New file uploaded to bolger
This email message is a notification to let you know that
a file has been uploaded to the Files area of the bolger
group.
File : /SailLacing-Schuster1.pdf
Uploaded by : polysail <polysail@...>
Description : Techniques for lashing a sail to a mast
You can access this file at the URL:
https://groups.yahoo.com/neo/groups/bolger/files/SailLacing-Schuster1.pdf
To learn more about file sharing for your group, please visit:
https://help.yahoo.com/kb/index?page=content&y=PROD_GRPS&locale=en_US&id=SLN15398
group.
File : /"Spark" Modifed Cruising Bolger Bobcat/Spark sail up.JPG
Uploaded by :david.chambers49221@...<dchamb@...>
Description : Driveway sailing
https://groups.yahoo.com/neo/groups/bolger/files/%22Spark%22%20Modifed%20Cruising%20Bolger%20Bobcat/Spark%20sail%20up.JPG
group.
File : /"Spark" Modifed Cruising Bolger Bobcat/photo-4_zpsd6d7111f.jpg
Description : Moored 3
https://groups.yahoo.com/neo/groups/bolger/files/%22Spark%22%20Modifed%20Cruising%20Bolger%20Bobcat/photo-4_zpsd6d7111f.jpg
group.
File : /"Spark" Modifed Cruising Bolger Bobcat/photo-3_zps175575f1.jpg
https://groups.yahoo.com/neo/groups/bolger/files/%22Spark%22%20Modifed%20Cruising%20Bolger%20Bobcat/photo-3_zps175575f1.jpg
group.
File : /"Spark" Modifed Cruising Bolger Bobcat/Spark.jpg
Description : Spark on trailer
https://groups.yahoo.com/neo/groups/bolger/files/%22Spark%22%20Modifed%20Cruising%20Bolger%20Bobcat/Spark.jpg
group.
File : /LCU-F/Bridging Our Surface-Connector Gap U_S_ Naval Institute.mht
Uploaded by : c.ruzer <c.ruzer@...>
Description : Proceedings Magazine article June 2014. LCU-F #673 at fifth paragraph from end
https://groups.yahoo.com/neo/groups/bolger/files/LCU-F/Bridging%20Our%20Surface-Connector%20Gap%20%20U_S_%20Naval%20Institute.mht
group.
File : /LCU-F/LCU-F in Proceedings Mag July2013.pdf
Description : Article
https://groups.yahoo.com/neo/groups/bolger/files/LCU-F/LCU-F%20in%20Proceedings%20Mag%20July2013.pdf
group.
File : /LCU-F/LCU-F see pp 16-19 ProjectsOverviewByCaptMarkThomas091109.pdf
Description : Powerpoint. LCU at pp 16-19
https://groups.yahoo.com/neo/groups/bolger/files/LCU-F/LCU-F%20see%20pp%2016-19%20ProjectsOverviewByCaptMarkThomas091109.pdf
A couple of general observations…
At displacement speeds, a hull shape that goes through the water with the least turbulence will have the least drag. Thus, a spindle shaped hull with semi-circular cross sections has minimal drag. But (always comes the but!) such hulls have minimal initial and reserve stability and hulls of this type are generally found on racing shells and kayaks.
A boat with a flat transom will generate a lot of turbulence and drag at displacement speeds if the transom is immersed in the water. This is why most rowing boats have either a very narrow transom (dories) or a heart shaped transom (producing a double ended boat at the design waterline). A flat bottomed boat can work with the stem a little out of the water or immersed in the water (and a number of Atkins boats are designed to have the stem in the water). However, any flat bottomed boat with a transom needs to keep the transom out of the water or it will generate a lot of turbulence and a case of the slows.
Sail boats and boats which carry loads complicate design considerations-- sail boats because they must have enough stability to resist the heeling forces exerted by the sails and because they must operate at varying angles of heel. A flat bottomed boat with a hard shine will generate some turbulence/drag along the chine as water moves from an area of high pressure on the bottom to lower pressure along the chines. Bolger theorized that if the curve of the side matched the curve of the bottom, turbulence would be reduced and he designed many successful boats based on this theory. He also accepted that if the chine could be radiused (as it is on Dovekies. O’Day 22’s, and nonpareil sharpies), turbulence along the chine would be greatly reduced and the need to match bottom and side curve s would also be reduced.
When you factor in loads, you need to figure out a way to increase displacement while keeping the transom out of the water and this is normally accomplished on flat bottom boats with rocker.
When you start talking about planeing boats or very light displacement boats (to include multi-hulls) the world changes and many other design choices enter the picture.
JohnT
bolger@yahoogroups.com ]On Behalf OfTom Pee
Sent:Saturday, April 19, 2014
11:18 AM
Subject:Re: [bolger] Re: New file
uploaded to bolger
"goes best" according to what? Bolger as well as other sharpie designers have designed hulls round or straight, bows and sterns above or below waterlines and all can work well as long as you keep sharpies light, with at least 4-1 beam-length ratios, and low topsides.
On Friday, April 18, 2014 8:29 AM, earling22 . <dave.irland@...> wrote:
Bolger states several times in his writings that a sharpie goes best when the rocker profile matches the plan view ( side curvature). It's not absolutely critical, but the boat sails better on some point or other (can't remember), probably to windward. Also, as for the dovekie, as pointed out by another poster, heavily radiused chines remove this requirement so you can get away with a dead flat bottom. He first noticed this at an early 1970s boat show when the oday 22 first appeared, which has a bottom that is dead ringer for a dovekie, which bolger declared a breakthrough. As an oday 22 owner, I can attest to the zippy, well balanced qualities of that boat. (I also have a dovekie, but haven't sailed it yet.) I think this is all in that podcast.
Also, I'll just repeat that the cushion or fender under the bow fixes the drumming at anchor just fine.
The skimmer is for sure a great sailing boat, super close winded (with the right sails) and a blast on a reach or a run, especially with the hiking board deployed. The rig needs upgrading vs. the stock drawings (fatter boom, two part spotter lead to cockpit, leeboards tackle, few other things) but all in all, an exemplary sharpie
group.
File : /SBJ FLA Keys Cruise/SBJ FLA Keys Cruise.pdf
Uploaded by : marka97203 <marka97203@...>
Description :
https://groups.yahoo.com/group/bolger/files/SBJ%20FLA%20Keys%20Cruise/SBJ%20FLA%20Keys%20Cruise.pdf
group.
