Re: [bolger] Re: winter cover technique
<<The Seaport uses fitted canvas covers tied across under the boat.>>
The first time I covered my car while abroad for the winter, I returned
to find the cover flapping in the breeze and the car covered with snow.
Since then, tie it under!
CM
http://www.angelfire.com/mi/mmmkkk/
(Last of the Red Hot DJs)
CM
> I'm trying to work out something similar right now, and I waswondering how
> the tarp gets attached.The Seaport uses fitted canvas covers tied across under the boat.
PHV
<<...will moisture pool where a non-breathing cover touches the edge,
and maybe start decay in the wood trim? Or might it chafe? Or am I
paranoid?>>
You are obviously paranoid, but don't sweat it. :) Your question
reminds me of what a construction site guy told me about Tyvek. It
breathes, allowing moisture out but not in. Seems to me it would be the
perfect storage tarp.
Cliff
paranoid?>>
Cliff
That is a great photo from Mystic! That looks like the Oyster shack
in the background.
In regards to tarps, I have used both the blue poly tarp and the
green. It appears that the heavier green poly is more water proof
than the blue.
In New England, I always buy a tarp that is much too large for the
entire craft and then tuck the long parts under (like making a bed)
then, The sides and ends are held in place with logs and rocks. I
then rake all of the leaves around the yard up around the cover. This
way, I accomplish 2 things: 1. the wind does not get under the tarp
and lift it off. 2. I have a nice place to put the leaves til
spring.
the only problem I have had with this is that it is so cozy under the
tarped boat that hibernating animals like to take up residency in
there.
"if anyone needs some leaves, I know where they can get some ;-)"
in the background.
than the blue.
spring.
there.
Good picture (good posting, this kind of stuff is what I subscribe for.)
I'm trying to work out something similar right now, and I was wondering how
the tarp gets attached. The cover in the background of the picture appears
to show a dark line just below the ridge -- is there a cap on top of the
canvas? Could the piece on top of the frame shown fit on top of the canvas?
I've found a cap piece screwed down through the tarp will tame it in strong
winds.
I'm also wondering how much protection gunwales need from the cover itself
-- will moisture pool where the a non-breathing cover touches the edge, and
maybe start decay in the wood trim? Or might it chafe? Or am I paranoid?
I'm going to try a polytarp cover, partially open at the ends, on top of a
frame similar to the one shown, and keep an eye on how things go over the
winter. I want to be able to whip it off and go sailing at short notice, so
a complex job is out of the question.
Jamie Orr
Sent: Friday, November 10, 2000 2:20 PM
To:bolger@egroups.com
Subject: [bolger] winter cover technique
This is a sort of cross-post from the boatdesign group, but the
population here is bigger, and its a useful idea. This is a shot of
the frame for the winter cover for a small sharpie at Mystic Seaport.
Note how the ends of the side braces are covered so they don't create
a hard spot and chafe the cover.
ma_sh2 under Folder Schooner in Files
http://www.egroups.com/files/bolger/Folding+Schooner/ma_sh2.JPG
- no cursing, flaming, trolling, or spamming
- no flogging dead horses
- add something: take "thanks!" and "ditto!" posts off-list.
- stay on topic and punctuate
winds.
Jamie Orr
