Re: Filler
Bill,
I usually squeegee on a thin scrim of epoxy thickened with
microballoons as my second-to-last (penultimate?) epoxy coating prior
to painting, when using glass cloth. As you have already applied
paint, your best option is to get a sanding filler compatable with
the paint you've used. I wouldn't apply epoxy on top of the paint,
it's too expensive and the paint bond will fail eventually, leaving
you with a mess to remove.
Good luck!
david (porky) galvin
--- In bolger@y..., Bill Wallace <wwostar@h...> wrote:
> I am not a bit pleased, even after efforts at filling and
sanding, to be
> able to see the weave of the cloth through the final coat of paint.
> What do you guys suggest as a filler? Someting to mix into
epoxy?
> Bill Wallace in Houston
You can add one of the very easy to sand fillers to epoxy, then trowel it on and sand fair after it cures.
Or use a high build primer.
Lincoln Ross wrote:
I guess it's too late, but some boatbuilders use 1 oz cloth or some
kind of non woven veil cloth on the last layer to hide the weave.
sanding, to be
epoxy?
- no cursing, flaming, trolling, or spamming
- no flogging dead horses
- add something: take "thanks!" and "ditto!" posts off-list.
- stay on topic and punctuate
sanding, to be
epoxy?
I am not a bit pleased, even after efforts at filling and sanding, to be
What do you guys suggest as a filler? Someting to mix into epoxy?
