Re: [bolger] Re: A Question on the Light Scooner
True, offsets can have any number of dimensions (even more than 3 for
physicists). I'm talking about the X-Y datapoints for laying out the
sides. I did enter the boat in the program, ripped the sides on the table
saw, assembled and butt-blocked them, and transferred the changes to the
ends since the sides were mostly rectangles.
I did not plot the bottom, rather nailed it on and transferred the cuts off
the inverted boat, took it off and cut it.
Gregg Carlson
At 11:58 AM 11/13/2000 -0500, you wrote:
>Greg --
>When I think of offsets, I think of x, y, and z figures relative to a
>baseline and center line.
>When you said "The offsets are the X-Y data used to plot the sides."
>do you mean the figures for laying out the topsides, or did you use
>your hull program to generate offsets for the entire hull?
>YIBB,
>David
>>Interesting, I guess it's there all right. As I noted, I took it off; I
>>didn't think the 1/2" bottom would take it. Probably why MY schooner is SO
>>fast...;-}
>CRUMBLING EMPIRE PRODUCTIONS
>134 W.26th St. 12th Floor
>New York, NY 10001
>(212) 243-1636
>- no flogging dead horses
Greg --
>fast...;-}
New York, NY 10001
(212) 243-1636
fast...;-}
Gregg Carlson
At 09:24 AM 11/13/2000 -0500, you wrote:
>FLSB (Fellow Light Scooner Builders) --
>I too notice (by eyeball) a "kink" when I was laying out the lines
>for the aft sections of the topsides. But as this was during one of
>the "Bolger is God" flare-ups on the list, I moved on with the
>building and put my faith in God Bolger.
>Kink or not, Margaret Ellen is by no means a "fair" boat. She twists
>and turn and ripples this way and that. But she is a fast boat. As
>fast as Tim's? We'll never know, but plenty fast for me.
>My question is this: Where are these offsets GC is referring to? I
>see no offsets on my plans?
>YIBB,
>David
>>The kink is definitely there. In a model, it shows up as a sweep up
>>in the schooner's run. It also requires about an inch taken off the
>>top of the transom to keep the sheer reasonably fair. The
>>gereneral look is a slightly "hippy" schooner. Likelihood is that
>>there's a hiccup in the offsets but...PCB has cheated on a number of
>>things to get the scooner reasonably load bearing without departing
>>too far from the 6:1 length/beam at floors ratio and this could have
>>been another cheat.
>>We looked at it and looked at it, thought about just what the water is
>>going to do at high speed (!) then *kept* the sweep-up and took a bit
>>off the transom to maintain the sheerline. The sweep=up was faired
>>with a 16' batten but is still quite evident when the boat's on her
>>trailer. Skiffies give it (the sweep-up) wolf-whistles when they see
>>it... I strongly suspect it's the reason why we are so very, very
>>fast, almost unbelievably so given later builders' reports. My own
>>building notes say "live with it and trim the transom".
>>Tim & Flying Tadpole
>>--- Inbolger@egroups.com, "Gregg Carlson" <ghartc@p...> wrote:
>>> A question for light scooner builders occured to me: did anyone else
>>> find a bump orkink nk in the side panel on the bottom edge (the
>>> chine) near the stern? I plotted that kink twice myself and then
>>> faired it out by a spline. Was it just me, or is there a bug in the
>>> offsets or an intentional sweep up in the aft rocker?
>>> Gregg Carlson
>>Bolger rules!!!
>New York, NY 10001
>(212) 243-1636
>been another cheat.
>> Gregg Carlson
New York, NY 10001
(212) 243-1636
been another cheat.
> Gregg Carlson
I haven't yet gotten to that part of the project, but I may have some
insight. According to Glen L. Witt in "Boatbuilding With Plywood", no
designer intentionally includes any unfair lines, and those found to be so
through a fault in the plans or in the lofting thereof, should be correctly
faired with a batten. Sounds like you did it right Gregg.
____________________________________________________________________________
__
Human beings can always be counted upon to assert, with vigor, their
God-given right to be stupid.
-Dean Koontz
To: <bolger@egroups.com>
Sent: Friday, November 10, 2000 11:19 PM
Subject: [bolger] A Question on the Light Scooner
> Gregg Carlson
Gregg Carlson
