PCB 1967 39ft cat found in a UK maritime museum treasure trove, & Windsprint dreams too
The UKNational Maritime Museum in Cornwallhttps://nmmc.co.uk/- a huge treasure trove for boaties!
For example, look at their Yacht Design Database of14000 magazine articles.14,000!(Each available for a small postage/handling/copying fee.)
Go to: National Maritime Museum Cornwall > More > Databases > Yacht Design database >
https://nmmc.co.uk/explore/databases/
"... The volunteers in the Bartlett Maritime Research Centre have trawled througheighteen different titles from as far back as 1891, and have extractedover 14,000articles about individual boat designs. We don’t pretend that this is a comprehensive list because we do not have every copy of every yachting magazine over that period, but we think we have found most of them. If you want to find details of a design then use the search facility below to check if we have what you’re looking for. ..."
14000 articles !!
>http://87.106.22.33/iframe/yachtdesigns.php
15,962 entries !!!
It may be slow if loading the lot - a minute or so, similar when loading a fresh sorting)
Sorted by: ID; Designer; Boat Name; Boat Type; Class/Size; Magazine; Year/Month.
Now then:
Search  > Bolger > find 36 designs articles listed
From 1958:
11621 Bolger, Philip C  Yacht, motor 29 ft LOA - twin screw Yachting World 1958/06 266 (What one is that?)
To 2009:
4602 Bolger, Phil Chebacco 20 Dinghy, sailing 20 ft LOA Watercraft 2009/11 18
Ok then,what is this?
multihull, "Arachne", from 1967...
Sail or motor?
>700Bolger, Philip Arachne Catamaran 39 ft LOA Yachting World 1967/09page 416
Also there...
I wonder how PCB's listed write-up ofWindsprintread in CLASSIC BOAT  in 1991?
Was Windsprint ever written up by PCB in WoodenBoat or MAIB in the US?Nothing in SBJ...
But, ...In about1994there was a short piece by a Hans Waeker inMAIB, Volume 11 Issue 22, titled 'Rerigging "Windsprint"', that described a neat idea that worked great using the original spars and sail. After corresponding with PCB he rigged a peak halyard,butfixed it not to the peakbutto the yard just above its centre of gravity. The yard then behaved like a gaff in lowering and raising. The new "peak" halyard is rove through the former halyard slot in mast tip, and the throat halyard through a new hole set below the slot. He spliced the two halyards together just above the belaying cleat, so that in raising sail only one halyard need be hauled. The yard now behaving pretty much as a gaff, no thrashing dramas, he fitted lazy jacks shown in PCB's "100 Small Boat Rigs" at page 49. This "peak" halyard / halyard / lazy jack / topping lift combination worked great on his model and at full size.. all handled easily from the cockpit. He gave some measurements.
Dave Thibodeau's index forMAIB Bolger On Designarticles to 23/10/01 shows:
"#423 30' Camper/Daysailer 32'x7'V11I22p28for that issue... aboutMay 15,1994.
But, ...Bruce Hallman's 2008 MAIB Index is blank for that issue. Use 'Search Conversations' for the message archive for:
#59286 From: "Bruce Hallman" <bruce@...>
Date: Wed Dec 31, 2008 5:01 am
Subject: Re: MAIB index of Bolger articles
==============MAIB Index of Bolger articles below=======
Vol  No   Title        Date  Opus
V06  N11  Anhinga
V06  N16  A Bolger Rendezvous  1/1/1989
V06  N17  Jinni
V06  N22  Monster Micro, AS-29
V06  N24  Ron Muller's Birdwatcher
V07  N02  Shoebox Punt
V07  N06  Michalak Birdwatcher Launching
''        "       "        " &etc...
V11  N01  Yamato Fishing Launch  5/15/1993
V11  N02  Commuter
V11  N03  A Trailer Motorsailor
V11  N04  Advanced Sharpie 29
V11  N05  Spartina
V11  N06  Concept For A Steel Excursion Boat
V11  N07  Aluminum Trailer Cruiser
V11  N08  Long Micro
V11  N09  Dick Welch's Microtrawler
V11  N09  Keel Sailing Dingy
V11  N10  21' Canoe Yawl
V11  N10  Long Micro Build
V11  N11  Aluminum Diesel Launch
V11  N12  Flat Iron Skiff
V11  N14  20' Hard Bottom Inflatable
V11  N14  Jinni Build
V11  N15  Compact Charter Schooner
V11  N16
V11  N17
V11  N18
V11  N19
V11  N20
V11  N21
V11  N22
V11  N23  Fie Fia
V11  N23  Common Sense Skiff Build
V11  N24  Schooner Rigged Stonehorse
V12  N01  Eight-oared Cutter  5/15/1994
"       "        "   & etc, etc...
V26  N07  Black Gauntlet Cover
V26  N07  Peter Duff Bio
V26  N07  Life Of Maggie And Peter Duff
V26  N07  Lady Slipper
V26  N07  Canard - Bow Steering
V26  N07  Dovekie Shearwater Nov15 1987 Reprint
V26  N08  Building Sneakeasy
V26  N08  Update On The Plywood 12 Design
end.
"Arachne" cat? From the group designs databases could it be "#398, Cruising Catamaran,Single staysail from aft mast\, Inboard engine"? Sounds much like the Bolger catamaran design in Derek Harvey's reference book Multihulls for Cruising & Racing, but that book wasn't published until 2003. Also a #398 in orderly sequence would be from late 70s early 80s. Of course #398 could feature in the later Harvey book twenty years later, but how would it get in a 1967Yachting Worldarticle some thirteen years earlier than the design numbering sequence suggests?
