Re: [bolger] Windows
Thanks, Jeff--very timely. I started that discussion,
and am now puzzling over the installation of plexi
windows on my Topaz. Looks like lots of neat, helpful
stuff on the site. Sam
--- Jeff Blunck <boatbuilding@...> wrote:
> There was a discussion earlier on how to deal with
> Lexan / Acrylic. Here's a web site with the glues
> and tools available to order.
http://www.clearcutplastics.com/Do_it_Yourself/do_it_yourself.html
> Jeff
> [Non-text portions of this message have been
> removed]
Do You Yahoo!?
Great stuff seeking new owners in Yahoo! Auctions!
http://auctions.yahoo.com
There was a discussion earlier on how to deal with Lexan / Acrylic. Here's a web site with the glues and tools available to order.
While I do not know what they are called, though I heard them called
pullman? or train car windows there is a vertical sliding
kindadjustable by astrap with eyeholes on a hook lowered they slip out
of sight in protective bays the strap hiik on an inverted peg below
the window so when the window needs to be all of the way up the strap
is down in front
having wrote that there is another solution On the bluebird
schoolbusses the windows are split unto upper and lower halfs and
spring loaded friction mechinisms hold them in place that gives you
half ventalation and half clear glass. last sugention I use a
backhow,(Case) it has triple windows ( three tracks) upper is outer
most and hook or ratchets on each side. by lowering the midddle window
then the upper window you get about 75 percent air space and the
lowest part still lets light in
jeffery
--- Inbolger@egroups.com, "Rick " <sctree@d...> wrote:
> Thanks guys, my brain is begining to actually work.
> David,
> Wiley windows are great, I've built and used them. A piece of 1/4"
> plywood with the center cut out and a screen stapled to it makes a
> great bug screen.
> They wont work in my application though. I've got a 24" x 24" window
> with only 3" above it to the overhead.
> Jim,
> Good thoughts.
> Trim on the outside I'd be worried about wind pressure pushing in
> when
> trailering, have to think on that one.
> Swinging in and hanging from the overhead is restricted by the small
> (4' X 6') pilothouse and five 24" x 24" windows, to crowded.
> More suggestions welcome
David,
great bug screen.
Jim,
Good thoughts.
when
More suggestions welcomed.
Rick
