[bolger] Re: The Scarffer
Chuck,
Great idea using a router to cut the ends of the plywood. I've been
known to sleep with my routers I love the versatility of the tool so
much. Yep, routers, plural, got me two of em, a Sears one I keep in a
router table and a Makita plunge unit for hand work.
I do have one question on it. I'm assuming you use a rabbeting bit to
cut a trough. How wide and how deep do you cut? Do you cut both sides?
(Gee, I guess that was three questions)
TIA
"chuck merrell" <chuckmerrel-@...> wrote:
original article:http://www.egroups.com/group/bolger/?start=790
TIA
> Hello all,well for
> I've used the Gougeon Scarf Attachment, and while it works fairly
> 1/4" plywood its not much good if you are using anything thicker. Mycopy
> is kicking around under the front seat of my pickup, and if it getslost or
> purloined, I wouldn't care, Although I bought mine in 1985, Iimagine that
> Gougeon still sells this appliance. However, there is a MUCH BETTERanswer
> to the joining of plywood panels, and one that I've used extensivelywith no
> problems. The better mouse trap is the PAYSON GLASS BUTT JOINT. Ijust
> added a drawing to my list of files on "Private Postings" which showseither
> exactly how to make the joint (as drawn by Tim Payson). You can use
> Polyester Resin to make the joint, and it's quite strong (at least asstrong
> as the Plywood), however I like to use Epoxy and most builders do.the
> I used to dish out the ends of the plywood with a grinder as shown in
> drawing, then one day I used a router instead of a grinder whichallowed me
> to calculate the exact thickness of the lay-up over the joint(including the
> resin) which made for a much neater job. I mentioned this toDynamite one
> day, and he liked the idea too, and changed the procedure andrecommended
> my way instead when he wrote the procedure in a WoodenBoat article.Make
> the route on both ends of the plywood one-half the width of the tapeyou're
> going to use to make the joint.joint is
> Click your way to Private Postings:http://chux.homepage.com/The
> #2 on the list.that
> Cheers!
> Chuck
> CHUCK MERRELL
> MERRELL WATERCRAFT
> P. O. Box 80264
> Seattle, WA 98108-0264
> (206) 764-1298
> Email:chuck@...
> Web Site:http://www.boatdesign.com
> From: <david@...>
> To: <bolger@egroups.com>
> Sent: Tuesday, November 09, 1999 4:36 PM
> Subject: [bolger] The Scarffer
> > Fellow Bolger Boat Builders --
> > I got my hands on a copy of a copy of Robert M. Steward's book
> > "Boatbuilding Manual" 3rd Edition. Mostly it's a lot of dense text
> > doesn't make boat building seem very exciting or even posible.including
> > However, there are a lot of nice facts, figure and resourses
> > a photo of the Gougeon Brother Scarffer, a contraption thatattaches to
> > a skil saw and cuts a deep bevel in one pass. Sounds like (as Marthathose
> > Stewart says) a "good thing."
> > I'm pretty sure the Gougeon Bros. are the same folks who bring us
> > wonderfully over-priced West Systems products. But if this thingreally
> > works, I might consider my love affair with butt straps, (at least
> > where joining plywood is concerned.)
> > On the other hand, the copyright on this edition is 1987. Mebbe they
> > don't make it anymore.
> > Yours in boat building,
> > David
Hello all,
I've used the Gougeon Scarf Attachment, and while it works fairly well for
1/4" plywood its not much good if you are using anything thicker. My copy
is kicking around under the front seat of my pickup, and if it gets lost or
purloined, I wouldn't care, Although I bought mine in 1985, I imagine that
Gougeon still sells this appliance. However, there is a MUCH BETTER answer
to the joining of plywood panels, and one that I've used extensively with no
problems. The better mouse trap is the PAYSON GLASS BUTT JOINT. I just
exactly how to make the joint (as drawn by Tim Payson). You can use either
Polyester Resin to make the joint, and it's quite strong (at least as strong
I used to dish out the ends of the plywood with a grinder as shown in the
drawing, then one day I used a router instead of a grinder which allowed me
to calculate the exact thickness of the lay-up over the joint (including the
resin) which made for a much neater job. I mentioned this to Dynamite one
day, and he liked the idea too, and changed the procedure and recommended
my way instead when he wrote the procedure in a WoodenBoat article. Make
the route on both ends of the plywood one-half the width of the tape you're
Click your way to Private Postings:http://chux.homepage.com/The joint is
#2 on the list.
Cheers!
CHUCK MERRELL
MERRELL WATERCRAFT
P. O. Box 80264
(206) 764-1298
Email:chuck@...
#2 on the list.
Cheers!
CHUCK MERRELL
MERRELL WATERCRAFT
P. O. Box 80264
(206) 764-1298
Email:chuck@...
> "Boatbuilding Manual" 3rd Edition. Mostly it's a lot of dense text that
> However, there are a lot of nice facts, figure and resourses including
> a photo of the Gougeon Brother Scarffer, a contraption that attaches to
> I'm pretty sure the Gougeon Bros. are the same folks who bring us those
> wonderfully over-priced West Systems products. But if this thing really
> David
> eGroup Home:http://www.egroups.com/group/bolger/
