Re: [bolger] Re: Micro keel/Navigator rig
The list has cycled through keel casting before, but since there are some new
builders it might be worth repeating the following:
Lead can be melted on the kitchen stove (not suggested) or its equivalent - it
only takes around 750 degrees F. The fumes are toxic, and the arsenic usually
found in the melt is a concern. Normal free-flowing ventilation will take care
of this.
Any (Really, ANY - even a teaspoon!) water can be disasterous. A dripping tin
roof, a dipper with a few drops of water, or wet wheelweights added to the melt
can blow the melt right out of the pot and all over you. Thick gloves, good
boots, layered (non-synthetic) clothing is called for. Eye protection is a must.
BUT, it is really not that hard to do, and the lead can be sawed (even planed)
once cast, and since the Micro puts it all in a box, it is OK to have a flawed
casting. A half a dozen borrowed Coleman stoves and a few garage sale cast iron
pots will get you in the backyard foundary business. Anyone who has never
skimmed pieces of steel that are floating on a shiny pool of lead is missing a
thrill. Furthermore, you may know an expert - any friends who cast bullets or
fishing weights? Drift boat anchors?
If the lead is really that much of a block to your building, think about a steel
piece from a metal salvage yard. They are reasonable, sell by the pound, and
will cut to order.
Lastly,( though I have cast a lot of lead - but never a keel) consider doing
your cast into a 3 sided box. If it is level, you don't need a top! Disclaimer
- I haven't done it, but I know that the lead finds level all by itself.
Jim
of this.
will cut to order.
Jim
At least one Micro builder subcontracted the lead ballast to a
professional.
Another did some research with the people who provide lead shielding
for dentists offices, hospitals and other places who use x-rays. The
were willing to pour a slab of the desired thickness out of which the
desired shape could be cut. They would buy back the excess lead.
So, there are many ways to ballast a cat-yawl.
PHV
professional.
PHV
--- Inbolger@egroups.com, "Don H. Reed" <donhreed@m...> wrote:
> Pheww!!!!
> Gosh, Peter, thanks for saying that...That's a shot in the
arm. 'Cause I
> was beginning to worry. I thought I could sneak by and build
around my
> keel-mess...you've pretty much confirmed my thoughts on the
subject. Point
> is--to be out on the blue enjoying rather than wringing my hands in
worry
> about "keel envy", or worse, keel fall off. Yikes!
> Even if it does, (fall off), @ $0.15 per lbs. for scrap
lead...it'll be back
> to the drawing board for sure. Now that's an Idea! Why hasn't one
of the
> faithful gone into the mass produced, Micro-keel business? [It's a
> rhetorical question] ;-)
> Thanks for the help.
> Don
> -----Original Message-----
> From: Peter Vanderwaart <pvanderw@o...>
> To:bolger@egroups.com<bolger@egroups.com>
> Date: Wednesday, November 01, 2000 11:09 AM
> Subject: [bolger] Re: Micro keel
> >> clogged up. Molten lead splashed and hardened immediately--
> >blocking
> >> feeder hole.
> >Up to now, all the stories I have read about pouring keels include
> >the part where the hero takes a propane torch and heats the outlet
> >pipe to re-melt the plug that forms there.
> >I don't think that the Micro design relies on any strength from the
> >lead keel. If you get the keel properly built around the lead, you
> >should be fine.
> >Peter
> >Bolger rules!!!
> >- no cursing
> >- stay on topic
> >- use punctuation
> >- add your comments at the TOP and SIGN your posts
> >- add some content: send "thanks!" and "ditto!" posts off-list.
I hope so, Paul. By the time I nail that puppy with ring-shanks, she should
hold together. I originally planned for one inch nails...now the plan is
1.5" ...I'm staying rigidly flexible.
Don
Date: Wednesday, November 01, 2000 10:29 AM
Subject: RE: [bolger] Re: Micro keel/Navigator rig
Don
>Thanks, Don....... So is your 'baklava' keel going to work out, with thegot
>epoxy 'syrup' poured over it? I'd love to pour my own keel, I'm kind of a
>compulsive do-it-yourselfer; but I worry about the fumes, etc...... I've
>an electrician friend who has a plumber's burner designed to melt lead, soI
>would just need to buy a lot of gas..... but it still intimates me some.progresses.