File : /unknown Bolger hull/image.jpg
Uploaded by : gunnerscoin <gunnerscoin@...>
Description : Photo 1
http://groups.yahoo.com/group/bolger/files/unknown%20Bolger%20hull/image.jpg
http://help.yahoo.com/l/us/yahoo/groups/original/members/web/index.html
group.
File : /POOHSTICKS Design 10-II-57/How to Build, Popular Boating, May 1961, p181.pdf
Description :
http://groups.yahoo.com/group/bolger/files/POOHSTICKS%20%20Design%2010-II-57/How%20to%20Build%2C%20Popular%20Boating%2C%20May%201961%2C%20p181.pdf
group.
File : /POOHSTICKS Design 10-II-57/How to Build, Popular Boating, May 1961, p180.pdf
Description :
http://groups.yahoo.com/group/bolger/files/POOHSTICKS%20%20Design%2010-II-57/How%20to%20Build%2C%20Popular%20Boating%2C%20May%201961%2C%20p180.pdf
group.
File : /Hardware/Rack Clamp.pdf
Uploaded by : stefanhanoi <stefan.probst@opticom.v-nam.net>
Description : DIY cheap long F clamps
http://groups.yahoo.com/group/bolger/files/Hardware/Rack%20Clamp.pdf
group.
File : /1AAA BOLGER LINKS/Designs Links 120824.zip
Description : Zipped file of bookmarked Bolger design link favourites
http://groups.yahoo.com/group/bolger/files/1AAA%20BOLGER%20LINKS/Designs%20Links%20120824.zip
group.
File : /Storm Petrel/Storm Petrel Discourse.pdf
Description :
http://groups.yahoo.com/group/bolger/files/Storm%20Petrel/Storm%20Petrel%20Discourse.pdf
group.
File : /Storm Petrel/Bolger Storm Petrel Tony's 7.jpg
Description :
http://groups.yahoo.com/group/bolger/files/Storm%20Petrel/Bolger%20Storm%20Petrel%20Tony%27s%207.jpg
group.
File : /Storm Petrel/Bolger Storm Petrel Tony's 6.jpg
Description :
http://groups.yahoo.com/group/bolger/files/Storm%20Petrel/Bolger%20Storm%20Petrel%20Tony%27s%206.jpg
group.
File : /Storm Petrel/Bolger Storm Petrel Tony's 1.jpg
Description :
http://groups.yahoo.com/group/bolger/files/Storm%20Petrel/Bolger%20Storm%20Petrel%20Tony%27s%201.jpg
Jon
>http://groups.yahoo.com/group/bolger/files/Micro/Lenihans%27%20%20%22LESTAT%22%20/home%20sweet%20home.jpg
> Regards,
> ellengaestboatbuildingcom <peterlenihan@...>
--- Inbolger@yahoogroups.com, BruceHallman <hallman@...> wrote:
> > File : /Micro/Lenihans' "LESTAT" /home sweet home.jpg
> > Uploaded by : ellengaestboatbuildingcom <peterlenihan@...>
> > Description : Windermere resting at her quay......it has been a long wait!
> Wow! Peter super news, she looks gorgeous, what a great accomplishment!
--- Inbolger@yahoogroups.com, "Peter" <peterlenihan@...> wrote:
> --- Inbolger@yahoogroups.com, "John Kohnen" <jhkohnen@> wrote:
> > Congratulations, Peter! It's been a long time coming. I'll bet it feels
> > good to see her in the water! :o)
> Thank you John! I cannot begin to describe how good it feels to be both finished with the building of her and now begining to live the dream I've had for so long.It's a wee bit over-whelming and sweeter than honey!
> Cheers!
> Peter
> File : /Micro/Lenihans' "LESTAT" /home sweet home.jpgWow! Peter super news, she looks gorgeous, what a great accomplishment!
--- Inbolger@yahoogroups.com,bolger@yahoogroups.comwrote:
> Hello,
> group.
> File : /Micro/Lenihans' "LESTAT" /ry=480.jpg
> Description : Windermere about to be launched
>http://groups.yahoo.com/group/bolger/files/Micro/Lenihans%27%20%20%22LESTAT%22%20/ry%3D480.jpg
> Regards,
Ben
> Cheers!
> Peter
>Yes, it is true Bob,things "kind of stopped"......and that was due to some craziness which occured here:
> Really glad to see her launched! You used to post so often during the early years of building (and beer drinking), then kind of stopped; so I had wondered what was going on :) We all want photos of your first cruise too!
> Bob
http://forum.woodenboat.com/showthread.php?80153-Just-fore-the-fun-of-it-%29
Lots of pictures and yapping of the build process happened there.
Cheers!
Bob
> Cheers!
> Peter
Cheers!
> group.
> wait!
John (jkohnen@...)
Eels are said to kelter in the water when they wamble.
group.
group.
group.
File : /Temporary/PortSkiff4.pdf
Description : Somewhat better scans of Portland Skiff photos.
http://groups.yahoo.com/group/bolger/files/Temporary/PortSkiff4.pdf
On 04/19/2011 09:38 AM, Douglas Pollard wrote:Sorry guys, wrong group wrong conversation. Clicked the wrong e-mail and replied:-[ DougMy father used to say about religion. "In the beginning there was chaos, and God made the world and it has been chaotic ever since. Doug
On 04/19/2011 08:56 AM, Walter wrote:
--- Inbolger@yahoogroups.com, Mark Albanese<marka97203@...>wrote:
> The rules for these make me feel like Josef K.
> If I think my good quality tiffs are just too large and reduce them
> into gifs, the larger one of those gets through but not the smaller.
> Sheesh.
Mark- convert to jpeg's at 72 ppi, about 600 pixels on the long side, save at quality 10 or so.This seems to work well for most web based images.
> Sheesh.
> Sheesh.
Sheesh.
group.
File : /FellucaSail.gif
Description :
http://groups.yahoo.com/group/bolger/files/FellucaSail.gif
group.
File : /Swallow/Swallow003a.tif
Description :
http://groups.yahoo.com/group/bolger/files/Swallow/Swallow003a.tif
group.
File : /Swallow/Swallow.tiff
Description : BW clone
http://groups.yahoo.com/group/bolger/files/Swallow/Swallow.tiff
> some pictures of the 28' Bolger designed Lobster BoatAlthough PCB is best know among amateurs for his inventiveness with small sailboats, I always thought he was at his best with powerboats for professional construction. Seeing this boat is looking at a capsule of New England history.
>Lovely boat.Very nice indeed.!!!
> Hello,
> group.
