RE: [bolger] Re: Questions on Foam
Lincoln,
I used R-guard for the Pointy Skiff flotation. Don't know about its
resistance to fuel and the effect epoxy has on it but I plan to find out
soon. I'll let everyone know. I cut mine with my trusty sabre saw followed
by clean up with my trusty shop vac. No fumes, fires, hot wires, etc.
Jim C.
Jim C.
> -----Original Message-----
> From: Lincoln Ross [mailto:lincolnr@...]
> Sent: Wednesday, December 27, 2000 12:19 PM
> To:bolger@egroups.com
> Subject: [bolger] Re: Questions on Foam
> Aircraft Spruce and Specialty used to have a cheap kit for a hot wire
> cutter that works fine. Maybe they still carry it. I'm sure you can
> surf and find them.
> If you want to play now, get a 12V battery, a charger or maybe another
> battery, some .020" steel wire (maybe stranded steel fishing stuff,
> tho music wire works ok). Make a bow about 3 or 4 feet long to hold
> the wire in tension (10 or 20 lbs????), plus wrap some wire in a
> spiral around something like a brick that won't burn or conduct.
> connect the two voltage sources in series and to one end of the bow.
> Connect a wire from the other end of the voltage source to one end of
> the spiral. Clip a wire from the spiral to the opposite end of the
> bow. Adjust position of clip on spiral to adjust current. Should
> slowly and easily cut through styrofoam if current is right. DON'T cut
> urethane as apparently it kicks off really nasty fumes. You will want
> some ventilation anyway. Be careful that you don't have anything
> tremendously flammable about, particularly if you mess up momentarily
> and the wire gets red hot. This is an easy, non-critical process. Just
> make sure you have some extra wire as you may break some. Don't use
> copper wire. Proper size guitar string will work if you're really in a
> hurry. Works on expanded bead foam just as well as styrofoam.
> --- Inbolger@egroups.com, "Rick " <sctree@d...> wrote:
> > Soon the decision on foam buoyancy for the Diablo has to be made.
> > Locally I can get the white styrofoam called "R-Guard" in two inch
> > thick sheets. A few questions, does anyone know;
> > 1. Is this stuff OK?
> > 2. Is it fuel resistant?
> > 3. How do you cut it? I seem to recall any saw produces tons of
> small
> > particles that fly around and stick everywhere. Someone told me
> craft
> > people use a "Hotwire" cutter, anyone know what and where about
> that?
> > 4. Is there a perfered glue to hold the pieces together to make a
> > block ? I was told epoxy disolves it.
> > 5. Is there a coating, -paint,varnish, something else?- that will
> > give it a little protection?
> > Boatshop shutdown until Saturday am, but still building in my head.
> > Thanks for any and all thoughts,
> > Rick
> - no flogging dead horses
surf and find them.
surf and find them.
small
craft
that?
> Rick
James:
FWIW, I concur on every point.
> My experience with this foam is based on model a/c and homebuilt a/c buta
> this is what I think. ( free advice is worth what you pay for it!)
> 1. It ought to be just fine for floatation.
> 2. gasoline will melt it as soon as it touches it.
> 3. It is very easy to make a hot wire cutter, and it is the easiest and
> neatest way
> to cut it. If you search under hot wire foam cutting you should find
> plenty of
> info on how to. If you need further info, I can tell you how to make
> simple
> one.
> 4. I think that the best adhesive is epoxy. It will not harm it, and it
> will keep
> gasoline from harming it. Do not use polyester resin, it will eat it
> up.
> 5. Epoxy.
> James Fuller
> From: Rick <sctree@...>
> To: <bolger@egroups.com>
> Sent: Tuesday, December 26, 2000 9:07 AM
> Subject: [bolger] Questions on Foam
> > 3. How do you cut it? I seem to recall any saw produces tons of small
> > particles that fly around and stick everywhere. Someone told me craft
> > people use a "Hotwire" cutter, anyone know what and where about that?
> > Rick
has the insulation foam. It usually comes in either 1" or 2" thick
sheets and is pink or blue. I don't know if it's gasoline resistant,
but it's supposed to be "epoxy-proof".
Bruce
> Soon the decision on foam buoyancy for the Diablo has to be made.Check to see if your local home supply store(Lowes, Home Depot etc)
> thick sheets
Bruce
neatest way
plenty of
info on how to. If you need further info, I can tell you how to make a
simple
one.
will keep
up.
5. Epoxy.
James Fuller
neatest way
plenty of
simple
one.
will keep
up.
5. Epoxy.
James Fuller
> Rick
Rick
Rick
