Ataraxia
Speaking of Ataraxia, (see "Open Mind") has anybody run across this
boat recently, or have a report on how she's doing? Is she living up
to her "breakdown-proofing?"
John
John
Does anyone have any pictures of Ataraxia, the dipping lug motorsailer
shown in BWAOM?
Celticnavigator
shown in BWAOM?
Celticnavigator
In a message dated 11/24/01 4:23:10 PM Central Standard Time,
welshman@...writes:
in Corsica for an experimental oyster rearing project. We ran the beast at
near full-load, 24 hrs. a day, 7 days a week, for nearly a year, shutting
down only to check the oil, re-fuel, oil-and-filter changes and some other
small routine stuff that I've forgotten. It never gave a minute's worth of
trouble in that time. (The project collapsed before the engine gave out.)
However:
1) Was it ever NOISY!!! I think the cooling fins may have amplified the
normal diesel racket. The cooling fan might have contributed its part. In
any case, the beast was LOUD!!! About the only ambient sound I could hear
within 50'-100' of the beast were the occassional Mirages making high-speed
low-level training flights over the lagoon. If I was in the vicinity and
someone wanted to get my attention I either had to notice visual signalling
or the unfortunate had to enter the ZONE OF NOISE and tap me on the shoulder.
I can't recall if it was a Deutz, or something else, but I would guess the
noise situation is pretty much inherent in the type;
2) It processed a lot of AIR! I have no idea what cfm the fan was blowing at
full chat, but, if memory serves, the blower intake was approx. 12" in
diameter and it certainly pulled a significant draft. This would pose some
problems in the confines of a small boat:
a) It would have required intake and outlet ducting something in
excess of 115 sq. in. cross-section - providing two great channels for
ducting noise where it wouldn't be welcome, and
b) providing two big holes to let water into where one would least
want it to go.
3) The beast got pretty darn HOT! This is a pretty subjective observation, as
water-cooled blocks also get too hot to touch, but the cooling fins seemed to
be hotter than anything my "dermal thermometer" had encountered, short of the
exhaust pipe on a motorcycle. (PSSSTT!!! :-(o)
Ataraxia's design addresses these issues - but it is a pretty big boat. I
think the smaller the boat, the greater the difficulty of making an
air-cooled diesel an unobjectionable companion.
Ciao for Niao,
Bill in MN
welshman@...writes:
> The hot air by product might be a pain to get rid of in the tropics,A long, long time ago, I "baby-sat" a three cylinder air-cooled diesel genset
> but in my part of the world it would be welcome.
However:
want it to go.
Ciao for Niao,
Bill in MN
--- In bolger@y..., Steven Geoffrey Keating <sgkeating@m...> wrote:
we use them to run the hydraulics and compressors on drill rigs .
ambient temps of 55 Deg celcius are not uncommon. They are very
popular when sending rigs to remote 3 rd world jobs because they tend
not to break down much . This may be why they are usually 50% more
expensive. Good inlet space and good insulated outlet space is
important. Mind you I'm talking 3-10 litre straight 6 to v12's. Our
small rigs used 2 and 3 cyl units with never a breakdown. I always
thought an old v12 with its aircraft type air intake would look
pretty amazing in an old dodge or inter 6 tonner.
keep your pet budgie away fromthe air inlet !!!
I think they would be an excellent choice in a boat, a lot less fuss
Cheers Paul
> Has anyone seen images of the sailing lugger, Ataraxia, built byStory
> Boat building and featured in BWAOM?I've worked with air cooled Duetz motora alot.
> This is an interesting concept.
> How well do air cooled diesels work?
> Steve
Cheers Paul
One of PCB's designs in MAIB in the recent 2-4 years was for a long range power cruiser with a Deutz
oil cooled diesel. This is essentially an aircooled diesel, because a radiator is used to cool the
oil. Deutz also has pure aircooled diesels. It makes for simpler systems, because you don't need
water pumps and through hulls. The hot air by product might be a pain to get rid of in the tropics,
I have given a lot off thought to a Wyoming with a pair of 50 hp Deutz diesels coupled to DBD drives
http://www.dbdmarine.com/
Light weight, shallow draft and fast, get way up the rivers and shallow bays.
