah...
From: a.sobriquet@... [bolger] <bolger@yahoogroups.com>
Sent: Wed, May 23, 2018 6:48 pm
Subject: Re: [bolger] steel plate on sharpie bottom
Naah...
Naah...
Naah...
Naah...
Naah...
Naah...
Any ballast and bolts metal underwater would be steel.
Of course, you’d need a barrier-coat over the steel to put (copper-based) bottom-paint on.
Solid copper would seem a ‘dreamy’ option (mega-$$s) with likely self-bending qualities as each plate is (bronze-)bolt-pulled up against the hull-bottom.
My take as a (now former) marine surveyor:
Aluminium hull bottom and steel ballast/shield is a non-starter - the aluminium will gently fizz away to nothing in even slightly brackish water.
If you want to protect the steel from corrosion, then a good epoxy paint system (possibly over a high zinc primer) is a good start, and I'd suggest using sacrificial anodes, with the obvious proviso that you'll need to ensure a good electrical connection between all of the plates (or give each plate it's own anode).
As far as protecting the bolt holes through the hull from water ingress. Drill them oversized, line them with thickened epoxy, then drill them to size when it's cured. I'd also recommend bedding each bolt liberally in your choice of waterproof goop (preferably something intended for marine use, like Sikaflex, rather than the bathroom silicone I kept finding on grotty old Norfolk Broads cruisers).
Dan
My two cents...as an owner of a Bolger Old Shoe sharpie sailboat.Sharpie hulls are nice in many ways.....but they are not the be all and end all of hydrodynamic elegance.Once you have that less than perfect hull...IMO the drag from bolt heads will be in the noise....and counter sunk bolt heads might not be less drag in the first place...and countersunk could lead to another issue or two for that matter.Perhaps an aluminum hull bottom?-----Original Message-----
From:a.sobriquet@...[bolger]mailto:bolger@yahoogroups.com
To: bolgermailto:bolger@yahoogroups.com
Subject: Re: [bolger] steel plate on sharpie bottomChief,I want the system to be usable in salt water, so it needs to be very corrosion resident.I would prefer the bolts to be counter-sunk or counter-bored, to keep the bottom as smooth as possible, but I'm not sure if the steel plate is thick enough to permit this. Does anyone know what did Bolger specified?Has anyone tried an O-ring or rubber washer approach? I wonder how butyl tape would work? It may not tolerate a huge amount of compression, but it will conform to any irregularities, including the bolt threads.Your black oxidation coating doesn't seem as robust as galvanization. One of the attractions of a hull plate is so that the boat can dry out on a rough "beach" with minimal damage.Thanks for you ideasA. S.
---Inbolger@yahoogroups.com,mailto:chiefredelk@...wrote :Just thinking. Salt water or Fresh water?Attached plates expansion control?Easy fix. Bolt holes oversized with O rings to fill the gap in the oversized holes. Rubber washer between metal washer beneath bolt head. Everything can expand and contract while rubber absorbs the slack.Corrosion, Salt water? Ouch.Freshwater not so difficult.A slab of cement attachment with Galvanized (replaceable) bolts feels good to me.Could actually be poured inside on plastic. Would form to boat shape. Cured, remove silicone in place and thank Jesus as you enjoy your boat with exactly what you wanted without the induced drag.Or . Try what I've sorta invented.Place metal in saline bath until an even coat of rust appears. Was well in fresh water dry and place in White vinegar for w week flip over to get both sides BLACKENED.That black stuff can be washed off in warm fresh water using a soft cloth. Don't scratch the metal. It will have a nice Oxidized protective coating. No soap or other chemicals should be on the metal.Sun dry. Want it nice and dry and warm or hot.Spray with rustolem. Choose a color your wife likes. You'll hate it but a happy makes a happy life.Next coat of paint. Latex. They make a Latex paint for rust.We want this metal totally sealed.Scratches shouldn't remove the spray paint but if so touch up immediately.Sometimes a wash cloth soaked in vinegar played over rust then sealed with plastic and duct tape works. In some cases a s yringe can keep the cloth wet for days and tape the needle hole.Good luck. Chief
Virus-free.www.avg.com
Naah...
Dan
From:a.sobriquet@...[bolger]<bolger@yahoogroups.com>
To: bolger<bolger@yahoogroups.com>
---Inbolger@yahoogroups.com,<chiefredelk@...>wrote :Just thinking. Salt water or Fresh water?Attached plates expansion control?Easy fix. Bolt holes oversized with O rings to fill the gap in the oversized holes. Rubber washer between metal washer beneath bolt head. Everything can expand and contract while rubber absorbs the slack.Corrosion, Salt water? Ouch.Freshwater not so difficult.A slab of cement attachment with Galvanized (replaceable) bolts feels good to me.Could actually be poured inside on plastic. Would form to boat shape. Cured, remove silicone in place and thank Jesus as you enjoy your boat with exactly what you wanted without the induced drag.Or . Try what I've sorta invented.Place metal in saline bath until an even coat of rust appears. Was well in fresh water dry and place in White vinegar for w week flip over to get both sides BLACKENED.That black stuff can be washed off in warm fresh water using a soft cloth. Don't scratch the metal. It will have a nice Oxidized protective coating. No soap or other chemicals should be on the metal.Sun dry. Want it nice and dry and warm or hot.Spray with rustolem. Choose a color your wife likes. You'll hate it but a happy makes a happy life.Next coat of paint. Latex. They make a Latex paint for rust.We want this metal totally sealed.Scratches shouldn't remove the spray paint but if so touch up immediately.Sometimes a wash cloth soaked in vinegar played over rust then sealed with plastic and duct tape works. In some cases a s yringe can keep the cloth wet for days and tape the needle hole.Good luck. Chief
To summarize:
---In bolger@yahoogroups.com, <pconnor@...> wrote :
On some of Bolger's sharpies a large, thick, steel plate(s) is attached to the flatish bottom, to act as ballast and for grounding protection. I'm wondering how the plate is prepared to resist corrosion, and what is the best way to attach the plate to the plywood hull bottom?Some specific questions:1) How large can a plate be before the rate of expansion of the steel conflicts with the rate of expansion of the plywood?2) If the plates are to be galvanized...a) where do you get the plates galvanized?b) how thick should the galvanization be?c) what is the maximum size of a plate that can be galvanized?
d) to what extent should plate edges be rounded before being galvanized?
e) if/when the galvanization on the edge of a plate is chipped and the plate starts rusting, how is the rust managed if it creeps in between the plate and the hull, where you can't get at it?
f) how often do the plates need to be re-galvanized?
g) maybe it would be better to coat the steel with epoxy/fiberglass, rather than galvanization???
h) if I had unlimited funds I'd use plates made of a copper/nickle alloy. No corrosion, and self-anti-fouling.
3) What is the best way to bolt the plate to the fiberglassed (I presume) plywood hull? Do you use flathead bolts countersunk into the steel plate? What keeps water from seeping past the bolts into the plywood? Do you use galvanized bolts, or stainless steel bolts, or monel or bronze bolts? Maybe some sort of a gasket can be used? Using a sealant seems like bad idea, if you want to be able to take the plates off.
Thanks for sharing whatever knowledge and experience you've had.
A.S.
On May 23, 2018, at 12:52 PM,a.sobriquet@...[bolger] <bolger@yahoogroups.com> wrote:
A.S.
A.S.
