Re: [bolger]
I think the notches will be necessary to get the chine in the correct place. Or on the Light Schooner are they attached to a panel first??
If you cut the notches a bit oversize, then you can use wedges or better yet temporary blocks screwed to the sides of the frames to hold the chine log just where you want it,- a nice fair curve. Then after attaching the planking, remove the wedges/blocking and fill with googe.
If standing water and rot are a concern, make the notches way oversize and leave them open as limberholes. Course then you would want the top of the chine beveled or sloped with a fillet to drain off any standing water, and then......
Rick
David Ryan wrote:
>      In building Bolger's Light Schooner, thinking about cutting out the notches at the corners of the frames to take the chine logs
It seems to me that a sloppy fit- a slightly oversized notch-
>should not harm the strength of the hull.
 But you must have them for the the log. It's pretty easy to
get them close enough. I used hand saw to make sure I went slow
enough to do it right.(Well, pretty right. Right enough.)