> Steve
Sorry miss typed, I'm NOT familar with Ataraxia.
Andy
Andy
the Canadian Navy and I can discuss your diesel engine concerns. We
use small 1 and 2 cylinder air cooled diesels to run our emergency
fire pumps and air compressors. I have found they work great. One of
the biggest problems we have is a lack of use but that should not be a
issue for you. Engines that sit around to long with out being turned
over can seize up. If you have an overheating problem you could
always place a heat sink(piece of metal, alimunum good and light) in
front of the engine fan as long as the heat sink is in direct contact
with the outer hull is should stay quite cool.
Andy
> Boat building and featured in BWAOM?Steve, I'm familar with Ataraxia but I am a Petty Officer Engineer in
> Steve
Andy
Has anyone seen images of the sailing lugger, Ataraxia, built by Story
Steve
Steve
Gary, I've looked at the picts in the wing keel file, how about putting up
a picture of the boat? Clyde
> --- Inbolger@egroups.com, "mark " <jensenms@h...> wrote:
> > Looking through Boats With An Open Mind I find myself returning to
> > the Ataraxia design.
I saw the boat at the Montgomery boatyard in 1993. Owner Dave O'Neill
was still finishing the interior and fitting it out, and I don't think
the mast was on board. Other than some details (Dave complained some
of the counters had been installed at the wrong height) he was fairly
well pleased. My best recollecton is the interior was well laid out,
roomy and comfortable. Some of the mechanics, such as the engine
arrangement were unusual and depended that Dave was a brilliant
engineer. It had twin deisels, mounted faily high in a well ventilated
engine room in the sterm, conected to the drive shafts with belts. I
recall we had a discussion about rigging it as a balanced instead of
dipping lugger. It was quite a jump down from the deck to the dock!
Sorry I can't recall more. I think I have a picture of it somewhere. .
. . I'll see if I can dig it up....
Gary Blankenship
Tallahassee, FL
> Looking through Boats With An Open Mind I find myself returning toan
> the Ataraxia design. As I recall, Bolger said the article was for
> upcoming publication on reliability. If I remember right, the boatMark:
> was built by Story (sp?) boatbuilding somewhere in MA.
> Has anyone ever seen the boat or heard how the design worked?
Gary Blankenship
Tallahassee, FL
Peter Vanderwaart wrote:
"Resolution" real soon now as a motor boat. Susanne has some changes she
wants to make before Resolution is for sale. I slept aboard Resolution
and she's pretty neat.
Resolution might be a heck of a deal if she's what you want and you live
near Gloucester or if you'd like to cruise home from Gloucester.
Phil Smith
>I've heard from Phil and Susanne that they will probably sell
> > Are there any other Bolger designs that were of the low tech, high
> > reliability, seaworthy long distance power or motor sailer(or?)
> > cruising type?
> Yes, several, depending on time and budget. And, of course, your
> particular definition of low tech and high reliability.
> PCB showed plans in MAIB for a long distance power cruiser (named
> Tahiti, as I recall) of about 35'. In the issue that I received
> yesterday, he showed the tender designed for it, and said the
> building of the prototype was proceeding.
> It seems to me that he showed another ocean-crossing power cruiser
> about the same time, but I don't remember the details. He has
> designed a number of power boats with ocean crossing potential. I
> would work out your performance/cost profile and ask him directly.
> On the motorsailer front, the first things to come to mind are the
> Solution 48 (imagine a very big, steel Teal), the Loose Moose (aka
> Advanced Sharpie 39) which was designed for power in canals and sail
> on the high seas, the Double Eagle catamaran (and variants). And of
> course, his own Resolution.
> Peter
> - no flogging dead horses
Phil Smith
> Are there any other Bolger designs that were of the low tech, highYes, several, depending on time and budget. And, of course, your
> cruising type?
the Ataraxia design. As I recall, Bolger said the article was for an
cruising type? (I'll take a breath after reading the last out
loud.)
Thanks to all for the posts -- it is always a treat to read this
group.
Mark Jensen
O'Fallon IL
loud.)
group.
Mark Jensen
O'Fallon IL
