Re: [bolger] Happy Discovery
Vince
Where do you get your carbide rollers?
> It makes a good surface for
> using a carbide roller cutter and since it is masonite coated with a
> very glossy white plastic on one side it is easy to use a felt tipped
> pen to make cutting guide lines which show through the glass tape or
> cloth. I had a little left over.
_ _ _ _ _
% Harrywelshman@...
Also makes a pretty good whiteboard for your office or your kid's room.
> -----Original Message-----
> From: Vince Chew [mailto:vachew@...]
> Sent: Thursday, September 28, 2000 6:03 PM
> To:bolger@egroups.com
> Subject: [bolger] Re: Happy Discovery
> James,
> If you're asking about the tileboard, as I recall, it was stacked in a
> bin near the paneling and plywood. I think it only had a barcode
> sticker. The bin label was "tileboard". I believe it is sold for a
> cheap shower/tub surround. It comes both plain and with an embossed
> fake tile pattern. I used the plain, of course. If you're referring to
> the peel-ply, it is sold by the yard at all suppliers of glass and
> epoxy.
> Vince
> --- Inbolger@egroups.com, "james fuller" <jamar@z...> wrote:
> > Hi,
> > Is there any brand name on the product?
> > Thanks
> > James fuller
> - no cursing
> - stay on topic
> - use punctuation
James,
epoxy.
Vince
> Hi,
> Thanks
> James fuller
Hi,
Thanks
James fuller
To: <bolger@egroups.com>
Sent: Wednesday, September 27, 2000 6:13 PM
Subject: [bolger] Happy Discovery
> Fellow Ply Splicers,
> When I began my project, I bought a 4' X 8' sheet of 1 / 8 " white
> tileboard at Home Depot (about $9 a sheet). I got it to cover the work
> table where I cut my glass tape and cloth. It makes a good surface for
> Then I made a happy discovery. Epoxy absolutely does not adhere
> to the glossy white plastic coating. Now when I tape-splice sheets of
> plywood, I use a strip of peel-ply next to the wet out tape. Next comes
> a piece of tileboard with the plastic coating facing the peel-ply. then
> comes my clamping board.
> Both the strip of peel-ply and the piece of tile board can be used
> over and over. The first time peel-ply is used, the epoxy wets through
> and cures on the outer surface (the one that is away from the wet out
> tape) but none stays on the inner surface. When the peel-ply is
> removed, the joint is left with a very smooth matte finish and no
> sanding is required (provided the plywood was dished out the correct
> amount for the thickness of tape used). Each time I reuse the strip of
> peel-ply, I make sure to place the same inner surface, the one which is
> free of cured epoxy, against the splice. My joints are now much
> smoother and more uniform than when I was using 4mil polyethylene
> against the splice.
> Vince Chew
> - no cursing
> - stay on topic
> - use punctuation
against the splice.
Vince Chew
