(15November10)This will complete the Sail Oklahoma 2010 messabout. The 1December issue will rerun the taped seam essay.
Sail Oklahoma b
SUNDAY IS DUCKER DAY!!!Well, first there was the great breakfast buffet in Mikes Boat Palace work shop.
Jackie and Mike made a great effort to get as many Puddle Duck Racers as possible to attend Sail Oklahoma. I think there were 13 or 14 on site on Sunday morning and maybe a few more arriving later in the day and on Monday although by that time others had already started home. I think part of the plan was to get enough together at once to qualify for next year's world championships. Anyway, a short walk down to the beach showed this...
All sorts of rigs and colors but keep in mind they all have the same lower hull shape. Here are some more...
Looks pretty early still with very light winds. It was about at this time that Gene took his new Piccup Pram out for its and his first sail. You can't get in much trouble in that wind, says I. And so it was.
The Duckers were going to have a real race. They had some other boats go out and anchor to define the course. I was on shore, too far away to get a meaningful photo. They mill about as racing sailboats do before the start and then THEY'RE OFF!! One boat lost its mast. I think there were some stumps just under the water out there that may have been a factor. But Brad in a Storer hull with a huge polytarp balanced lug rig with a 16 to 1 tack line tackle easily outpaced the fleet and won.
UP ON THE SOAPBOX...
Right here might be a good time to present some thoughts about racing in general. It seems to me that almost any sport that involves mechanical gear is hard to sustain over time. Any sort of racing, boats, cars, airplanes, and other sports like maybe shooting sports all have this problem. This is how I figure it. Someone makes up a new "class" that is supposed to be affordable and fun to everyone. Folks rush in and have a lot of fun. But in general only about ten percent can "win" both because of natural abilities and the inclination to advance their equipment. The equipment adavances, even if the basic idea behind the gear is simple and cheap, and in a season or two a fellow realizes he can't afford to keep up with the Jones's and drops out of competition. Each year a few more drop aside. Eventually the hard core get control of the class totally in that they start making the rules. And by then the competitors are all pretty good but there aren't many of them. Thus at Carlyle Lake, near me, the huge fleets of Sunfish are no more. No more fleets of sailing surfboards either and Dave Carnell once sent me a Wall Street Journal article about that failure. The article said that sailing surfboard technology advanced so quickly to keep up with the needs of the racers that after about 5 years it was impossible to buy a beginner's board, and apparently a good racing board is quite difficult to learn on. Anyway, the sport crashed, at least around here.
I think by tradition "one class" sail racing has relied on very strict control of the equipment to the point where you must buy your hull from this guy only and your sails from that guy only, and that usually doesn't make for an inexpensive sport. PDR's aren't there yet but I don't think any other class ever avoided the problem. It is supposed to be a cheap build your own boat thing but I don't see how you could avoid the situation where someone say makes a mold and starts producing carbon fiber hulls that fit the rules. Or something like that, where it fits the rules but is quite expensive and with a technical advantage. As for hull costs it would be quite easy to control by putting a generous minimum weight on a hull, say 100 pounds or maybe even more so that a fellow could build a solid hull from ordinary 1/4" plywood. Fancy superlight hulls would not be obsolete since they would have to carry weights to make up the difference. But the sailrigs would be another story, much more difficult to govern.
To me the only solution is to use the "claiming race" setup where anyone can buy any boat in the race before a competition for a set price. So let's say we do that with a $500 claim price. No one would spend over $500 building anything, or actually anything close to that in reality. This is done in horse racing apparently all the time. I've read it was done in sportscar racing in the 1960's. I first saw the idea in my youth when some were trying to prevent an arms race in gokart racing, but that sport crashed too. The claiming race idea is not something that could be started after the racing experts have gained control.
