Re: [bolger] CAMP CRUISER CONCEPT
The latest issue of Messing About in Boats has the goldplater version
of this boat in the Bolger column.
Ron
On Sun, 28 Jan 2001 00:27:47 -0000, you wrote:
>The drawing below is a design by Philip Bolger; he describes it as a
>Camping Cruiser Concept.
>http://www.tomah.com/delliott/campcruiser.jpg
>Here's a list of the main points that he incorporated into the design.
> 1.Low freeboard for good rowing.
> 2.Room in the cockpit for a single camper.
> 3.A small cockpit to allow for a stiffs knockdown without
>swamping the boat.
> 4.Overhangs at the bow and stern.
> 5.A short waterline.
> The following is some thoughts on studying the boat.
>On point no 1; low freeboard this also reduces the windage and makes
>the wide coaming a necessity (to keep water from coming the boat),
>under those coamings would be a good place to put some floatation.
> The narrow beam (4 foot 4 inches) allows easy righting of the
>boat in event of a capsize.
> Both the rudder and the off center board are of a kick-up design,
>allowing worry free cruising in shallow water.
> The long cockpit permits the crew to move fore and aft with ease.
>Ample dry stowage is provided for with large fore and aft
>compartments with hatches. The spray rail keeps fast moving water out
>of the forward hatch and the cockpit.
> The Gunter sail rig allows a short mast while providing good
>windward performance.
>The sharpie is shown at 18 feet to qualify for the e-group, it was
>designed at 19 feet.
> Mr. Bolger says this about the sharpie:
>"Sharpies need enough rocker in their bottom profiles to show long,
>low over hangs. Otherwise they're slow because of eddying around the
>forward chine, and drag at the corners of the transom. They also have
>to turn quickly since they don't have much momentum, and keeping the
>waterline short makes for easy swinging. In smooth water, the short
>waterline saves wetted surface, while the low overhangs produce a
>long waterline as the boat heels or meets waves."
>Not many things slip by this designer.Don
>I've also posted this same post on my new e-group site,Smallboats,
>Http://groups.yahoo.com/group/Smallboats. This e-group will have more
>on the smaller designs of Mr.Bolger and other designers. Come over
>and take a look. Don
>- no flogging dead horses
swamping the boat.