>Dave Jost posted the name of the foundry he got his Micro keel poured at,
>it's very close by, and the price wasn't too bad, so that may be the one
>aspect of my micro that I hire out..... we'll see how the winter
>At this point the whole project still only exists in my head, but I thinkthe
>once I have all these pesky 'how-to' details ironed out in my head I'll be
>diving in pretty quick.
>Peter, you did a deadwood keel, with the lead through-bolted rather than
>hollow plywood box keel section...... I remember a long time about youso
>saying something about having had to compensate for the flotation added by
>this extra wood versus the would-be free-flooding hollow keel. So your lead
>must be heavier overall to compensate for the extra flotation of the
>timbers, and wider since there isn't 1/4" of plywood sandwiched around it,
>correct? I'd be interested in knowing how you calculated the weight
>compensation, fore-aft distribution, etc. around those notches to fit the
>deadwood - would you be willing to share your alternate keel pattern, info
>on the barrier coat used, structural considerations to receive the bolts,
>etc? Whether or not I cast my own keel, I will probably want to go with the
>more stout timber keel for many of the same reasons you once mentioned in
>this forum. Also, aside from building it for its own sake, the Micro is
>practice for eventually building a much larger liveaboard boat (hopefully!
>Otherwise I'll at least have a Micro to cruise around in!) which will also
>probably have a laminated deadwood keel, so I may as well learn how on a
>much smaller scale. I've built 4 strip canoes and kayaks, so while I'm
>confident I can build a keeled plywood boat, it is still new territory for
>me. Your pictures on Duckworks are excellent, by the way! Thanks for taking
>the time to put that story together for us.
>I just ordered '103 rigs' yesterday; I understand the Micro plans now come
>with the Navigator upgrade so I'm considering the Navigator 'chinese gaff'
>sail, though I'll stick with the standard cuddy. I've long been a junkie in
>my boat fantasies and subscribe to the junk rig list as well as this one,
>I'd like to try out that rig on the Micro with an eye toward gaininglooks
>experience with the rig for my big dream boat. But since I plan to trailer
>my micro, this may determine which rig I ultimately use; if the gaffer
>too complicated to set up and take down each time, I'll go with thestandard
>rig for simplicity. I know I'll go out more often if I don't have to spendI
>too long at the ramp swatting mosquitoes while I rig the boat. Of course if
>the mast is shorter on the gaffer (which PCB alludes to in the MAIB
>article), it might make for easier trailering. Hell, maybe I can even leave
>the mast up with the sail furled on deck if I'm just running back and forth
>to the ramp down the street! I'll have to check the powerlines enroute, but
>I've seen some awfully big trucks make it down my street.
>Does anyone know if PCB offers Long Micro plans with the chinese gaff rig?
>guess with the book in hand I could probably figure it out for myself,I
>knowing that rig already has his blessings for this boat, but it'd be nice
>if it came in the plans! Only reason I haven't sent in my check yet is cuz
>still may go for the Long.........
>Thanks, all, for sharing your Micro expertise! You've kept my enthusiasm
>high, and I'm hoping to join the fraternity very soon.....
>Paul Lefebvre
>looking for something productive to do through a long Cape Cod winter.....
>- no cursing
>- stay on topic
>- use punctuation
Pheww!!!!
Gosh, Peter, thanks for saying that...That's a shot in the arm. 'Cause I
was beginning to worry. I thought I could sneak by and build around my
keel-mess...you've pretty much confirmed my thoughts on the subject. Point
is--to be out on the blue enjoying rather than wringing my hands in worry
Even if it does, (fall off), @ $0.15 per lbs. for scrap lead...it'll be back
to the drawing board for sure. Now that's an Idea! Why hasn't one of the
Don
Don
>blocking
>> feeder hole.
>should be fine.
>Peter
>- no cursing
>- stay on topic
>- use punctuation
> clogged up. Molten lead splashed and hardened immediately--blocking
> feeder hole.Up to now, all the stories I have read about pouring keels include
should be fine.
compulsive do-it-yourselfer; but I worry about the fumes, etc...... I've got
an electrician friend who has a plumber's burner designed to melt lead, so I
aspect of my micro that I hire out..... we'll see how the winter progresses.
