Re: [bolger] Tile Board - MY Epoxy Sticks to it!
Richard, thanks, I'll give the heat a try...
Don Hodges
To: <bolger@egroups.com>
Sent: Friday, September 29, 2000 8:35 PM
Subject: Re: [bolger] Tile Board - MY Epoxy Sticks to it!
> Use a heat gun to heat up the tile board, pull the edge up with a pair of
> pliers. Work your over the rest of the board, heating the edge and pulling
> it off.
Vince,
I'm glad it's working for you - I was not knocking your recommendation, just
a heads up to others to experiment a bit before committing. I'm using
Fiberglass Coatings Inc. from St Petersburg FL. It is very touchy to go off
quickly if mixed over three or four oz. at a time in our 85+ degree weather.
If my ply was coated all over, I could probably just soak the masonite
backing off. I was really surprised at the bond, even a spilled drop of
epoxy will pull the white facing off locally. I'm going to try a 32 grit
belt sander when I really get ready to finish this joint. Right now I'm
still tabbing on the cabin sides.
Don Hodges
Sent: Friday, September 29, 2000 8:21 PM
Subject: [bolger] Re: Tile Board - MY Epoxy Sticks to it!
> Donald,
> It would appear that the common wisdom that "epoxy is epoxy" isn't
> always true after all. I am using Raka. I have tried glueing tileboard
> pieces to each other both with straight epoxy and with thickened. In
> every case, it did not adhere at all to the glossy white side. It did
> stick very well to the brown masonite side. I have made about 24
> splices using tileboard with peel-ply. I'm sorry my "tip" caused you
> extra work. What brand were you using?
> Vince
> --- Inbolger@egroups.com, "Donald Hodges" <dhodges@w...> wrote:
> > All,
> > I thought the tile board sounded great, and having one last structural
> > splice to make, I decided to try it. I didn't have any peel ply, but
what
> > the heck, I don't mind sanding one joint - no waxed paper squishing
around,
> > great idea.
> > Well, my hot-weather epoxy LOVES it - now I have 1/8 of masonite to sand
off
> > in addition to the excess epoxy, and it is BONDED. I tried to lift the
tile
> > board off with a wide chisel and lifted off one ply of wood instead.
> > Try before you commit! Lesson learned again...
> > Don Hodges, fitted the cabin side panels today (splice was for the cabin
aft
> > panel)
> - no cursing
> - stay on topic
> - use punctuation
it off.
Sent: Friday, September 29, 2000 7:47 PM
Subject: [bolger] Tile Board - MY Epoxy Sticks to it!
> All,
> splice to make, I decided to try it. I didn't have any peel ply, but what
around,
> great idea.
off
tile
aft
> panel)
> - no cursing
> - stay on topic
> - use punctuation
Donald,
Vince
> All,
> the heck, I don't mind sanding one joint - no waxed paper squishing around,
> great idea.
> Well, my hot-weather epoxy LOVES it - now I have 1/8 of masonite to sand off
> in addition to the excess epoxy, and it is BONDED. I tried to lift the tile
> Don Hodges, fitted the cabin side panels today (splice was for the cabin aft
> panel)
All,
great idea.
panel)
