Re: Weldwood split from Good Wood
I had NO problem during use after boat (Pointy Skiff) was in use.
When attaching the sides to frames and stem the butts separated. I
probably didn't let the glue set up right, use enough weight or mixed
wrong. I chock it up to experience. To correct it, on one side I used
Premium PL on where the wood split (from the butts) and on the other
side I used 3M 5200 and then clamped them, side on frames and stem.
I used butts with Weldwood on the Nymph frames with no problems.
Set up rock hard there, but it was much drier time of year. When I
butted the side for the skiff it was a really steamy hot Florida day.
No real complaints with Weldwood. I will use again. Time will tell if
either butt breaks apart with increased use.
my 2 cents,
Rich
--- Inbolger@egroups.com, "Donald Hodges" <dhodges@w...> wrote:
> I hate to butt in, but I built a 12-footer using Weldwood "long
ago". It
> requires more precise joinery and clamping than I'm willing to fool
with as
> life gets shorter, otherwise it is ok.
> I believe it has been far surpassed by epoxy and even PL Premium.
It works
> a lot like resorcinol, and that was over after the 50's...
> Don Hodges
> From: Mark Albanese <marka@o...>
> To: <bolger@egroups.com>
> Sent: Thursday, September 07, 2000 11:30 PM
> Subject: [bolger] Re: Weldwood split from Good Wood
I hate to butt in, but I built a 12-footer using Weldwood "long ago". It
requires more precise joinery and clamping than I'm willing to fool with as
I believe it has been far surpassed by epoxy and even PL Premium. It works
Don Hodges
I have seen black top at 150 when the air was 104. When it is 115 you can
fry an egg on the sidewalk in Witicha Falls, Texas.
If I was making a laminated mast for this country that had to live on
pavement. I would use one of the epoxies that cured at 130 or so and build
an oven out of Styrofoam and cure it in a vacuum bag. And something to
blow hot air in the oven. Or just use a tin barn in the summer time.
Gordon
Gordon Cougergcouger@...
405 624-2855 GMT -6:00
> Gary,
> Thanks for this. I'd been focussed on application time
> effects. Your story helps a lot. In the heat, the wood must
> have distorted from the glue line with terrific force. Hard
> to imagine. Where I live it's the rare day that gets past
> 85-90. My sympathy to you for the trouble you had.
> Anyone have other horror stories about using Weldwood? The
> stuff is so attractive in some ways, it would be nice to
> know if anything, else than intense humid heat exposure can
> go wrong.
> Most discussion I've seen in books and magazines centers on
> how waterproof it is, Weldwood being officially only water
> 'resistant'. And there's that famous quote ( re: waterproof
> testing ) from Pete Culler, warning not to use it if you
> plan to boil your boat. Anyone had it delaminate through
> soakage at moderate temperature alone?
> Scott Birch: If you're still following this, would you care
> to tell how it's been, "Useless" for you?
> With scientific spirit,
> Mark
> "Gary" wrote:
> > It wasn't when or how they were laminated that was the problem. It
> > was
> > afterwards after the varnished-finished masts had been exposed to
> > the summer sun & heat. In one case, my Zephyr mast delaminated
> > after it had been left at a repair shop after the trailer axle broke.
> > The boat and mast sat in the sun on a blacktop parking lot for a week
> > in the summer and most of the seams let go. The second mast on my
> > 19-foot catboat) was never exposed to quite that extreme, but had the
> > disconcerting habit of letting go while the boat was under sail,
> > although fortunately the mast never broke. I don't think it had
> > anything to do with how the glue was applied -- it was mixed normally
> > and spead without difficulty -- but rather the heat and humidity it
> > was exposed to later.
> > Gary
> - no cursing
> - stay on topic
> - use punctuation
Gary,
go wrong.
> was
> Gary
