Re: [bolger] Re: paint for epoxy
System Three has a paint system for their epoxy, but it's more expensive
than the epoxy itself. I think I've settled on Valspar Duramax Gloss Enamel
for my Light Schooner. It's great paint and has no alkyds that can react
with the epoxy.
____________________________________________________________________________
__
Human beings can always be counted upon to assert, with vigor, their
God-given right to be stupid.
-Dean Koontz
with the epoxy.
__
-Dean Koontz
To: <bolger@egroups.com>
Sent: Wednesday, October 04, 2000 12:01 PM
Subject: [bolger] Re: paint for epoxy
> Richard,
> I can't remember what kind of boat you're going to build. If it's
> a pretty serious investment in time, by all means take great care
> with the finish. If it's a simple boat, I wouldn't spend much time
> finishing her. Be sure to spend most of your time sanding, not
> painting.
> I've had good luck with all the standard yacht enamels on boats
> finished with epoxy or polyester. Also the single-part polyurethanes,
> such as Interlux Brightsides, have performed beautifully. They work
> well on plain wood, as well.
> A number of years ago, I helped a friend paint his Catalina 27
> with Awlgrip 2-part polyurethane. What a pain! It looked great when
> we finished, but I think a single-part paint would have worked jus as
> well. We ended up with a good, 2' paint job. It looked sprayed from
> that distance, or farther. Closer, we could pick out some brush marks
> and dull spots. Four coats of primer and 2 of finish did the trick.
> I think the key to painting epoxy is to wash the hull with a good
> detergent, to get rid of any amine blush. Then start sanding it,
> starting with 80-grit, moving to 100, 120, then finishing in the
> upper 100's. Then get the recommended primer for the finish paint.
> Wipe the whole hull down with acetone, and change paper towels often.
> Then put the primer on. Sanding the first coat almost all the way
> off. Put a second coat of primer on, then sand again. NOW you're
> ready for the final coat. I've never had any trouble painting epoxy
> or polyester. All the paint types have stuck just fine, and held up
> well.
> I built a tortured plywood kayak for a friend about 8 years ago.
> We glassed the hull with epoxy resin, and painted her with a single-
> part polyurethane, with the appropriate primer. This paint job stayed
> on through years of being dragged across launch ramps, sand, and a
> few rocky beaches, and thrown up on countless roof racks. It was
> stored outside until a gutter loaded with wet dirt, acorns, and a
> surprising number of sprouting trees fell off a house and crushed
> her. The hull was scraped up, but no worse than a gelcoated boat.
> I'd go for a better paint job on a Micro, but use latex on a skiff.
> Take care,
> Pete Reynolds
> --- Inbolger@egroups.com, "Richard Spelling" <richard@s...> wrote:
> > Not to start a new thread, I know 100% acrylic will stick to epoxy.
> I even have 6 gallons that I picked up at a garage sale.. But it's
> grey, and I want RED!
> > Anyway, for my new boat I'm thinking I should splurg and go with
> one of the expensive boat paints.
> > There was a thread here awhile back where someone mentioned
> awlgrip, or maybe interlux, and a special primer for epoxy? One of
> these manufacturers even has a "epoxy system" for painting epoxy.
> Anyone remember who that was?
> > anyone? anyone? anyone?
> > Richard Spelling,http://www.spellingbusiness.com/boats
> > From the muddy waters of Oklahoma
> - no cursing
> - stay on topic
> - use punctuation
--- Inbolger@egroups.com, "Vance Cowan" <vcgraphics@t...>
Vance
http://home.att.net/~DaveCarnell/articles.html
> Oops, sorry, this link used to work but is refusing now.Sloppy pasting; this is correct
> Vance
Vance
Further thoughts on paint: there's a difference between merely dry
paint and fully cured, hardened paint. I painted my first boat (a
Windsprint) with oil-based porch paint, and in the month after
application, if I dragged it over anything rough, the paint would
tear off in long stripes or sheets. But after a full winter and
spring outside, upsidedown in the yard, it really got tough, and over
the same abrasive surfaces would only get nicks and thin scratches.
