(15Jan) This time around I'll review some thoughts about trailering homebuilt plywood boats. A lot of this stuff was learned by me the hard way trailering the Jinni for 15 years. Next issue, due out about 30 January, I'll continue along the same line with a essay about cartopping.
Left: BOB TAYLOR'S PIRAGUA
...WHEN TO TRAILER...
...TOW VEHICLE...
...TRAILER TYPES...
A low trailer is best.
...CUSTOM BUNKS...
...TONGUE WEIGHT...
...NOW FOR THOSE BUNKS...
WINCH POST
...GOAL POSTS...
...SIDE BUNKS...
...TIE DOWNS...
...LIGHTS...
...FINALLY.....
Piragua
I got this mail the other day...
Dear Jim,
A good friend of mine convinced me that I needed to build a boat this past summer, so he could borrow it. I had entertained the idea for sometime (except for the borrowing part) but could not decide what type of boat to build. I own a twenty four-foot offshore rig and was looking for something I could play around with that was "low maintenance". I decide on the Piragua for several reasons but I made a few changes and I hope you don't mind. I am sending a few pictures to you of the finished product and I want you to understand how extremely pleased I am with this boat.
You'll notice that I incorporated a slight crown on the fore and aft decks to help shed water. I also installed deck lids in the fore and aft bulkheads for access to the dry storage at each end of the boat. I used a scarf joint on the five millimeter Lauan plywood to hide the joint which required me to scarf pieces together for the fore and aft decks.
The structure was fastened with stainless steel ring shanked nails and epoxy. The bottom has one layer of fiberglass cloth for protection. All wood surfaces have three coats of epoxy and five coats of paint. I use the bow eye and aft cleat to secure the boat inverted to the roof of my Ford Bronco. A real eye catcher!
This boat was my first to build but won't be my last. I had a great time building the Piragua and will be doing it again next summer. My hat's off to you! The plans were concise and easy to cipher. I'm amazed at how straight this boat tracks in the water. Nothing like a canoe.
Once again, thanks for supplying me with your Piragua plans. I hope I did them justice and didn't offend you with the changes I made.
Bob Taylor
Bob did the plans justice and didn't offend me with his changes.
PIRAGUA, SWAMP BOAT, 14' X 33", 70 POUNDS EMPTY
I saw a genuine historic pirogue at a museum a long time ago. It looked like a big snack tray - not so much a hollowed out log as a hollowed out plank. Pirogues are great for poking around in swamps and ponds. They're a lot like canoes. Don't plan on standing up in one without practice and don't take one out in hard waves or wind. This one might float two men if they sit still.
The prototype Piragua was built by Don O'Hearn of Ferguson, Missouri, mostly for fishing.
Piragua should make a good electric boat. I did some electric testing with my Piccup Squared and a borrowed motor and battery. I clamped the motor to the stern with the mount's locking pin disabled to allow it to kick up if it struck anything. I clamped a control arm to the motor tube and used a long light push/pull stick, actually an old came pole with screw together ferrules that I had found somewhere. The control stick ran almost the full length of the cockpit and I could steer from anywhere in the boat. The control head stayed with the motor (the motor was not modified in any way) and was set to full power. From the cockpit the power was controlled by simply connecting the alligator clip to the battery. Docking was effected by pulsing the motor. It worked great! Full speed was about 4 mph with that boat using a 24 pound thrust motor. I did learn that the battery is probably a more important purchase than the motor. A good full size trolling motor battery might supply full power for almost two hours giving 6 or 8 miles range. The operation is totally silent, especially at reduced power. There is nothing like it.
And there is nothing to building one of these. It might be the easiest project in the catalog, maybe twenty hours of labor. Use lumberyard and discount store stuff. Two sheets of 1/4" plywood with nail and glue construction. Plans are $15. No jigs. No lofting.
Scram Pram, a 16' multichine Birdwatcher type, is being built near Savannah.
And Skat, a 12' cat boat daysailer, is being built near Phoenix. Latest word from the West Coast Spy is that the boat has been glassed on the outside and ready to flip and finish.
The Kansas Boat Psychologist keeps plugging away at his Fusebox. The bulkheads and transoms done. I'm leaving Fusebox in the Prototypes Catalog for now because it has appeared on at least three web pages.
I've started building the AF4 here in my unheated shed. I've been working at it an hour or two or three a day. It's been about five years since I built a boat and I'm a bit rusty. (One thing I'd forgotten was how much I enjoy building a boat! There I was banging and buzzing away at the project listening to the lady on the jazz station singing "Santa, I've Been Bad All Year".) I'm using lumberyard wood and exterior plywood, galvanized nails and Weldwood plastic resin glue. I had to quibble with a few of my dimensions. That's pretty normal and I've made those little updates to the drawings. I've raised the front edge of the motor slop well 2" to get a bit more room underneath and to better drain the well. I looked over my gas tanks and they all have the pickup along one edge so the tanks may acually drain better provided the pickup is on the low side of the slope.
I'm keeping a crude log. I started 13dec. Right now I'm 52 hours and $305 into the project. The basic hull is done! I can sit in it and sack out in the cabin so progress may slow a bit. We had a cold snap just when I was hoping to finish the bottom with the skids/stiffeners and epoxy taping the chines. (Bought some epoxy from Raka since nearby Wicks Aircraft has very few selections left.) I flipped the hull back upright and will get most details done. Maybe finish the interior since I can heat that area. Good news is that it weighs 225 pounds without the skids or cabin deck and detail parts and I think 300 pounds (less motor and gear) is quite within reach. Hoping costs will be closer to $400. About the only stuff left to buy is paint.
