Re: [Long shaft/short shaft
>So, Bill, you would then position the new motor so that it extended fartherI'd leave the transom as it is, and risk the odd grounding of the motor.
>down into the water than the short shaft motor does? Would you mount the
>new motor on the same transom, or raise it somewhat?>
>Chuck
Bill
> I'd leave the transom as it is, and risk the odd grounding of the motor.Not having a better plan, that is the best way to start, simply because it
> Bill
is easiest. If it turns out to be too deep, you can always raise the
transom later.
