Re: [bolger] Re: birdsmouth and oars?
In a message dated 2/14/01 7:07:59 PM Central Standard Time,
delliott@... writes:
Carron. the latest issue of MAIB (Feb, 15) has an article on the birdmouth
as applied to making oars
Now building these oars definitely looks like something requiring "specialist
skills"! Not only are they tapered, but the cross-section varies from round
at the loom to oval approaching the blade. These oars are definitely works of
art!
Bill in MN
In a message dated 02/15/2001 8:<BR50:<BR09 AM
Eastern Standard ,pvanderw@...writes:> It was one of two issues
that arrived in the mail yesterday: 2/1 or
> 2/15. - PHV
Can you tell me the width and thickness of the staves? Does it use an
inserted balde?
Cheers/Don Carron
It was one of two issues that arrived in the mail yesterday: 2/1 or
2/15. - PHV
> pvanderw@o... wrote:
> > > I find it interesting that the term 'birdsmouth' has become the
> > > standard terminology for this mast construction. (Also, oar
loom
> > > construction as per MAIB)
> Well, this got my attention.
> I just got the first of a pair of oars glued up using the
Culler/Michalak
> system. Still, I'd like to see how birdsmouths apply to oar looms.
I zipped
> over to MAIB and found no reference...plus the Search feature seems
to be
> down.
> Can you give a reference to the article, or is it in print only???
> Cheers/Carron
Just looked it up in the past issues and found a complete mathematical
description of the process. It written by Ernest Murphy, and it's called
"Mast making mathematics". Its in July 1, 1994, Vol 12, no 4. He calls the
construction method "Swallow tailed mast building.) This article came out
long before the one in Wooden Boat appeared. Don
Sent: Wednesday, February 14, 2001 6:54 PM
Subject: Re: [bolger] Re: birdsmouth and oars?
> > > standard terminology for this mast construction. (Also, oar loom
> I just got the first of a pair of oars glued up using the Culler/Michalak
> system. Still, I'd like to see how birdsmouths apply to oar looms. I
zipped
> over to MAIB and found no reference...plus the Search feature seems to be
> down.
> Cheers/Carron
> - no flogging dead horses
as applied to making oars. It's titled Hollow shaft spoon blade oars, by
Joel Herzel. Don
zipped
> down.
> Cheers/Carron
system. Still, I'd like to see how birdsmouths apply to oar looms. I zipped
down.
Cheers/Carron
