Re: what about using the bow for the stern?
Dewey
your right it is the shape I was talking about
sometimes I wonder if there is anything left to invent in the way of
boats
I love the writing of Mr Bolger when he stated " I was prepaired to
be
mildly aplogetic if there were cracking sounds when tested by
playcing
the boat on saw horses and having sevel men jump up and down in the
middle..."
a wize bit of do it and then test
thankyou for the memory
the last page of on the Gloucester Gull in my copy of 'Bolger Boats',
a reprint of small boats and the folding schooner, had a photo of one
built by Shelter island yacht Ways of san diac=go said to be a
lively
sailer but tricky and wet looks as through some ballest would be a
good idea
thankyou
boats
be
playcing
middle..."
lively
good idea
thankyou
--- Inbolger@egroups.com, "John Ewing" <j.c.ewing@h...> wrote:
> Jeff, I recently was able to purchase a somewhat musty copy of
PCB's
> 1973 book, SMALL BOATS. On page 48 I discovered the 'Gloucester
> Yawl', with a hull shape not unlike what you are imagining (if I
> interpret your post correctly). At 21'0" x 5'6" with a
double-ended,
> box-section 'cutwater' reaching 3'4" in width amidships, the
> Gloucester Gull was intended to be sailed and rowed by a crew of
four
> or five. It is not comparable in purpose to Microtrawler but you
can
> see a Bolger thread there. The design was apparently too,
> um, 'original' for the would-be client, who rejected it in the end.
> But I can't help but wonder if it's been built by others. I don't
see
> any links to Gloucester Yawl through the usual (to me, at least)
> Bolger-related Websites. Does anyone on the List have any
information?
> John 'Dewey' Ewing, in Victoria
> --- Inbolger@egroups.com, Mark Albanese <marka@o...> wrote:
> > Jeff,
> > Probably the boat you're scheming up won't plane anymore, nor
> support a 50 HP
> > outboard without dragging the sponsons badly. Part of the beauty
> the
> > Microtrawler is combining good high and low speed operation,
which
> is what the
> > typical wide transomed, driveway sculpture just won't do.
> > Bolger has done what you describe in the sailboat 'Antispray,'
now
> abuilding,
> > and discussed here recently under "re: Big but not huge sharpie."
A
> low speed proposition.
> > Around Oregon, there are the George Calkins shallow vee bottom,
> double-ended,
> > planing 'Bartenders.' with a very good reputation for
seakeeping.
> They come in
> > different sizes, but the 3000# 22 footer needs 150 HP.
> > Mark
> > freedem@e... wrote:
> > > The box cutwater bow in the microtrawler design gives a fine
entry
> > > and
> > > I wonder if it was used also for the stern would that give a
low
> drag
> > > shape with steadyness from the sponsons What do you all think
> this
> > > usage idea?
> > > thankyou
> > > Jeff
> > > Bolger rules!!!
> > > - no cursing
> > > - stay on topic
> > > - use punctuation
> > > - add your comments at the TOP and SIGN your posts
> > > - add some content: send "thanks!" and "ditto!" p
Jeff, I recently was able to purchase a somewhat musty copy of PCB's
interpret your post correctly). At 21'0" x 5'6" with a double-ended,
Gloucester Gull was intended to be sailed and rowed by a crew of four
or five. It is not comparable in purpose to Microtrawler but you can
But I can't help but wonder if it's been built by others. I don't see
Bolger-related Websites. Does anyone on the List have any information?
> Jeff,
support a 50 HP
> outboard without dragging the sponsons badly. Part of the beauty of
> Microtrawler is combining good high and low speed operation, which
is what the
> Bolger has done what you describe in the sailboat 'Antispray,' now
abuilding,
> and discussed here recently under "re: Big but not huge sharpie." A
double-ended,
> planing 'Bartenders.' with a very good reputation for seakeeping.
They come in
> Mark
> freedem@e... wrote:
> > The box cutwater bow in the microtrawler design gives a fine entry
> > and
> > I wonder if it was used also for the stern would that give a low
drag
> > shape with steadyness from the sponsons What do you all think of
this
> > usage idea?
> > thankyou
> > Jeff
> > - no cursing
> > - stay on topic
> > - use punctuation
> > - add some content: send "thanks!" and "ditto!" posts off-list.
Jeff,
Probably the boat you're scheming up won't plane anymore, nor support a 50 HP
outboard without dragging the sponsons badly. Part of the beauty of the
Microtrawler is combining good high and low speed operation, which is what the
Bolger has done what you describe in the sailboat 'Antispray,' now abuilding,
and discussed here recently under "re: Big but not huge sharpie." A low speed proposition.
Around Oregon, there are the George Calkins shallow vee bottom, double-ended,
planing 'Bartenders.' with a very good reputation for seakeeping. They come in
> and
> I wonder if it was used also for the stern would that give a low drag
> shape with steadyness from the sponsons What do you all think of this
> usage idea?
> thankyou
> Jeff
> - no cursing
> - stay on topic
> - use punctuation