Ditto for my Gypsy this summer. I was in a terrible hurry to finish
her. Painted her in the two or three days just prior to launch, with
the last coat going on as the boat was cartopped ready for our
vacation. Bad move -- it dried but never really cured. Also, the week
of our vacation ranged between humid and rainy. The paint came off
wholesale from the bottom as it got dragged over sand flats. It
blistered wherever rainwater collected inside. Back home, I sanded
and painted all over -- and with several good dry weeks in the sun,
the same paint seems much harder. (Sadly, being a landlocked mountain
dweller, I haven't had the chance to drag her back over the sand
flats again and out into the sea, but that'll be the big test.)
Am I just imagining this? Maybe. But to be on the safe side -- give
it a l-o-n-g time to dry and bake.
All best,
Garth
All best,
Garth
Vance
..I would read what Dave
Vance
> Carnell has to say at
--- Inbolger@egroups.com, "David Jost" <djost@m...> wrote:
I'm just an observer, no hands on experience, but if I had
questions about painting a Bolger boat I would read what Dave
This reinforces David's views and then some.
Vance
> Dear group,of
> I painted my Diablo with acrylic latex primer and then a coat of
> Acrylic latex gloss paint (white). So far it has survived 5 years
> being stored outside in New Englands weather extremes withno signs of
> paint degradation. I highly recommend this method and amplanning on
> doing the same with Micro.<cut>
Vance
Dear group,
Acrylic latex gloss paint (white). So far it has survived 5 years of
being stored outside in New Englands weather extremes with no signs of
paint degradation. I highly recommend this method and am planning on
The biggest difference between cheap paint and expensive paint
seems to be the flowability and ease of application. I have used
Petit's gloss enamel on a number of fiberglass boats and have been very
satisfied with the results. Not so with Sears Acrylic trim paint.
Stay away from it. It looks terrible.
Richard,
painting.
well.
Take care,
Pete Reynolds
painting.
well.
Take care,
Pete Reynolds
The Interlux system is very good (and the only high-end marine paint I have
used), but you must adhere to the manufacturer's instructions. As I recall,
it came with an audio cassette of instructions back in 1995.
From experience: Do not apply the 2-part topcoat outdoors if there is any
chance of moisture (dew, for instance) getting on it. It will cure "dull"
(worse than flat) and you will have re-sand the entire surface and recoat.
I painted a 30-foot fiberglass sailboat with it - got carried away sanding
and started the topcoat about 2 PM. The dew fell about 5:30, and that's
when I got the experience.
It's a great paint once cured, but not very "repairable". My later high-end
projects (boats for sale or deemed worth keeping in salable condition) were
done with Interlux Brightsides one-part polyurethane (about 80 percent of
the properties for 40-50 percent of the cost and effort). Good enough for
me.
Don Hodges
me.
Don Hodges
My story reads almost like this one, but it was Interlux Brightside
Primer over System Three Epoxy that never dried. After lots of
sanding (I second the root canal analogy), Interlux 404/414 worked
fine. Also used Interlux Brightside as a top coat.
Ralph
Ralph
--- Inbolger@egroups.com, "Mike Vacanti" <mike_vacanti@h...> wrote:
> I would second the recommendation for Interlux 404/414 epoxy primer.
> I
> tried twice to paint over West Sysytems epoxy with West Marine
store
> brand oil base enamel primer. The primer never dried properly even
> after several weeks of midsummer weather. I ended up sanding all
> oil base primer off (twice, as much fun as do it youself root
canal)
> and applied a coat of the Interlux 404/414. It dried nice and hard
> while still being easy to sand. For the topcoat I used Interlux
> Brightside 1 part polyurethane enamel. It also dried nice and hard
> and
> has an attractive glossy finish. Neither of these paints is
> particularly inexpensive.
