Re: [bolger] Updated Micro scantlings?
Pippo,
I'm happy to see that you're not considering to abort your proyect, even
being so short of time. Congratulations and... coraggio!
About the scantlings, I agree with Eric S., it has to do with the
intented use. I will put a double bottom in my micro (totalizing 6/8"),
because I want to be able to make 100 miles long runs, in a sea (the
Mediterranean) that is usually quiet, but can quickly show his claws,
with short-steppy waves. In those conditions, you'll need good solidity
(material & skill), but also, very important, you'll need peace of mind!!
P.C.B. (polychlorinated biphenyl, if I trust in my dictionary), says
about of some of his designs something like: "it will behave well in a
storm... if it held together...
Now, getting surprised by storms in the Med, Phil knows it well, and he
recomended me a 1/2" bottom, so I'm probably overkilling here.
Peter L., I like the micro-claus idea, but then, please, came to Spain
and give some presents (work) to my boat during the night :-)
Francisco
...being sorry my wife (english teacher) is not here to correct me...
Francisco
> Hello everybody. I was wondering whether PCB has updated the Micro
> scantlings...
Pippo,
Any guy that has a spyglass as big as the one you show on your
web page just has to be a perfectionist!Afterall,I would imagine that
the absolute very slightest movement from down at your end results in
a shift of light years at the other end,no?You can't fool us
Bolgerites for long!:-D
Sorry to hear that in optimizing your time you have only allowed
yourself 30 minutes per day for your Micro.Equally sorry that you
live so very far away as there is no way I could just sneak over
during the night,pry open the door to your shop and do a bit of
building while you sleep.Imagine the look of absolute surprise and
delight on your childrens' faces(not to mention the look of utter
shock on your wifes' face!)when you proudly show them all the progess
being made on your boat,while you sleep,by MICRO CLAUS!I'd even wear
red overalls.........
Continued success,even if it is only 30 minutes per day,with your
Micro construction!!
Peter Lenihan,sensing the early symptoms of cabin fever which each
passing day,on the banks of the frozen St.Lawrence.....
--- Inbolger@egroups.com, "Giuseppe Bianco" <pippobianco@t...> wrote:
> Hey there! I'm not such a perfectionist... I wish I was though. I'm
> trying to optimize my time... Right now there's no way to do epoxy
> work in the garage, nor I have time to go downstairs for more than
30
> minutes at a day... I'm sure I'll launch within this century
> though... provided I could hand over the project to my kids ;-)
> Cheers, Pippo
> P.S.: nice girlfriend Peter!
> > Also,since Pippo is such a perfectionist,I was just worrying
> > that
> > he will not get to experience the bliss of sailing his Micro
before
> > 2002(or even 2003!) if he fusses too much over such details.I
> suppose
> > he wasn't kidding when he chose to call his web site"The
> > Ultimate....."
work in the garage, nor I have time to go downstairs for more than 30
Cheers, Pippo
Cheers, Pippo
> Also,since Pippo is such a perfectionist,I was just worryingsuppose
> that
> he will not get to experience the bliss of sailing his Micro before
> Ultimate....."
Hello Marco,
Grazie tanto per i tuoi complimenti pero posso scrivere un poco
l'Italiano perché la mia bellicisma fidanzata e d'origine
Italiana.I
sui genitori sono di Campobasso provincia di Casacalenda.
I guess that pricing varies;up here epoxy is $185.00 per gallon
and MDO 4 X 8 about $54.00 per sheet.Depending on the weight of the
cloth,alot of epoxy could be needed.
that
2002(or even 2003!) if he fusses too much over such details.I suppose
Ultimate....."
Good luck with your construction!
Tanti Saluti,
Peter Lenihan,with apologizes to our unilingual Bolgerites,from the
banks of the St.Lawrence..........
Italiana.I
that
Ultimate....."
Tanti Saluti,
--- Inbolger@egroups.com, Marco Vinicio Masoni <masoni@t...> wrote:
> Hi Peter,
> I want to tell you two belongingses:
> 1) epoxy is expensive, but also two layers of ply implicate the
use of much
> epoxy.
> 2) your Italian is very beautiful and poetic, compliments!
> Marco
> In 11.47 11/01/01 +0000, hai scritto
> >Hi Pippo!,
> > I do not own an updated plans set(if one exists) for the
Micro,but
> >I would be inclined and highly recommend going with the thicker
> >bottom.Your 10mm is nice,13mm would be better(!).However,I would
feel
> >comfortable with Marcos' suggestion,puo usare statidi tessuto di
vetro
> >pero questa maniera sara pui costosa perché epoxy!
> > The chine logs on the plans do seem a bit on the small side so
if
> >your available dimensions in wood are a bit bigger,use it.
> > Sincerely,
> >Peter Lenihan,glad he went with a thicker bottom,on the Micro,here
on
> >the Banks of the St.Lawrence.............