Peter, you did a deadwood keel, with the lead through-bolted rather than the
my boat fantasies and subscribe to the junk rig list as well as this one, so
my micro, this may determine which rig I ultimately use; if the gaffer looks
too complicated to set up and take down each time, I'll go with the standard
Does anyone know if PCB offers Long Micro plans with the chinese gaff rig? I
if it came in the plans! Only reason I haven't sent in my check yet is cuz I
Paul Lefebvre
Paul Lefebvre
Paul,
Send your money in for the Micro plans...Yes...St. Louis, S. Grand
area...Near Carondolet Park. Nice job!
I'm not frightened by the melting or the pouring...frustrated is more
the word. Four bags of charcoal @ 25 deg. each brickette...still
could not heat hot enough to melt 20#. Used the Turkey-fryer
@170,000 BTU...more frustration. 1.5" x 7" opening in my mold
feeder hole. Maddeningly, I laid the mold flat, removed all the
screws, began ladeling in hot lead. Guess what, without a Bessimer
Blast furnace, it's done one pot/tincan-full at a time!! What you
wind up with is a lead Baklava. (Multi-layers)
I now have a layered keel...not a solid one, as I'm sure the designer
intended. Although it may have many layers, the lead plys lay in the
correct direction; and, it's just as heavy. I'm not giving up on
this...Once this monstrocity is placed beneath the hull, slathered in
epoxy and sandwiched with plywood, then nailed with SB ring-shank
nails...gawd, it's ugly!
#1. You'll need a blast-furnace or lots of friends with turkey
fryers to keep a lot of lead molten. (1200 deg. F.)
#2. Don't do it outdoors or the lead with solidify pretty darn quick
and with not stay liquid long enough to fill in the nooks and crannys
of your mold.
#3. If indoors--ventilate!!
#4. Save a lot of time and energy--have a foundry do it!
Don Reed
of your mold.
Don Reed
--- Inbolger@egroups.com, "Paul A. Lefebvre, Jr." <paul@w...> wrote:
> Hey Don,
> I'm about to send in my check and start my Micro - let us
know how the
> turkey fryer works, the only aspect of this project that I find
somewhat
> intimidating is the keel pouring!
> Now let me check out this handy-dandy internet 'latitude/longitude
finder' I
> just searched up - are you in St. Louis, in the vicinity of S.
Grand Blvd?
> Paul Lefebvre
> From: donhreed@m... [mailto:donhreed@m...]
> Sent: Tuesday, October 31, 2000 3:38 PM
> Subject: [bolger] Micro keel
> Hello list,
> New member here. ...been reading and thoroughly enjoying...
> Building a Micro...single-handed...she's 80% built about now, she's
> on her feet and needing a keel. Tried the 55 gal drum cut in two
> w/charcoal. Not hot enough to melt 10 lbs. Hah, talked myself into
> buying a Turkey-Fryer (170,000 btu) propane/outdoor stove. This
> weekend should do one of two things-:
> Fry a turkey, or
> melt 420# of lead.
> Later & Happy Halloween,
> Don Reed
> N38 34.4 -- W90 16.1
> - no cursing
> - stay on topic
> - use punctuation
To Don and Paul,
The keel on the Micro really is not that difficult.Also,there
are many ways to do one.Click
here:http://www.duckworksmagazine.com/articles/micro/index.htmto see
how I did mine and perhaps pick up some ideas for your own particular
situation.I would be glad to answer any questions you may have about
the MICRO,"the cutest little yacht in any harbour"!
Peter Lenihan,rooting around like a pig on speed,since he put his
MICRO to bed for the winter,on the not yet frozen but always polluted
shores of the St.Lawrence..........
> Hey Don,
know how the
somewhat
finder' I
Grand Blvd?
> Paul Lefebvre
> Hello list,
> Fry a turkey, or
> melt 420# of lead.
> Don Reed
> - no cursing
> - stay on topic
> - use punctuation
Hey Don,
I'm about to send in my check and start my Micro - let us know how the
turkey fryer works, the only aspect of this project that I find somewhat
Now let me check out this handy-dandy internet 'latitude/longitude finder' I
just searched up - are you in St. Louis, in the vicinity of S. Grand Blvd?
Paul Lefebvre
Hello list,
Fry a turkey, or
melt 420# of lead.
Don Reed
- no cursing
- stay on topic
- use punctuation
Paul Lefebvre
Hello list,
Fry a turkey, or
melt 420# of lead.
Don Reed
- no cursing
- stay on topic
- use punctuation
Hello list,
Fry a turkey, or
melt 420# of lead.
Don Reed
Fry a turkey, or
melt 420# of lead.
Don Reed