> File : /28' Bolger Lobsterboat/Picture 014s.JPG
> Uploaded by : hhetyson <hhetyson@...>
> Description : Another very nice picture....good bow-on angle..pity the day was so cloudy.
>http://groups.yahoo.com/group/bolger/files/28%27%20Bolger%20Lobsterboat/Picture%20014s.JPG
>http://help.yahoo.com/l/us/yahoo/groups/original/members/forms/general.htmlfiles
> Regards,
Hello everyone! I haven't posted for a while..but I thought you might like to see some pictures of the 28' Bolger designed Lobster Boat that my father built and launched in March 2009. Go to the files section in the Bolger group and you'll find a folder called 28' Bolger Lobsterboat with quite a few pictures in it. Just a note....My father built this boat from the complete set of plans published in Harold Payson's book; "Boat Modelling The Easy Way....A scratch Builder's Guide." Dad is currently building a Harry Bryan designed 21' "Handy Billy" launch for myMe,my partner and our 3 young children! --- OnFri, 25/6/10, bolger@yahoogroups.com<bolger@yahoogroups.com>wrote:
group.
group.
File : /28' Bolger Lobsterboat/Picture 011.jpg
Description : Stern view on a grey day.
http://groups.yahoo.com/group/bolger/files/28%27%20Bolger%20Lobsterboat/Picture%20011.jpg
group.
File : /28' Bolger Lobsterboat/Picture 009.jpg
Description : A nice view...almost a magazine cover shot!?
http://groups.yahoo.com/group/bolger/files/28%27%20Bolger%20Lobsterboat/Picture%20009.jpg
group.
File : /28' Bolger Lobsterboat/Picture 004.jpg
Description : At speed on a very calm day...This is a displacement hull so will only do about 10 Knots Max.55HP Yanmar 4cyl. Diesel. Uses about 1/2 US Gallon an hour at 7.5 Knots!
http://groups.yahoo.com/group/bolger/files/28%27%20Bolger%20Lobsterboat/Picture%20004.jpg
group.
File : /28' Bolger Lobsterboat/IMG_4882s.JPG
Description : On the Slip for bottom cleaning
http://groups.yahoo.com/group/bolger/files/28%27%20Bolger%20Lobsterboat/IMG_4882s.JPG
group.
File : /28' Bolger Lobsterboat/IMG_4681.JPG
Description : The Reubenios Nymphoss in use.
http://groups.yahoo.com/group/bolger/files/28%27%20Bolger%20Lobsterboat/IMG_4681.JPG
group.
File : /28' Bolger Lobsterboat/IMG_4669.JPG
Description : A Rueubo's Nympho cockle shell built from Payson's New instant boat book from the nymph plans...BUT... enlarged and stretched. Nearly 9' x 4'6" I think!
http://groups.yahoo.com/group/bolger/files/28%27%20Bolger%20Lobsterboat/IMG_4669.JPG
group.
File : /28' Bolger Lobsterboat/dfg.JPG
Description : moving fast for a displacement boat... about 10 knots
http://groups.yahoo.com/group/bolger/files/28%27%20Bolger%20Lobsterboat/dfg.JPG
group.
File : /28' Bolger Lobsterboat/Allison's Camera 001s.jpg
Description :
http://groups.yahoo.com/group/bolger/files/28%27%20Bolger%20Lobsterboat/Allison%27s%20Camera%20001s.jpg
group.
File : /28' Bolger Lobsterboat/Gryphon ..in the water at last!MTA].JPG
Description : In the water at last!
http://groups.yahoo.com/group/bolger/files/28%27%20Bolger%20Lobsterboat/Gryphon%20..in%20the%20water%20at%20last%21MTA%5D.JPG
group.
File : /28' Bolger Lobsterboat/Gryphon...launch.JPG
Description : launching
http://groups.yahoo.com/group/bolger/files/28%27%20Bolger%20Lobsterboat/Gryphon...launch.JPG
group.
File : /perspexmanual.pdf
Uploaded by : sunbearone <mhamill1@...>
Description : Perspex plastic use manual
http://groups.yahoo.com/group/bolger/files/perspexmanual.pdf
group.
File : /Gypsy/Bolger Gypsy.gif
Uploaded by : graeme19121984 <graeme19121984@...>
Description :
http://groups.yahoo.com/group/bolger/files/Gypsy/Bolger%20Gypsy.gif
>Thanks Nels. The motor is a 9.9 Yamaha high thrust. It is amazing and wonderful for this boat. Sometimes at the locks people think it is an electric it is so quiet. The larger prop makes for great braking also. I have been told that yamaha is a true high thrust with the appropriate gearing changes and not just the larger prop.
> Wow what a great photo!
> As a more mundane aside - what make of motor are you using and how do
> you like it?
> Happy New Year everyone.
> Nels
you like it?
> Hello,
> group.
> File : /houseboat # 481/2008070948.JPG
> Uploaded by : bysc2002 paulmclellan@...
> Description : Enjoying the Houseboat
http://groups.yahoo.com/group/bolger/files/houseboat%20%23%20481/2008070\
http://help.yahoo.com/l/us/yahoo/groups/original/members/forms/general.h\
tmlfiles
> Regards,
group.
Uploaded by : bysc2002 <paulmclellan@...>
http://groups.yahoo.com/group/bolger/files/houseboat%20%23%20481/2008070948.JPG
group.
File : /Bolger Catamarans/Sharpie-cat_23_6.gif
Uploaded by : lucasac78 <lucasac78@...>
Description :
http://groups.yahoo.com/group/bolger/files/Bolger%20Catamarans/Sharpie-cat_23_6.gif
http://help.yahoo.com/l/us/yahoo/groups/original/members/web/index.htmlfiles
group.
File : /Bolger Catamarans/Trashcat line drawing.jpg
Description :
http://groups.yahoo.com/group/bolger/files/Bolger%20Catamarans/Trashcat%20line%20drawing.jpg
group.
File : /Bolger Catamarans/Bolger_cruising_cat_as_in_Multihull_Voyaging.jpg
Description :
http://groups.yahoo.com/group/bolger/files/Bolger%20Catamarans/Bolger_cruising_cat_as_in_Multihull_Voyaging.jpg
group.
File : /Scott's Micro/micro.jpg
Uploaded by : sclimber11 <sclimber11@...>
Description : Google Sketchup drawing
http://groups.yahoo.com/group/bolger/files/Scott%27s%20Micro/micro.jpg
group.
File : /Scott's Micro/micro3.jpg
Description : Close up
http://groups.yahoo.com/group/bolger/files/Scott%27s%20Micro/micro3.jpg
group.