> >--- Inbolger@egroups.com, "Giuseppe Bianco" <g
iuseppe.bianco@a...>
Micro
> >> scantlings so, if anybody has recently purchased a set of Micro
> >plans
> >> from PCB directly, I'd like to know:
> >> 1) bottom thickness
> >> 2) section of chine logs
> >> 3)any other major update
> >> I haven't put the bottom on yet and given my terrible shortage
> >> time I'm having double thoughts on the double thickness
bottom...
So
> >> maybe 10 mm single thickness would be enough, eventually adding
> >> shoes as suggested by Bernie Wolfard.
> >> Thanks and best
> >> Pippo
> >Bolger rules!!!
> >- no cursing, flaming, trolling, or spamming
> >- no flogging dead horses
> >- add something: take "thanks!" and "ditto!" posts off-list.
> >- stay on topic and punctuate
> >- add your comments at the TOP and SIGN your posts
> Laboratorio di Psicologia Dott. Masoni
> Via Stromboli,3
> 20144 MILANO - Italy
> Tel. 02 43911114 - 0347 7153486
> Fax. 0243318224 - 0247716682
> email: masoni@t...
> "Perciò saranno tutte soltanto nomi Le cose che i mortali hanno
> stabilito, persuasi che fossero vere" (Parmenide 8, 38-39)
Hi Peter,
I want to tell you
two belongingses:
implicate the use of much epoxy.
Marco
for the Micro,but>>Hi Pippo!,> I do not own an updated plans set(if one exists)
feel>bottom.Your 10mm is nice,13mm would be better(!).However,I would
vetro>comfortable with Marcos' suggestion,puo usare statidi tessuto di
epoxy!>pero questa maniera sara pui costosa perché
small side so if> The chine logs on the plans do seem a bit on the
it.>your available dimensions in wood are a bit bigger,use
Sincerely,>
Micro,here on>Peter Lenihan,glad he went with a thicker bottom,on the
<giuseppe.bianco@a...>>the Banks of the St.Lawrence.............>>>>--- In bolger@egroups.com, "Giuseppe Bianco"
the Micro>wrote:>> Hello everybody. I was wondering whether PCB has updated
Micro>> scantlings so, if anybody has recently purchased a set of
shortage of>plans>> from PCB directly, I'd like to know:>> 1) bottom thickness>> 2) section of chine logs>> 3)any other major update>> I haven't put the bottom on yet and given my terrible
bottom... So>> time I'm having double thoughts on the double thickness
adding the>> maybe 10 mm single thickness would be enough, eventually
posts off-list.>> shoes as suggested by Bernie Wolfard.>> Thanks and best>>>> Pippo>>>Bolger rules!!!>- no cursing, flaming, trolling, or spamming>- no flogging dead horses>- add something: take "thanks!" and "ditto!"
>- stay on topic and punctuate>- add your comments at the TOP and SIGN your posts>
- Laboratorio di Psicologia Dott. Masoni
- Via Stromboli,3
- 20144 MILANO - Italy
- Tel. 02 43911114 - 0347 7153486
- Fax. 0243318224 - 0247716682
- email: masoni@...
- "Perciò saranno tutte soltanto nomi Le cose che i mortali hanno
- stabilito, persuasi che fossero vere" (Parmenide 8, 38-39)
Hi Pippo!,
I do not own an updated plans set(if one exists) for the Micro,but
bottom.Your 10mm is nice,13mm would be better(!).However,I would feel
comfortable with Marcos' suggestion,puo usare statidi tessuto di vetro
The chine logs on the plans do seem a bit on the small side so if
Peter Lenihan,glad he went with a thicker bottom,on the Micro,here on
--- Inbolger@egroups.com, "Giuseppe Bianco" <giuseppe.bianco@a...>
> Hello everybody. I was wondering whether PCB has updated the Microplans
> 1) bottom thickness
> I haven't put the bottom on yet and given my terrible shortage of
> time I'm having double thoughts on the double thickness bottom... So
> maybe 10 mm single thickness would be enough, eventually adding the
> Thanks and best
> Pippo
Ciao Pippo,
io
ho usato un solo foglio di ply da 10 mm. Conto di aggiungere due
strati di tessuto di vetro. Il fondo dovrebbe così
raggiungerer la resistenza pari a quella di uno strato di
compensato da 3 cm.
( Guarda che come consulente ho un bravo costruttore!)
riciao
Marco
In 12.22 10/01/01 +0000, hai scritto:
Micro>Hello everybody. I was wondering whether PCB has updated the
plans>scantlings so, if anybody has recently purchased a set of Micro
of>from PCB directly, I'd like to know:>1) bottom thickness>2) section of chine logs>3)any other major update>I haven't put the bottom on yet and given my terrible shortage
bottom... So>time I'm having double thoughts on the double thickness
the>maybe 10 mm single thickness would be enough, eventually adding
posts off-list.>shoes as suggested by Bernie Wolfard.>Thanks and best>>Pippo>>>Bolger rules!!!>- no cursing, flaming, trolling, or spamming>- no flogging dead horses>- add something: take "thanks!" and "ditto!"
- Via Stromboli,3
- email: masoni@...
scantlings so, if anybody has recently purchased a set of Micro plans
1) bottom thickness
Thanks and best
Pippo
1) bottom thickness
Thanks and best
Pippo
