Re: ailerons vs leaning
Drew,
I built a Bolger Tortoise about three years ago. Last year I added a
bolt-on outboard motor bracket to the transom for my 2hp Johnson. I do
90% of my steering by leaning. I only use it in VERY protected water,
but it is lots of fun on our local chain of small lakes.
Vince Chew
Vince Chew
--- Inbolger@egroups.com, "Drew Schumann" <drewnel@p...> wrote:
> ailerons are a means of positive control, while leaning is definitely
> analog in nature. It's very similar to steering a boat via rudder or
> leaning, especially in a sharp-chined craft. The problem I see with
> leaning in boats or airplanes, is that it takes a more intimate
> knowledge of the craft to lean, and is less exact, i.e. you're never
> 100% sure of the end result due to different force vectors. Just my
> 2 cents worth.
> Drew
2 cents worth.
Drew
2 cents worth.
Drew