File : /William D Jochems Schooner/Bolger William D Jochems #639 Stability Curve.jpg
Description : Bolger William D Jochems #639 Stability Curve
http://groups.yahoo.com/group/bolger/files/William%20D%20Jochems%20Schooner/Bolger%20William%20D%20Jochems%20%23639%20Stability%20Curve.jpg
group.
File : /24-02.jpg
Uploaded by : hardystein2004 <hardystein2004@...>
Description : Large Bolger proa
http://groups.yahoo.com/group/bolger/files/24-02.jpg
Paul H.
> Hello,
> group.
> File : /Lego.doc
> Description : Favorite Sails: Constructing the Bolger 59 sq. ft.
Leg o' Mutton Sail from a PolySail Kit
>http://groups.yahoo.com/group/bolger/files/Lego.doc
>http://help.yahoo.com/help/us/groups/files
> Regards,
group.
File : /Lego.doc
Description : Favorite Sails: Constructing the Bolger 59 sq. ft. Leg o' Mutton Sail from a PolySail Kit
group.
File : /Roger Keyes MicroVoyage May 07/PALOMA CRUISING 2007 (2)-1.doc
Uploaded by : mannthree <johnmann@...>
Description : Roger's narrative of his voyage
http://groups.yahoo.com/group/bolger/files/Roger%20Keyes%20MicroVoyage%20May%2007/PALOMA%20CRUISING%202007%20%282%29-1.doc
group.
File : /Roger Keyes MicroVoyage May 07/Paloma Blanca.JPG
Description : Roger's Micro Palaoma Blanca resting
http://groups.yahoo.com/group/bolger/files/Roger%20Keyes%20MicroVoyage%20May%2007/Paloma%20Blanca.JPG
group.
File : /Birds Mouth Spars/birdie_2-0.xls
Uploaded by : sarkhori <gmcatee@...>
Description : Birds Mouth Spar Calculator (Excel)
http://groups.yahoo.com/group/bolger/files/Birds%20Mouth%20Spars/birdie_2-0.xls
group.
File : /Chebacco Raised Deck/Chebacco RD.jpg
Uploaded by : bh100014 <ben.ho@...>
Description : Chebacco Raised Deck
http://groups.yahoo.com/group/bolger/files/Chebacco%20Raised%20Deck/Chebacco%20RD.jpg
group.
File : /Rocks 'Surf'/Sarph_port.jpg
Uploaded by : r_taber_2000 <taber.rock@...>
Description : Sarph - port view
http://groups.yahoo.com/group/bolger/files/Rocks%20%27Surf%27/Sarph_port.jpg
> > Uploaded by : sharpie3444 <sharpie3444@y...>shop,but
> Oh no........not another builder who not only has an indoor
> what appears to be a ton of reading material for taking onesleisure
> in the moaning chair :-)).........on
> Seriously David, it is not nice to rub it in like that ;-
> the other hand,she does look very good and with summer slowlygetting
> closer you must be dying to launch her!more
> Do you intend on covering the "slot" with canvas or installing a
> rigid and lockable companionway hatch?completion!
> Thanks for posting some pictures and best of luck with her
>Poly tarp over the slot top this summer / maybe a removable hard top
> Sincerely,
> Peter Lenihan
and a stove before next winter, The water don't freeze down here (
West Arkansas ) but the people do.
Just finishing the sails. Have the spars, ballast, glassing and a
small amount of wood work left. Hope to be sailing by June.
> Uploaded by : sharpie3444 <sharpie3444@y...>Oh no........not another builder who not only has an indoor shop,but
what appears to be a ton of reading material for taking ones leisure
Seriously David, it is not nice to rub it in like that ;-).........on
the other hand,she does look very good and with summer slowly getting
Do you intend on covering the "slot" with canvas or installing a more
Thanks for posting some pictures and best of luck with her completion!
group.
File : /PICARA/Picara
Uploaded by : sharpie3444 <sharpie3444@...>
Description : Picara is in Bolger3.
http://groups.yahoo.com/group/bolger/files/PICARA/Picara
group.
File : /Tennessee/1920_runner.jpg
Uploaded by : jhbjap <boatbuilding@...>
Description : Sneakeasy? 1920 photo
http://groups.yahoo.com/group/bolger/files/Tennessee/1920_runner.jpg
> On Monday 30 December 2002 12:11 am, you wrote:is
> I was surprised to find this upload breaking into our files. This
> a moderated forum,and members are vetted. I suspect that ourmoderator is on
> a well deserved Christmas break. I also suspect that simplygirls2002 will
> not be a member vey much longer.And there I was thinking all along that all our file space had
> HJ
been taken up by the really good stuff(boats!).I hope that Gregg
really boots them in the nookies with some evil scrotum chomping chip
frying "return message".Yeah! that'll learn 'em ta mess with us nuts!
Go gittem Gregg!!!!
ARRRRgggg!!!!
Epoxy Pete
Besides the dissapointment of finding out that Erica wasn't a shapely Norse
double ender, but what appears to be a rather bluff in the bows Russian
design, I was surprised to find this upload breaking into our files. This is
a moderated forum,and members are vetted. I suspect that our moderator is on
a well deserved Christmas break. I also suspect that simplygirls 2002 will
I am a member of several other Yahoo groups, and this doesn't bode well at
all.
The extent of this illness just occured to me. When I as a healthy
> male, realized I was in fact dissapointed to find the picture of a
> beautiful woman instead of a boat name "Erica".
> My God what has happened to me.
> > Hello,
> > group.
> > File : /ERICA 6.jpg
> > Uploaded by : simplygirls2002 <simplygirls@h...>
> > Description :http://groups.yahoo.com/group/simplygirls2002/
> >http://groups.yahoo.com/group/bolger/files/ERICA%206.jpg
> > Regards,
> Hello,
> group.
> File : /ERICA 6.jpg
> Regards,
group.
File : /ERICA 6.jpg
Uploaded by : simplygirls2002 <simplygirls@...>
group.
File : /Mouser/mouser.jpg
Uploaded by : owlnmole <owlnmole@...>
Description : A picture of the original Mouser, then 15 years old, in Mississippi.
http://groups.yahoo.com/group/bolger/files/Mouser/mouser.jpg
group.
File : /Micro/Micro "Firefly"/boxplatform.JPG
Uploaded by : dnjost <djost@...>
Description : box/footwell
http://groups.yahoo.com/group/bolger/files/Micro/Micro%20%22Firefly%22/boxplatform.JPG
dnjost <djost@...>
group.