I don't see how any sport requiring equipment can avoid this problem. To the point where I think the only solution is for the promoter to keep a close eye on the stage of development and just when the thing is about to burst expensive, invent a new class. Well, PDR's probably aren't there yet. I don't get involve in PDR forums and such and don't know what folks are thinking. So I'll step off the soapbox...
I SPENT AN HOUR OR TWO...
...sailing the Welsford PDR that Mike Monies had built. It was in light winds, no chance of going over for that reason. PDR's really are fun to sail. This one responded instantly to the tiller, spinning right around from tack to tack, in smooth water at least. By my limited experience in this fine Welsford boat and some in Ken Giles PDR at Rend Lake these hulls can be a bit of a balancing act but not in the usual sense that you are trying to keep upright in a tippy boat. These aren't tippy but the bottom rocker is perfectly planned such that you can only sit in about one place to keep the transoms from either pushing water at the bow or pulling water at the stern. I suppose in normal goofing off it doesn't matter. But I would think perfect form would require the trimming act, made more difficult by any ability to actually see the transoms from the skipper's seat. It might be done mostly by sound and watching the wake. But what do I know.
THEN THE GREAT MARSHMALLOW RACE OF 2010...
... This proved to be quite entertaining to those of us on shore. It's the reason Jackie had that handful of ducky trophies...
The idea was originally to turn loose a fleet of rubber duckies and have the PDR skippers gather them afloat with simple cheap bait nets that were provided, but eventually it was realized that marshmallows floated just as well and would dissolve after a good while and not leave cleanup problem. So marshmallows it was. The light winds helped...
Even so some guys reefed since speed meant little and quick easy safe maneuverability meant a lot...
Here Kenny Giles shows proper form with the dip net but I think later, as equipment failure took its toll, it was found that a dip net with its handle broken off was a better device.
I don't recall who won but I know staying out as long as possible meant a lot since, as competitors came in with their catches, Jackie would rerelease them to the wild, thus providing more catches for those still agathering. It was a lot of fun.
AS SUNDAY PROGRESSED...
...there was more boat swapping and swamping going on. Here Kenny Giles tries out Stan Roberts' Piccup. And in the distance you might make out the only crash I was aware of. A new sailor had capsized Mike's take apart dinghy and with no buoyancy tanks there was no getting it upright. The Elegant Punt is sailing to the rescue but could only supply moral support. Eventually a SkiffAmerica came to gather up the swamped boat and swimmer.
Another picnic lunch overlooking the home beach this time. Folks were loading up their boats and heading home. This lake didn't get the Sunday afternoon traffic that we've seen at Rend Lake, which makes it somewhat important to get off the water by noon on Sunday. Still here new boats were arriving in the afternoon as owners who couldn't get the weekend off showed up for Monday. What's this? A new PDR still with wet paint and its sail rig never fitted before.
But most of us were flagging so it was back to the Monies spread for the supper buffet. Was that three different kinds of cobbler? More long chats and off to sleep.
MONDAY...
...and it's time to go for me. Mike drives me a ways north and we meet his kin for a quick lunch and then I am handed off for the drive home.
That's Michelle at the wheel now, Brandon flopping down in the back seat. The three dogs are still behind that fence. I forgot where our gear all went. Up to St Louis at flank speed now. I learn from Michelle all about the casino business in St Charles, Mo. I've learned three new careers this weekend. Approaching home their gps gadget picks the scenic way home through the darkness but that is OK. Then back into my truck for the final miles home. Finally the weather changes from perfect all weekend to driving through a squall line.
WELL, THANKS TO ALL...
... I certainly learned the meaning of "Southern Hospitality"!
Caprice
1dec09, Weight Problems, AF4Casa
15dec09, Ballast Again3, Raider
1jan10, Knockdown Recovery 1, RioGrande
15jan10, Knockdown Recovery 2, Caroline
1feb10, Emergency Flotation, Mayfly16
15feb10,IMB Capsize Test, IMB
15jul10,Texas200a, Mikesboat
15aug10,Texas200c, Cormorant
