Re: Block question
That seems like a lot of stress on the wire! Do they have wire with a
working load that high? I get, very roughly, somewhere above 40,000
psi, not accounting for the spaces between the strands. Don't know,
but I should think working load would be reduced in an application
where you move the wire over a block under load.
--- Inbolger@egroups.com, "MA Farrell, G Blankenship " <gbship@i...>
snip probably should be metal and probably should also be grooved for
1/4-
> inch wire. The working (not breaking) strength should be around a
> ton. snip
> Any thoughts/suggestions? Many thanks for any help!
> Gary Blankenship
> Tallahassee, FL, where it's not only too cold to epoxy, it's too
cold
> to paint!
- I'm not sure if what I have is what you're looking for, but a few
years ago my neighbor gave me a pair of (new) all steel blocks on
their own base. I think they are originally for the steering cables
of old outboards. Very hefty, I'm guessing they are drilled for a pair
of 3/8" mounting bolts. If you think one might work, let me know and
I'll scan a photo to you. You can have one if you pay the shipping.
Rick
> The design of the lifting keel for my rebuilding project calls for
> rather hefty block (for the lifting wire) that's proving hard to
> find. Nothing has been located that looks like the drawing, which
> resembles a masthead turning block and I think a conventional block
> shackled to a stout padeye would do. But after pouring over
catalogs,
> the right block as remained elusive -- except with a price tag of
> $200 or more, and I've built entire boats for less. Here's what's
> needed: A rather large block with a 3-inch or so sheave. The sheave
1/4-
> ton. If the block comes with its own baseplate, it should take at
> least 1/4-inch bolts.
> Gary Blankenship
cold
> to paint!
The design of the lifting keel for my rebuilding project calls for a
shackled to a stout padeye would do. But after pouring over catalogs,
probably should be metal and probably should also be grooved for 1/4-
Gary Blankenship
Tallahassee, FL, where it's not only too cold to epoxy, it's too cold
to paint!