File : /Micro/Micro "Firefly"/portside.JPG
Description : side view firefly
http://groups.yahoo.com/group/bolger/files/Micro/Micro%20%22Firefly%22/portside.JPG
dnjost <djost@...>
group.
File : /"*.hul" Design Files & Hull Designer/injnprof.jpg
Uploaded by : steelcb <steelcb@...>
Description : Profile from hull designer
http://groups.yahoo.com/group/bolger/files/%22%2A.hul%22%20Design%20Files%20%26%20Hull%20Designer/injnprof.jpg
the photos section instead. Else go to Bolger2.
(is this one of my old shots?)
JB
Sent: Wednesday, December 12, 2001 10:26 PM
Subject: [bolger] New file uploaded to bolger
| Hello,
| group.
| File : /Windsprint/m_qnada.jpg
| Uploaded by : henrybunch <henryclann@...>
| Description : Way John Bell Built her
|http://groups.yahoo.com/group/bolger/files/Windsprint/m_qnada.jpg
| Regards,
| Bolger rules!!!
| - pls take "personals" off-list, stay on topic, and punctuate
group.
group.
File : /turtle1.jpg
Uploaded by :bysc@...
Description : IDAHO Like Bolger Boat
http://groups.yahoo.com/group/bolger/files/turtle1.jpg
bysc@...
group.
File : /Stone_Camel/stone_camel_construction_plan.jpg
Uploaded by :jmbell@...
Description : More Stone Camel
http://groups.yahoo.com/group/bolger/files/Stone_Camel/stone_camel_construction_plan.jpg
jmbell@...
group.
File : /Stone_Camel/stone_camel_sail_plan.jpg
Description : Stone Camel side view
http://groups.yahoo.com/group/bolger/files/Stone_Camel/stone_camel_sail_plan.jpg
jmbell@...
group.
File : /JBs AF4/af4_stern.jpg
Description : Stern on view of JB's AF4.
http://groups.yahoo.com/group/bolger/files/JBs%20AF4/af4_stern.jpg
jmbell@...
group.
File : /June Bug/botanybay.jpg
Uploaded by :wattleweedooseeds@...
Description : from old wreck to new ketch
http://groups.yahoo.com/group/bolger/files/June%20Bug/botanybay.jpg
group.
File : /Pirogue outriggers/sailrig3.jpg
Uploaded by :micwal_va@...
Description : ouriggers2
http://groups.yahoo.com/group/bolger/files/Pirogue%20outriggers/sailrig3.jpg
micwal_va@...
group.
File : /Pirogue outriggers/sailrig2.jpg
Description : outriggers1
http://groups.yahoo.com/group/bolger/files/Pirogue%20outriggers/sailrig2.jpg
micwal_va@...
Uploaded by :colcath@...
Description : MJ Shirley Valentine under sail
These photos are all prior to increased ballast and
addition of sponsons. More photos of Graham's boat,
pre- and post-sponsons, are available within
SquareBoats, athttp://www.ace.net.au/schooner/mj.htm
We've yet to put the building photos up.
Tim & Flying Tadpole
The Light Schooner Website
http://www.ace.net.au/schooner/index.htm
SquareBoats!http://www.ace.net.au/schooner/sbhome.htm
Bolger Boats netted!
http://www.ace.net.au/schooner/sites2.htm
All extensively updated April 2001
group.
File : /mj2.JPG
http://groups.yahoo.com/group/bolger/files/mj2.JPG
colcath@...
group.
File : /mj1.JPG
Description : Graham Cheers MJ "Shirley Valentine"
http://groups.yahoo.com/group/bolger/files/mj1.JPG
colcath@...
group.
File : /Messabouts/FernRidge.jpg
Uploaded by :jhkohnen@...
Description : Fern Ridge Lake (Oregon) Spring Messabout, May 19
http://groups.yahoo.com/group/bolger/files/Messabouts/FernRidge.jpg
jhkohnen@...
group.
Description : Fern Ridge (Oregon) Spring Messabout, May 19, 2001
jhkohnen@...
group.
File : /tortoise and nymph/n6.JPG
Description : another view
http://groups.yahoo.com/group/bolger/files/tortoise%20and%20nymph/n6.JPG
colcath@...
group.
File : /tortoise and nymph/n5.JPG
Description : n display
http://groups.yahoo.com/group/bolger/files/tortoise%20and%20nymph/n5.JPG
colcath@...
group.
File : /tortoise and nymph/nymph.JPG
Description : poor shot of Nymph on display at Leukaemia foundation swimmation, Ballina pool.
http://groups.yahoo.com/group/bolger/files/tortoise%20and%20nymph/nymph.JPG
colcath@...
group.
File : /tortoise and nymph/tort4.jpg
Description : builders daughter in water saying goodbye
http://groups.yahoo.com/group/bolger/files/tortoise%20and%20nymph/tort4.jpg
colcath@...
group.
File : /lenihan/Nymph & Tortoise
Description : small bolger boats
http://groups.yahoo.com/group/bolger/files/lenihan/Nymph%20%26%20Tortoise
colcath@...
group.
File : /Mike V's June Bug/mikeboat2.jpg
Uploaded by :mike_vacanti@...
Description : An interior shot of the boat showing the aft deck plate.
http://groups.yahoo.com/group/bolger/files/Mike%20V%27s%20June%20Bug/mikeboat2.jpg
mike_vacanti@...
group.
File : /Mike V's June Bug/mikeboat.jpg
Description : First sail with my 2 oldest kids and a friend. My little girl is "helping" to row the boat.
http://groups.yahoo.com/group/bolger/files/Mike%20V%27s%20June%20Bug/mikeboat.jpg
mike_vacanti@...
group.
File : /Micro/micro chris burden.jpg
Uploaded by :flexitub@...
Description : Chris Burden Micros
http://groups.yahoo.com/group/bolger/files/Micro/micro%20chris%20burden.jpg
flexitub@...
group.
File : /USCG_Safety_Standards_for_Backyard_Boat_Builders.pdf
Description : Document outlining USCG standards for home built boats, including max HP, floatation, and HINs.
http://groups.yahoo.com/group/bolger/files/USCG_Safety_Standards_for_Backyard_Boat_Builders.pdf
jmbell@...
group.
File : /sloop.JPG
Uploaded by :thedemings@...
Description : Freindship Sloop
http://groups.yahoo.com/group/bolger/files/sloop.JPG
thedemings@...
group.
