Re: [bolger] Re: so-and-so FG butt block
They certainly make life easy.
A word of caution is due though... be careful where you are point them,
where you lay them down, and how long you leave them pointed at your boat.
Epoxy covered wood BURNS and those guns are DAMN HOT.
I used to use mine to light cigarettes...
Richard Spelling,http://www.spellingbusiness.com/boats
From the muddy waters of Oklahoma
To: <bolger@egroups.com>
Sent: Wednesday, September 13, 2000 10:53 AM
Subject: [bolger] Re: so-and-so FG butt block
> All,
> I have been using a heat gun and furniture scrapers (also putty
> knives sharpened like furniture scrapers) on two boat projects with
> great results. Removing excess epoxy in this way is far easier and
> less messy than sanding. I was concerned about the heat permanently
> affecting the strength of the epoxy but the people at Gougeon
> Brothers said that as long as you don't char the epoxy there is no
> strength degradation. Also, only prolonged exposure (days, weeks) to
> high temperatures (below the "char" point)would cause a strength
> problem. I believe that this method can cut many hours out of "excess
> epoxy" removal.
> Al, in Ann Arbor
> --- Inbolger@egroups.com, "Harry W. James" <welshman@p...> wrote:
> > I had forgotten about using a heat gun. You can peel fiberglass up
> really
> > easily with one. Get a corner up and grab hold with pliers and pull
> while
> > working the heat gun ahead of where it is lifting. You could try
> with a hair
> > drier, but it probably doesn't get hot enough. Harbor Freight has an
> > inexpensive gun that works fine for this.
> > HJ
> > > Two second blast from heat gun, scrap epoxy off like putty.
> > > Makes those odd, tight corners a simple matter. Run heat gun over
> epoxy,
> > > scrape with scraper. repeat. Beats the %@#% out of sanding...
> > _ _ _ _ _
> > % Harry welshman@p...
> - no cursing
> - stay on topic
> - use punctuation
All,
epoxy" removal.
Al, in Ann Arbor
really
while
with a hair
> HJ
epoxy,
> _ _ _ _ _
All,
strength degradation. Only prolonged exposure (days, weeks) to high
temperatures would cause a strength problem. I believe that this
method can cut many hours out of "excess epoxy" removal.
Al, in Ann Arbor
really
while
with a hair
> HJ
epoxy,
> _ _ _ _ _
Watch out for the fumes. I was scraping old polyester resin off the inside
of a canoe when I found out how well heat works. I had left the canoe right
side up on sawhorses, under a polytarp overnight. When I started work about
midday, I just peeled back the tarp for a few feet. The sun had really
warmed things up, and it was like an oven in the canoe -- the resin just
peeled off, no problem, but within a few minutes I was staggering like a
drunk, had to sit down as I couldn't stand without holding on to something.
Felt like hell too, bad headache and nausea. So wear a good fume filtering
mask, and don't breath that stuff!
Jamie Orr
PS I finished the job with a heat gun, just as you suggest, but with a mask
and lots of ventilation.
Sent: Tuesday, September 12, 2000 9:16 PM
To:bolger@egroups.com
Subject: Re: [bolger] Re: so-and-so FG butt block
I had forgotten about using a heat gun. You can peel fiberglass up really
easily with one. Get a corner up and grab hold with pliers and pull while
working the heat gun ahead of where it is lifting. You could try with a hair
> Makes those odd, tight corners a simple matter. Run heat gun over epoxy,
_ _ _ _ _
% Harrywelshman@...
- no cursing
- stay on topic
- use punctuation
_ _ _ _ _
% Harrywelshman@...
Sent: Tuesday, September 12, 2000 12:00 PM
> --- How do you use the Heat Gun?
> Leander
> > Using that, and judicios application of a heat gun, has made
> boatbuilding a
> > much more pleasant task, and I'm getting a much smoother finish
> than
> was
> > possible before, for less work.
> - no cursing
> - stay on topic
> - use punctuation
Leander
boatbuilding a
than
was
When I visited Mike Stockstill, he suggested using a sureform rasp. Have to
say, this is one of the best ideas I've seen in awhile.
While it hasn't completely eliminated the need for a sander, it sure makes
life easier on the larsboat I'm making. I even went out and bought a small
one, about 1 1/2 inches long, for inside the boat.
Using that, and judicios application of a heat gun, has made boatbuilding a
much more pleasant task, and I'm getting a much smoother finish than was
> When I visited Dynamite Payson this summer he told me he no longer
> wants to build anything that involves sanding fiberglass. He doesn't
> mind putting it on but he hates sanding it off.
> Vince Chew
> P.S. Can anyone tell me how to solve my problem with this posting
> editor?
Vince:
I simply post to:bolger@egroups.comusing my regular e-mail program.
Somehow through the magic of the internet, they end up on egroups. You
might give that a try.
http://www.egroups.com/files/bolger/Dakota/Dakota05.jpgshows a 40
foot X 4 foot panel with four fiberglass butt splices being picked up
and moved. Using the method I described in message 7204, I got quite
good results taping both sides simultaneously. Since I had to make
four
panels for the shoe and six for the bottom, it was worth the effort
make up the laminated clamps. If you are only doing a couple, it
might
not be worth the trouble.
I make sure when I am dishing out the ends of the sheets to receive
tape that I remove the proper amount of material. It is better to err
on the side of removing a bit too much rather than too little since
it
is
far
easier to fair a slight hollow than it is to sand down a hump.
Vince Chew
editor?
> Harry, Leander and the others, I'm just curious now: what did you do
> when you FG butt blocks failed? Scraped the FG down to the bare wood
> like I did? I'll tell you, it was hard work. Even if I catched it
> with less than 24 hours cure time , it took one good hour of tough
> scraping with the long Surform. And a lot of itch on hands...
Pippo: I always use a belt sander with a coarse grit, or an angle grinder
with a sandpaper disk. Either of these will make fast work of FG.
>FG is
> nasty stuff. Moreover, mine was pretty tough stuff (9 oz biaxial)...
> I'm tempted to do 1 layer at a time, but since what I'm doing is to
> join the two Micro hull sides (10 mm thick), I'm scared to break the
> joint when turning the panel upside down...
> Best, Pippo
To turn over two joined panels that are glassed on one side only, do as
Leander mentioned and clamp a board across the joint before turning the
whole thing over. Two boards (one on each edge) works even better.
Hi,
I have only done this once, so I am no expert, but both sides of my joints
came out very well.
I used a 2 ft x 4 ft piece of HD particle board under my layups, and the
same size on top of the layups, with probably 100 lbs of weigh on the
sandwitch. I covered the particle board with polyethelene so that it would
not stick. I think that one thing that you need to be carefull of is not to
use too much epoxy on the cloth. It is only necessary to use enough to
completely wet the F/G cloth. Any more than that does not add any strength,
and will ooze out and make the joint harder to fair. I used a sheet of poly
on my work bench and wet the cloth there before putting it on the poly on
the jig. I made sure that the wood was wet out as well before placing it in
position. I pretty well followed Dave Carnell's directions. I did goof up
in another way. I made the side joints seperately. When I got thru they
did not match exactly because I did not have the joint properly aligned. I
am building anther boat, and this time I will stack the sides, and make both
joints at the same time so that the side will match perfectly. They might
not be perfect, but they will be alike!
James Fuller
Sent: Monday, September 11, 2000 8:19 AM