> Mike
I called Interlux on their 800 number and talked to a tech guy that
told me what type of primer to use...the number was on a brochure that I picked
up in West Marine..... I will see if I can find it some where in my " Boat
Library"
Chris Flynn
Flynn's Folly
_/)
----- Original Message -----From:Richard SpellingSent:Tuesday, October 03, 2000 1:43 PMSubject:Re: [bolger] paint for epoxythier webpage shows several primers, but none with the word "epoxy" in the name...----- Original Message -----From:chrisSent:Tuesday, October 03, 2000 12:43 PMSubject:Re: [bolger] paint for epoxyInterlux Has an Epoxy primer for covering Epoxy before putting the finish coat on.... I used it on My Bobcat .... It is expensive and does fill small indentations ... also sands great before putting on a finish coat.....I got it at West Marine... but I am sure that any Marine store that carries Interlux could get it...Chris FlynnFlynn's Folly_/)~~~~~~~~~~~~~`----- Original Message -----From:Richard SpellingSent:Tuesday, October 03, 2000 12:15 PMSubject:[bolger] paint for epoxyNot to start a new thread, I know 100% acrylic will stick to epoxy. I even have 6 gallons that I picked up at a garage sale.. But it's grey, and I want RED!Anyway, for my new boat I'm thinking I should splurg and go with one of the expensive boat paints.There was a thread here awhile back where someone mentioned awlgrip, or maybe interlux, and a special primer for epoxy? One of these manufacturers even has a "epoxy system" for painting epoxy. Anyone remember who that was?anyone? anyone? anyone?
- no cursing
- stay on topic
- use punctuation
- no cursing
- stay on topic
- use punctuation
- no cursing
- stay on topic
- use punctuation
I
tried twice to paint over West Sysytems epoxy with West Marine store
after several weeks of midsummer weather. I ended up sanding all the
oil base primer off (twice, as much fun as do it youself root canal)
Mike
I
Mike
--- Inbolger@egroups.com, "Catboater " <catboater@h...> wrote:
> Having worked in a West Marine store for a number of years I would
> suggest that a primer be applied over the epoxy before any type of
> finish is applied. I have had very good sucess with Interlux
404/414
> which is a bullet proof primer that will take any sort of finish. I
> have also used Bullseye 1-2-3 latex primer which has been
recommended
> by Gougeon Brothers who produce W.E.S.T. Epoxy. As for the paint
> itself the Interlux two part epoxy paints are very durable but
> require
> some patience when applying.
> Dave Thibodeau
I've used a two part polyurethane, and the company also
provided its own primer for use over epoxy. Unless you really want to
spend some effort and cash, though, I wouldn't go with the two part poly.
It is extremely toxic, and fussy to apply, although you can get special mixes
for brushing rather than spraying (still fussy -- I rolled it on and smoothed it
out with a brush, but you have to smooth
it within seconds of rolling it
on).
Alternatives are one part polyurethanes or System
Three's two part water-based polyurethane, neither of which I've
used.
I have had good results with an inexpensive
marine/industrial enamel, sold, I think, by CIL/Glidden. It looks good,
wears reasonably well, and isn't hard to apply or touch up. We use this on
a dinghy that takes a fair amount of grounding (rocking?), so the touch up is
important.
Jamie Orr
Sent:Tuesday, October 03, 2000 10:16 AM
To:bolger@egroups.com
- no cursing
- stay on topic
- use punctuation
finish is applied. I have had very good sucess with Interlux 404/414
have also used Bullseye 1-2-3 latex primer which has been recommended
require
Dave Thibodeau
require
Dave Thibodeau
one
awlgrip,
- no cursing
- stay on topic
- use punctuation
- no cursing
- stay on topic
- use punctuation
The light scooner Margaret Ellen is painted with Benjimin Moore poach
paint (redwood, white, and bamboo beige) the kind that needs paint
thinner, not water.
This was held up really nicely over polyester on the teal lil'winnie.
So far, so good over the epoxy on the LSME.
Richard Spelling,
<http://www.spellingbusiness.com/boats>http://www.spellingbusiness.com
/boats
- no cursing
- stay on topic
- use punctuation
CRUMBLING EMPIRE PRODUCTIONS
134 W.26th St. 12th Floor
New York, NY 10001
(212) 243-1636
thinner, not water.
Richard Spelling,
/boats
- no cursing
- stay on topic
- use punctuation
New York, NY 10001
(212) 243-1636
Chris Flynn
Flynn's Folly
_/)
- no cursing
- stay on topic
- use punctuation
> One of these manufacturers even has a "epoxy system" for paintingepoxy. Anyone remember who that was?
For example:http://www.systemthree.com/