File : /Bolger-Inspired Proas/dagger_trailer.jpg
Uploaded by :dadadata@...
Description : John Harris' proa for Dale Dagger
http://groups.yahoo.com/group/bolger/files/Bolger-Inspired+Proas/dagger_trailer.jpg
dadadata@...
group.
File : /Bolger-Inspired Proas/mbuli_05_beach.JPG
Description : Preparing to push off.
http://groups.yahoo.com/group/bolger/files/Bolger-Inspired+Proas/mbuli_05_beach.JPG
dadadata@...
group.
File : /Bolger-Inspired Proas/mbuli_06_launch.JPG
Description : 2-11-2001
http://groups.yahoo.com/group/bolger/files/Bolger-Inspired+Proas/mbuli_06_launch.JPG
dadadata@...
group.
File : /folding schooner in australia/foldschoonerlatch2.gif
Description : ditto page 2of 2
http://groups.yahoo.com/group/bolger/files/folding+schooner+in+australia/foldschoonerlatch2.gif
group.
File : /folding schooner in australia/foldschoonerlatch1.gif
Description : a suggestion for worried latch builders
http://groups.yahoo.com/group/bolger/files/folding+schooner+in+australia/foldschoonerlatch1.gif
group.
File : /folding schooner in australia/wattleweedoowaterworks.gif
Description : effective recycling of an old windmill
http://groups.yahoo.com/group/bolger/files/folding+schooner+in+australia/wattleweedoowaterworks.gif
group.
File : /folding schooner in australia/waltzingmatilda4.gif
Description : two halves make a whole. vrew prepares for maiden voyage
http://groups.yahoo.com/group/bolger/files/folding+schooner+in+australia/waltzingmatilda4.gif
group.
File : /folding schooner in australia/stationcreek1.gif
Description : when the rains come. This creek becomes lake raeside and flows for 250 kms into the desert. It has been followed to its end only once in written history.
http://groups.yahoo.com/group/bolger/files/folding+schooner+in+australia/stationcreek1.gif
To learn more about eGroups file sharing, please visit
group.
File : /folding schooner in australia/redlake2.gif
Description : Red lake from our highest mountain
http://groups.yahoo.com/group/bolger/files/folding+schooner+in+australia/redlake2.gif
group.
File : /folding schooner in australia/redlake1.gif
Description : winter sailing on Red Lake
http://groups.yahoo.com/group/bolger/files/folding+schooner+in+australia/redlake1.gif
What a lovely photo!Tell us more,preferably with words and more
pictures!!!Simply beautiful!!
Peter Lenihan,grateful for this time on the computer and the chance
to see such an inspiring picture,in the dead of winter,on the shores
of the St.Lawrence.............
--- In bolger@y..., <bolger@y...> wrote:
> Hello,
> group.
> File : /~lwf0000.jpg
> Uploaded by : fritzdfk@m...
> Description : under sail & more
>http://groups.yahoo.com/group/bolger/files/%7Elwf0000.jpg
> Regards,
> fritzdfk@m...
group.
File : /Skillygalee/under sail.jpg
Uploaded by :fritzdfk@...
Description :
http://groups.yahoo.com/group/bolger/files/Skillygalee/under+sail.jpg
fritzdfk@...
group.
fritzdfk@...
group.
File : /walyzingmatilda2.gif
Description : this is what a shed should look like
http://groups.yahoo.com/group/bolger/files/walyzingmatilda2.gif
group.
File : /waltzingmatilda1.gif
Description : the start of something beautiful
http://groups.yahoo.com/group/bolger/files/waltzingmatilda1.gif
group.
File : /lenihan/Trailer.jpg
Uploaded by :ellengaest@...
Description : Cheap and nasty trailer with craddle bolted to trailer.
http://www.egroups.com/files/bolger/lenihan/Trailer%2Ejpg
http://www.egroups.com/help/files.html
ellengaest@...
group.
File : /lenihan/!sleighr.jpg
Description : wintertime fun!!!!
http://www.egroups.com/files/bolger/lenihan/%21sleighr%2Ejpg
ellengaest@...
group.
File : /lenihan/!sleighr.jp0
Description : the advantages of a craddle!
http://www.egroups.com/files/bolger/lenihan/%21sleighr%2Ejp0
ellengaest@...
Michael Surface
>From: <bolger@egroups.com>_________________________________________________________________
>Reply-To:bolger@egroups.com
>Date: 3 Jan 2001 20:31:00 -0000
>Hello,
>group.
> File : /lenihan2/!elver1.jpg
> Description :
>http://www.egroups.com/files/bolger/lenihan2/%21elver1%2Ejpg
>Regards,
>ellengaest@...
Get your FREE download of MSN Explorer athttp://explorer.msn.com
group.
File : /lenihan2/!elver4.jpg
Description :
http://www.egroups.com/files/bolger/lenihan2/%21elver4%2Ejpg
ellengaest@...
group.
File : /lenihan2/!elver3.jpg
Description :
http://www.egroups.com/files/bolger/lenihan2/%21elver3%2Ejpg
ellengaest@...
group.
Description :
ellengaest@...
group.
File : /!surf5.jpg
Description :
http://www.egroups.com/files/bolger/%21surf5%2Ejpg
ellengaest@...
group.
File : /!surf4.jpg
Description :
http://www.egroups.com/files/bolger/%21surf4%2Ejpg
ellengaest@...
group.
File : /!surf3.jpg
Description :
http://www.egroups.com/files/bolger/%21surf3%2Ejpg
ellengaest@...
group.
File : /!surf2.jpg
Description :
http://www.egroups.com/files/bolger/%21surf2%2Ejpg
ellengaest@...
group.
File : /Hull Identification Numbers/HIN information.pdf
Uploaded by :djost@...
Description : Hull Identification Numbers
http://www.egroups.com/files/bolger/Hull+Identification+Numbers/HIN+information%2Epdf
djost@...
I'd say you're already doing more penance that you deserve :).
Larry
in Talent, Oregon where my wife insists that I should be thinking of skiing
instead of sailing.
<snip> Sincerely,
> Peter Lenihan,contemplating other options for a suitable
> penance,while the wind howls at 45km/hour in -13Celsius
> temperatures,on the banks of the St.Lawrence.......
Eastern Standard ,bolger@egroups.comwrites:>
http://www.egroups.com/files/bolger/Skimmer+Sans+Motor/00000049%2Ejpg
Boy do you ever look ridiculous, tsunatra, rowing that flowerbox!!!
