Re: Romp
all the way, glued and nailed, than to fit and bend, scarf and
laminate 1/2" plywood planks.
That would actually be the easiest area to strip as there would be no
bevels and less fairing and sanding required.
Peter Lenihan would know - he built ELVER that way - except it had a
plywood bottom.
Nice looking boat too:-)
>To me it would be less hassle just to strip it with 1" square strips
> On 11/21/06, Hugo Tyson wrote:
> > I don't think it would work, plywood topsides.
> Perhaps you are right. Though, what I imagine is planks from plywood,
> pehaps 8 inches wide. Staggering two layers of 1/2" to make 1 inch
> thick. I imagine that the top four feet of the hull could be planked
> this way, but lower down where it gets curvy, 1 inch square planks,
> and at the keel, even narrower.
plywood bottom.
Bruce Hallman <bruce@...> wrote: > ironclad bitch once you got to the turn of the bilge. To get from the
filling gaps asneed be with thickened epoxy. Once you get up past
that twisting area, I see that most of that hull is a simple strip
job, with plywood even planking possibly possible on the high up
areas. Perhaps I am an optimist, but I see that hull as coming
together pretty quickly, with the miracle of thickened epoxy.
Send instant messages to your online friendshttp://au.messenger.yahoo.com
> flat bilge to the sharp forefoot require a lot of twist in the strips,If it were me, instead of steaming, I would have used thinner strips,
> many of which required steaming.
mindless sanding as one releases the shape within.Oh boy Oh boy I look
forward to entering the sanding zone one more time when I put the
finishing touches on the outside of Windermeres' hull :-D Yessirree
and to reward mayself with cold brewskis afterward......heaven!!
Peter Lenihan, no stranger to mindless states nor sanding acres worth
of stuff,from along the shores of the St.Lawrence..........
>the
> On 11/21/06, Nels wrote:
> > The joy of it coming together fairly quickly would be offset by
> > tedium of...I'm with Bruce! Absolutley hundreds of hours worth of completely
> tedium? rather
> ...by sculpting, smoothing and caressing that voluptuous shape.
Google "sourceforce Freeship" and download the software so you can
view and rotate the hull with full 3D rendering. She is 30 feet long
and 8 feet wide.
http://sourceforge.net/projects/freeship/
and 8 feet wide.
> The joy of it coming together fairly quickly would be offset by thetedium? rather
> tedium of...
tedium of having to sand it all fair, after filling all the chinks and
openings, then having to cover with glass, get the molds out, turn in
over and start doing the same on the interior.
It occured to me that that may be why a lot of builders cold mold over
top of the stripping. Either way, one would be mixing lots of epoxy
batches and doing lots of epoxy sanding afterwards.
Sure is a pretty boat though:-)
> If it were me, instead of steaming, I would have used thinner strips,The joy of it coming together fairly quickly would be offset by the
Can't tell from the screen dump what size she is. At a casual glance
she looks a lot like Moccasin or LFH's Golden Ball. What software uses
.fbm?
V/R
Chris
.fbm?
V/R
Chris
> Of all of Bolger's designs, Romp is simply the most pure, elegant
> sailboat. Even though it is a big boat, the simplicity of it would
> make it a relatively quick build, I think.
>http://hallman.org/bolger/romp/RompLines.gif
>http://hallman.org/bolger/romp/Romp.fbm
> ironclad bitch once you got to the turn of the bilge. To get from theIf it were me, instead of steaming, I would have used thinner strips,
The Romp is possible the last on my list of 3 boats to build.
1. windsprint for when I want to get away from the wife.
2. possibly a black skimmer for when I want to take the wife with me.
Was thinking his and hers (single handed) schooners. But knowing the
wife all to well, sometime on the maiden voyage I would hear the cry
"ramming speed" from her.
3. Romp (or possible sweet chariot... still deciding on that one) for
after I retire. To be put in the water probably only once a year
right after atlantic hurricane season is over. To sail from
Massachusetts bay down to the carribean and stay there will spring.
The wife grew up in St Croix and still has lots of friends there.
Of course, items 1 and 2 are somewhat dependent on how long she stays
a prof ar Boston Univ. They have a small fleet and she gets free
access to it, being an employee.
Steven
Steven
LOL That last like says it all my friend! We build
things and why? So we can enjoy them, and when they
are pretty as well! That just adds to the enjoyment!
Blessings Krissie
--- John Bell <smallboatdesigner@...>
To get from the flat bilge to the sharp forefoot
require a lot of twist in the strips, many of which
required steaming. When he complained to Bolger about
it, he was told in essence "yeah, but isn't she
pretty?" No argument there...
Sponsored Link
Mortgage rates near 39yr lows. $510k for $1,698/mo.
Calculate new payment! www.LowerMyBills.com/lre
Blessings Krissie
Sponsored Link
Maybe cold-moulding would be the way to build it. With this method
it's easy enough to use narrow planks on the difficult parts towards
the ends and wider ones where there's less compound curvature.
Howard
Howard
--- Inbolger@yahoogroups.com, Hugo Tyson <hhetyson@...> wrote:
> My father built one, and it was an absolutely tedious planking job,
which required steaming and in some sections of the bow due to the
extreme change of shape steaming and using strip planks of half the
height of the others. It is not a plywood box boat and for one man
alone to build, especially as a first big boat project it would take
about 2-3 years work, and we're not talking weekends and holidays,
but nearly full-time, including weekends boatbuilding
> Hugo Tyson. Hobart. Tasmania..Australia.
