Re: [bolger] explanation please
In a message dated 01/28/2001 7:<BR25:<BR52 AM
Eastern Standard ,pcman@...writes:> Transom Angle 15
degrees
measured from a normal to the waterlines.
The deadrise is shown in the body sections, and is measured from the
waterlines there. It is the upward slope of the bottom from the center or
keel, out toward the chine or turn of the bilge.
You might find a basic text on lofting to be interesting, as it shows how the
three major sets of lines (waterlines, buttocks, and station lines) plus one
or more additional lines such as diagonals are established.
Lofting isn't difficult, and even if you don't intend to do any, learning
about the process will allow you to understand a lot more about hull shapes
that you see *everywhere*!!!
Cheers/Carron
degrees
> Hull Deadrise 21 degreesYou've got it right, the angle is the one you see in profile, and it is
> i beleive that the transom angle is the angle that the rear of the boat
> should be but im not sure
Cheers/Carron
well explained
now to get to work
cheers
now to get to work
cheers
Sent: Sunday, January 28, 2001 11:48 PM
Subject: [bolger] Re: explanation please
> Good Morning Fred O'Neill,
> Hull deadrise refers to the angle in which the two bottom
> halves(port and starboard) are raised relative to the baseline(that
> deadflat horizontal line from which elevations are measured).Best seen
> by looking at a section drawing instead of the profile.Sort of like a
> giant V shape where the apex(bottom of the V) is the keel;either very
> shallow(low angle) or very steep(high angle)
> Transom angle refers to how far back the transom"leans" away from
> straight up-and-down.This is usually a backward lean but may also be a
> forward lean,as in a reverse transom which leans forward.
> Hope this helps!
> Sincerely,
> Peter Lenihan
> --- In bolger@y..., "Fred Oneill" <pcman@g...> wrote:
> > hiya all
> > can someone explain to me the following terms
> > Transom Angle 15 degrees
> boat
> > cheers
> > pcman
> - no flogging dead horses
Hope this helps!
Hope this helps!
> hiya all
boat
> cheers
> pcman
hiya all
cheers
pcman
cheers
pcman