I bet it was such fun. It is amazing what pleasure grown men can get from
such silly things. :-) :-) :-) :-) :-) :-) :-) :-) :-) :-)
Thanks for the pic. Have you ever looked at Bob Taylor's Skimmer?
<A HREF="http://members.aol.com/rtaylor137/stefspg.html">stefpage</A> down
at the bottom
This page: <A HREF="http://members.aol.com/rtaylor137/bobspg.html">Bobspage
</A> shows his Piragua, one of about 5 he's built.
Cheers and Merry Christmas/Don Carron
group.
File : /Skimmer Sans Motor/00000049.jpg
Uploaded by :tsunatra@...
Description : A Wheelbarrow With Oars
tsunatra@...
Thanks!To reply to some of your questions;the boomkin simply
slides through a square hole cut into a plywood knee secured to the
bulkhead.A pin is then inserted just aft of the knee into the boomkin
to prevent it from sliding back into the boat.The fid is simply a
plank,laid athwartships immediately aft of the mast and dropped into
a set of notches which must be cut in the beefed up section of the
sheer clamp at that point.If you click on the picture titled HEAD,you
will get a clear idea of what I am attempting to describe.
Until I have done suitable penance,like writing 1000 times"I will
not attempt to upload pictures to the Bolger group until I learn how
to do it right",no further pictures will be posted.Sorry.
Regarding the interior;it is not strip-planked.Instead,I
installed a number of vertical cleets on the inside of the hull and
proceeded to lay a 1/4" X 1 3/4" clear pine ceiling to knock off some
of the harshness of the bare plywood panel.
You're more then welcome to come up to Montreal if all that cold
is starting to get to you down in Texas!
--- Inbolger@egroups.com, "Roger Peterson" <GANGSTERFISH@w...> wrote:
> --- Inbolger@egroups.com, <bolger@egroups.com> wrote:
> > Hello,
> > group.
> > File : /lenihan/Head.jpg
> > Uploaded by : ellengaest@b...
> > Description :
> >http://www.egroups.com/files/bolger/lenihan/Head%2Ejpg
> > Regards,
> > ellengaest@b...
> Peter,
> What a nice boat!!!
> I was wondering, did you strip plank the "inside" of your Micro?
Also, I am getting ready to build my Micro and while looking at the
plans, I found it difficult to understand how the boomkin attaches to
the bulkhead inside the boat. Would you happen to have a picture?
> Come to think of it, I don't understand the "fid" at the main mast
partners either. It would be nice to see a micro in real life. I e-
mailed CSB to find out if their was a Micro in the Dallas/Ft.Worth
area but got no reply. It's sad, CSB does'nt seem to eager to answer
questions or offer much help.
> Thanks in advance,
> Roger Peterson
> 45 degrees and freezing to death in Ft.Worth TX
>Peter,
> Hello,
> group.
> Description :
> Regards,
> ellengaest@b...
What a nice boat!!!
I was wondering, did you strip plank the "inside" of your Micro? Also, I am getting ready to build my Micro and while looking at the plans, I found it difficult to understand how the boomkin attaches to the bulkhead inside the boat. Would you happen to have a picture?
Come to think of it, I don't understand the "fid" at the main mast partners either. It would be nice to see a micro in real life. I e-mailed CSB to find out if their was a Micro in the Dallas/Ft.Worth area but got no reply. It's sad, CSB does'nt seem to eager to answer questions or offer much help.
Thanks in advance,
Roger Peterson
too. ;-)
JB in snowy, icy Kennesaw, GA
To: <bolger@egroups.com>
Sent: Friday, December 22, 2000 10:04 AM
| Hello,
| group.
| File : /lenihan/Interior.jpg
| Description : the reason I like my MICRO so much!
|http://www.egroups.com/files/bolger/lenihan/Interior%2Ejpg
| Regards,
|ellengaest@...
| Bolger rules!!!
| - no cursing, flaming, trolling, or spamming
| - no flogging dead horses
| - add something: take "thanks!" and "ditto!" posts off-list.
| - stay on topic and punctuate
group.
File : /Proa/jch_proa_1100.jpg
Description : Overall view of John's Proa
http://www.egroups.com/files/bolger/Proa/jch_proa_1100%2Ejpg
dadadata@...
group.
File : /Proa/craig-in-proa.jpg
Description : John Harris Proa nearing completion. Mannikin shows scale.
http://www.egroups.com/files/bolger/Proa/craig-in-proa%2Ejpg
dadadata@...
group.
ellengaest@...
group.
File : /lenihan/!compani.jpg
Description :
http://www.egroups.com/files/bolger/lenihan/%21compani%2Ejpg
ellengaest@...
group.
File : /lenihan/Stern.jpg
Description :
http://www.egroups.com/files/bolger/lenihan/Stern%2Ejpg
ellengaest@...
group.
Description :
ellengaest@...
group.
File : /lenihan/Profil.jpg
Description :
http://www.egroups.com/files/bolger/lenihan/Profil%2Ejpg
ellengaest@...
group.
File : /lenihan/Bateau.jpg
Description : micro pictures
http://www.egroups.com/files/bolger/lenihan/Bateau%2Ejpg
ellengaest@...
get together a crew of six or eight stout fellows (at least) every
time it breezes up, you might want some ballast. How about a 1" or
so thick steel plate forming a shoe along the center of the bottom?
Scrap steel is pretty cheap, bulletproof (literally) for grouding,
and good ballast. Full length would be about 5000# if it were 12"
wide. OTOH, an unballasted version with enough crew would sure be a
blast, if impractical. Sort of like a schooner-rigged A-scow.
--- Inbolger@egroups.com, David Ryan <david@c...> wrote:
> >> Description : Dreaming of a big sharpie!
> >Not too different from Reuel Parker's Terrapin!
> Strongly influence by Parker's design, but I think using the LS as
> spring board give at least as pretty a hull with less figger'in out.
Parker doesn't have specs for his Terrapin 44 online, but he does
have the 34' on his site. She comes in at just under 14,000 pounds.
She's also a much fuller boat, so I think the below are within an
order of magnitute.
>Based on the weight of the LSME, I've been roughing the weight as follow:CRUMBLING EMPIRE PRODUCTIONS
>LS^2 hull #4000
>Interior joinery and appointments #2000
>Deckhouses #1000
>Spars, Sails, etc #2000
>Ballast #4000
>TOTAL 7.5 Tons
>These figures are not arbitrary, but they are total uneducated. I
>wonder how these compare with figures for the Terrapin 44.
>RE:Deckhouse rollover factor.
