Re: bolgers ocean abilities
On the original idea of this thread, simple ocean cruisers, Bolger
showed an interesting boat in the November 1, 1996 MAIB.
It's 39'centerboard yawl, double chine (like Chebacco) ply
construction. It looks to me like a fast and able boat. Accomdations
are a little looser and more conventional than the AS-29, but there
is no double bed.
There is a wishbone on the jib and a spirt boom on the mizzen.
is no double bed.
I for one don't mind a little repeat discussion-always brings out new stuff
anyway. Besides I don't have the time to search all the postings for every
new idea I have, but it does appear that you may have been the first to
discover the striking similarity to the AS29.
Frank Bales
Staunton, VA
Sent: Friday, September 15, 2000 3:33 AM
To:bolger@egroups.com
Subject: [bolger] Re: bolgers ocean abilities
Dick Pilz,
Before all Hell breaks loose again,may I refer you to a series
of postings from the past beginning with number:1613 onward?
Frank Bales
Staunton, VA
Dick Pilz,
--- Inbolger@egroups.com, "Dick Pilz" <dickpilz@g...> wrote:
> While you are at Tanton Designs, check out design #980 "Sea-Egret".
> It looks hauntingly familiar ... like a copy of AS-29.
> --- Inbolger@egroups.com, "Peter Vanderwaart" <pvanderw@o...>
> > > I am interested in a as29 or > a
> > > Jessie Cooper. what is the ocean abilities of these boats. have
> any
> > In the original writeup on Jessie Cooper, Bolger suggested that
it
> > wasn't really meant for ocean sailing. I'm not sure what his
> attitude
> > would be on the AS-29.
> >http://www.tantonyachts.com(click on catalogue, then find design
> > #946. Click on the checkmark.)
- no cursing
- stay on topic
- use punctuation
my two cents,
The Cape Cod Catboat has also been used for extensive voyages, but
it has similar problems that the Cat ketch rig has in that it is
susceptible to boom tripping in large seas. This usually results in
broken mast.
I feel that a good ocean crossing sailboat should have the ability
to shorten sail and heave to in the roughest conditions for the
safety
and comfort of the crew.
I am not planning a trans-Atlantic crossing in my Micro however, I
will use it for extensive coastal cruising. If the seas get to rough
I
will through it on the trailer and go home. Planning is essential.
I
still have not cut out the ventilator in bulkhead A as I have this
thing about preserving the watertight envelope the cabin forms. I
will
probably change my mind about this after the first hot, stuffy,
night.
It can always be done later. Maybe a standard Beckson style
portlight.
"should be working"
broken mast.
safety
I
I
will
night.
portlight.
"should be working"
> While you are at Tanton Designs, check out design #980 "Sea-Egret".Also check out #997 for a simple ocean cruiser. She does have
conventional rigging and deep keel though.
Dick Pilz,
> any
it
> attitude
Hi -
Last correspondence I had from Phil and Susanne indicated a strong
interest in a design intended for ocean cruising in the AS style and
size. Hopefully they will have something like that out in the next
few months perhaps.
Food for thought.
Burp.
Mike
few months perhaps.
Food for thought.
Burp.
Mike
--- Inbolger@egroups.com, elpicco@i... wrote:
> Hi all
> I am busy building a wharram tiki 26, but am interested in a as29 or
> a
> Jessie Cooper. what is the ocean abilities of these boats. have any
> crossed oceans , weathered storm
any
> In the original writeup on Jessie Cooper, Bolger suggested that it
attitude
> I am interested in a as29 or > aIn the original writeup on Jessie Cooper, Bolger suggested that it
wasn't really meant for ocean sailing. I'm not sure what his attitude
In either case, I don't think that the cat-yawl is a good rig for
ocean sailing. The boom is too long and too likely to get forced into
the water and broken. The mast is too far forward and there isn't
much deck space around it. If I were thinking of going trans-ocean, I
would ask Bolger about the Chinese Gaffer rig which would make it
easier to reef, etc, from the cockpit.
On the A-29, if the mast folding gear were robust enough to lower the
mast in heavy seas, it would be a major safety factor to be able to
lower the rig while riding to a sea anchor in a hurricane.
I also would prefer a hull shape with a quieter entry.
I've been trying to choose the most similar design that I would be
happy with. There is the Bahama Mama
www.databoat.com/boatingbooks/boatplans/GFCBoats/BahamaMama.html
and Sea Shell
Among Bolger designs, there are several good ones that are strip
planked. Among the ply boats that I know of is Arava (design #309), a
9m, double chine cutter/schooner. It appeared in MAIB a couple of
years ago. He has others that are not in any of his books.
Hi Nathan and welcome to the list
regarding the Jessie Cooper, I'd suggest that you take a look to
Chuck Merrell's web site at www.boatdesign.com. You might contact him
'cause he built a JC and he developed a revised version of the design.
Regarding the AS29, the two best web sites are Leo Foltz's
http://www.leow.de/(info and building pics) and Tim Fatchen's
(who owns an AS29)http://www.ace.net.au/schooner/as192939.htm#as29
(lots of info).
Plans for both should be available from the designer's office:
Phil Bolger and Friends
Post Office Box 1209
Gloucester MA 01930, USA
Fax: 001 (978) 282-1349
No web yet!
Best, Pippo
(lots of info).
No web yet!
Best, Pippo
> Hi all
> a
> crossed oceans , weathered storms?
> I like the simplicity of the designs.
> Are plans of the jessie cooper available.
> I like the as29/31 of the zeiger family up in juneau alaska.it
looks
> like a nice liveaboard size boat
> Then again i like the level sailing of a catamaran as well.
> thanks for all the posts, this group is a lot busier than the
wharram
> group at the moment.
> Long live simple boats that ordinary people can build and get out
> there and live the dreams they want.
> nathan levin
>http://www.icon.co.za/~elpicco
Hi all
I like the as29/31 of the zeiger family up in juneau alaska.it looks
thanks for all the posts, this group is a lot busier than the wharram
nathan levin
nathan levin