> PS. By the way she did sail quite fast and has surprised some
more "sophisticatedly rigged" boats!
elegant
My father built one, and it was an absolutely tedious planking job, which required steaming and in some sections of the bow due to the extreme change of shape steaming and using strip planks of half the height of the others. It is not a plywood box boat and for one man alone to build, especially as a first big boat project it would take about 2-3 years work, and we're not talking weekends and holidays, but nearly full-time, including weekends boatbuilding
PS. By the way she did sail quite fast and has surprised some more "sophisticatedly rigged" boats!
I don't know anything about building Romp, but agree is a neat boat. In the
'80's there was one in Sausalito (San Francisco Bay). I sailed alongside
it once and it was quite fast. Later I got a chance to go aboard it as it
sat on a trailer. I spent some time down below. It was cozy with the
limited headroom, but too open for my taste as an interior to be in while
sailing. Too much open space with nothing to grab onto, but of course an
interior could be changed. Pretty neat that it could be put on a trailer
for transport. I believe it was being sold at the time.
Gary
Gary
Sent: Monday, November 20, 2006 2:35 PM
Subject: [bolger] Romp
Before I got into boatbuilding, I used to kayak with a guy, John
Conneely, who build a Romp. He said that the strip-planked hull was an
many of which required steaming. When he complained to Bolger about it,
he was told in essence "yeah, but isn't she pretty?" No argument there...
--- Inbolger@yahoogroups.com, John Bell <smallboatdesigner@...> wrote:
extensive strong back and mold set-up no?
>there...
>Romp is a beautiful big canoe shape. Probably requires a fairly
Hi,
I recall Phil telling me that Romp sailed through a hurricane - and emerged unscathed!
One of his favourite stories, I think . . . but also a great recommendation for the boat type.
Bill
Bill
In answering this message...
> > Does anyone have information about this Romp or any boats
built to the design other than MAIB's article awhile back?
Peter answered...
> I enjoyed the pictures in MAIB very much. I was surprised how
elegant the small flare in the upper bow looked.
Which MAIB was this? I am a new subscriber and would like to
order the back issue. Romp, Ataraxia and the like are far too big
for me, but I have been looking at Owlet (designed as a
tender/lifeboat for Barn Owl) and would like to see more
information on the type. Owlet has elegant bows indeed.
Thanks, Vance
> DoesThe design was originally exposed in Different Boats, or was it 30-
> anyone have information about this Romp or any boats built to the
Odd Boats. Interestingly, in that original article he says that the
owner worked out the constrution. "All he bought from me was a shape
and a design for the folding mast." is what I remember. I don't know
if he has drawn up plans with a complete construction plan or not.
PCB has promised an up-coming book on his (their?) shoal draft
designs of which Manatee (Alert) and Romp would be featured. He
discussed many of the features (from a design point of view) in his
recent WoodenBoat article on shoal draft.
I enjoyed the pictures in MAIB very much. I was surprised how elegant
In the "Small Craft Advisor" article posted in the files, Bolger
identifies Romp as his "most seaworthy small sailboat design". Does
anyone have information about this design or any boats built to the
Tom
Tom
Romp is design #372, which I saw in "Messing About in Boats", Nov 15, 1998,
Vol 16-Num 13.She is 30ft by 8ft, center board presto type with high sheer,
yawl rig with 315 sqft, displacing 8250 lb, including 2000 lb ballast shoe
to quote a few of specs. PCB was talking about fitting leaboards and Chinese
gaff rig but I don't know if anything came of it.
I liked the look of it and St Valary, and the old Hoyt Freedom ketches.
I bought a 21ft Freedom cat boat last spring in great shape, but which I
haven't had time to put in the water yet, so I haven't pursued any of the
afore. My house project is coming along so maybe spring is realistic. Clyde
Jeff Gilbert wrote:
> Clyde
> Where would I find info on Romp??
> I know nothing about it I admit.
> LWL, intended use?
> Jeff
> From: Clyde S. Wisner <clydewis@...>
> To: <bolger@egroups.com>
> Sent: Saturday, October 28, 2000 11:10 PM
> Subject: Re: [bolger] Re: Saint Valery
> St Valerie and Romp are two of my favorite round Bolgers. I wonder if he
> ever
> finished design for Romp with Chinese gaff? Clyde
> - no cursing
> - stay on topic
> - use punctuation
Jeff,
There's a good write up (by Bolger himself) of Romp in _Messing About in Boats_, Volume 16, Number 13, November 15, 1998, pages 26-28.
29 Burley Street,
Wenham, MA 01984-1943
david g
Date:Sat Oct 28, 2000 5:54pm
Subject:Romp
Clyde
Where would I
find info on Romp??
LWL, intended
use?
> Where would I find info on Romp??When you do see a picture of Romp, compare it carefully to the lines
drawing. When you see how PCB got the incredible, elegant sculptured
shape in the upper bow, and you can reproduce the same sort of
effect, then you will have taken a big step toward your career goal.
When I looked at the drawings, I saw a plain sort of bow, but when I
looked at the pictures, I saw a subtle, beautiful shape. So much to
learn.
Clyde
LWL, intended use?
LWL, intended use?
ever