>Again, by eyeball only, I don't think they'd be much of a factor in
>tipping the boat over. OTH, if she did get knocked down, I think they
>could only help to keep her from going any further once they hit the
>water.
>Strictly speaking out of my ass, I'm much more concerned about the
>rigging's effect on stability. You don't have to tip the LSME very
>far before the weight of her spars, sails, and rigging starts to take
>her right over.
>YIBB,
>David
>>Cabins look nice. How much will they increase the
>>weight load above the waterline for roolover factors?
>>---bolger@egroups.comwrote:
>>> Hello,
>>> that
>>> bolger
>>> group.
>>> File : /LSME Photos/02LSx2.gif
>>> Uploaded by :david@...
>>> Description : Redraw with a raise house over
>>> galley
>>http://www.egroups.com/files/bolger/LSME+Photos/02LSx2%2Egif
>>> visit
>>> Regards,
>>>david@...
>>Do You Yahoo!?
>>Yahoo! Messenger - Talk while you surf! It's FREE.
>>http://im.yahoo.com/
>>Bolger rules!!!
>>- no cursing
>>- stay on topic
>>- use punctuation
>>- add some content: send "thanks!" and "ditto!" posts off-list.
>134 W.26th St. 12th Floor
>New York, NY 10001
>(212) 243-1636
>- no cursing
>- stay on topic
>- use punctuation
New York, NY 10001
(212) 243-1636
> Hello,
> that
> bolger
> group.
> galley
> visit
> Regards,
>david@...
Do You Yahoo!?
group.
Description : Redraw with a raise house over galley
david@...
The hull shape is essentially Black Skimmer. Interior is 4 berths,
about 5' headroom. At least one hull was built; I saw it advertised
for sale 10 or 15 years ago.
Displacement is 15,000 lbs (BIG SHARPIE!). Sail area is 708 ft^2
plus 225 ft^2 in the main staysail (take friends along for the ride).
It looks like a very 'shippy' boat to me, a quality shared by many of
the thin-water boats in Chapelle. I was musing just the other day
about how it would be a great boat to take to the schooner races
after the bank makes a mistake and fills my account to the 'FULL'
mark with someone else's money.
>Bolger has done a design very like the LS squared. WoodenboatCRUMBLING EMPIRE PRODUCTIONS
>ran an article about a "shorey" (sharpie dory) PCB designed for
>Mait Edy. Beautiful boat, but Phil's original concept was for a
>sharpie schooner. The article has a profile view.
>Vance
>- no cursing
>- stay on topic
>- use punctuation
New York, NY 10001
(212) 243-1636
> >> Description : Dreaming of a big sharpie!Bolger has done a design very like the LS squared. Woodenboat
Vance
library can get any of PCB's book on interlibrary loan. In the
meantime, what can you me?
>Speaking of big sharpies, I do assume you are familiar with Lion'sCRUMBLING EMPIRE PRODUCTIONS
>Paw. See 30 Odd Boats, page 92.
>PHV
>- no cursing
>- stay on topic
>- use punctuation
New York, NY 10001
(212) 243-1636
PHV
> Description : Dreaming of a big sharpie!Not too different from Reuel Parker's Terrapin!
>> Description : Dreaming of a big sharpie!Strongly influence by Parker's design, but I think using the LS as a
It's probably silly to carry the fineness of the Light Scooner so far
aft on a 47 foot hull. The Break-down Schooner, as well as the
Terrapin, suggest that a little more fullness in the forward part of
the middle is worthwhile. Still, there's something about those
lines...
I did some quick calculations based on the LSME:
20 sheets of 3/4" ply $500
12 gallons resin $500
fabric, funny powders, etc $500
400 feet of 2x4s $160
12 gallons of porch paint $375
A used genoa for main and jib $200
A used jib for foresail $75
300 feet of 3/4 inch polypro $100
Subtotal $2410
X factor 100%
Grand total $4820
I can think of a lot worse ways to spend 5K
New York, NY 10001
(212) 243-1636
group.
File : /LSME Photos/LSx2.gif
http://www.egroups.com/files/bolger/LSME+Photos/LSx2%2Egif
david@...
group.
File : /606ii.gif
Uploaded by :shansen@...
Description : Bolger 18 ft. Cabin Clam Skiff #606 II
http://www.egroups.com/files/bolger/606ii%2Egif
shansen@...
group.
File : /Watervan MAIB/watervan.txt
Uploaded by :chuck@...
Description : Text of MAIB article
http://www.egroups.com/files/bolger/Watervan+MAIB/watervan%2Etxt
chuck@...
Star Trek, TOS, shuttlecraft anyone?
Richard Spelling,http://www.spellingbusiness.com/boats
From the muddy waters of Oklahoma
Sent: Thursday, October 26, 2000 1:07 PM
> Hello,
> group.
> File : /Watervan/WaterVanSide.jpg
> Description :
>http://www.egroups.com/files/bolger/Watervan/WaterVanSide%2Ejpg
> Regards,
>dadadata@...
> - no cursing
> - stay on topic
> - use punctuation
it came in just after I posted.
Sorry, Don
with the crew all up front,
hence the unusual amt of water bunched up under the bow
and the slightly nose-down attitude.
Jeff Gilbert
Sent: Friday, October 27, 2000 4:44 AM
Subject: Re: [bolger] New file uploaded to bolger
> Hello,
> group.
> Description :
> Regards,
>dadadata@...
> - no cursing
> - stay on topic
> - use punctuation
- no cursing
- stay on topic
- use punctuation
group.
Description :
dadadata@...
You shold have seen the way they danced and crackled.
>Those overhead wires look pretty scary. Hope they're not close.CRUMBLING EMPIRE PRODUCTIONS
>> Hello,
>> group.
>> File : /LSME Photos/lawnsailing.jpg
>> Uploaded by : david@c...
>> Description : Jib, Foresail, and Main hoisted on the lawn
>>http://www.egroups.com/files/bolger/LSME+Photos/lawnsailing%2Ejpg
>> Regards,
>> david@c...
>- no cursing
>- stay on topic
>- use punctuation
New York, NY 10001
(212) 247-0296
> Hello,
> group.
> Regards,
> david@c...
Jim
> -----Original Message-----http://www.egroups.com/files/bolger/LSME+Photos/lawnsailing%2Ejpg
> From:bolger@egroups.com[mailto:bolger@egroups.com]
> Sent: Wednesday, September 20, 2000 4:20 PM
> Hello,
> group.
david@...
- no cursing
- stay on topic
- use punctuation
group.
david@...
