(15NOV98) This issue will describe how I like to rig a lug sail. Next issue (about 1Dec) will start some essays about rowing.
HOUSE CLEANING NOTICE....In December I will have to start deleting the links to the past issues so that only the last 25 issues or so are listed. I will try to keep on file the few that I know have been linked to by other sites. The problem is that I have about used up the free storage that Apci gives me. I should be able to keep a year's issues stored for your use. That's enough.
Left: PAUL KRAYNIAK'S QT
OOPS!!!..
Before I get started with the rigging essay I should say that a sharp eyed reader spotted a mistake in my "Flat Pattern" figure for the Piccup poly sail shown in the past two issues. The errors are in the fuzzy little table that shows the radii from points A and B to the various points that describe the flat pattern. The radius from A to E should be 85.13 instead of 81.79, and A to F should be 170.01 instead of 107.31. Boy is my face red! Not the first mistake I've ever made and not likely the last.
BASIC BALANCE....
TYING ON THE SAIL...
HALYARD/YARD ATTACHMENT...
THE TACK LINE....
THE SHEET...
Nothing fancy needed here. Almost anything will work. Because the sail is balance already to a great degree the sheet forces are less than with other sail types. Because the tack is pulling down in the middle of the boom, the boom has less tendency to lift so downward pull of the sheet on the boom is of less importance. The location and lead directions of the sheet are of little importance also. It's another advantage of the balanced boom. By the way, if the boom is omitted to make the sail boomless, the sheet location is very critical and its needs change all the time. I think the boom is a great invention! The boom on a balanced lug can be quite light and still work.
SAILING ADVICE...
Also it should be mentioned that one of the most effective ways to trim the boat, helm-wise, is to rake the mast as required to move the sail area fore or aft. You can see that a small amount of rake will move the mast head quite a bit and the entire sail will go with the masthead. Old time boats had adjustable mast steps or partners. On my designs you can usually shim the mast partner on the bulkhead. It's one place where tinkering pays off. Making a mast a bit longer than shown on the plans is also almost always a good idea as it allows for this tinkering not to mention real life stretch of the rigging.
We'll start to discuss rowing.
QT SKIFF
LIGHT ROW SKIFF, 13' X 45", 75 POUNDS EMPTY
QT SKIFF
Paul Krayniak of Odessa, NY, built the prototype QT, his first boat, in a couple of weeks. Here is the letter he wrote me:
"Hi Jim,
Building Qt was very easy and a great learning experience. I have read Payson's books, so there were no real surprises in this project. As you know, I mostly used hand tools, and really didn't need much else, though the oar I built with a belt sander was quite a revelation. I used a rasp, handsaw and plane which were my grandfather's, so that added something to the experience. Altogether, including making oars and painting, I spent about 60 hours abuilding. I used polyurethane glue, which worked fine, but makes a real mess when it expands into foam, and costs more than epoxy. She was painted with alkyd porch and deck enamel, which gives a very nice finish and should be extremely tough (according to the salesperson). The plywood was AC exterior, the other wood was yellow pine. If I were doing this project again, I would use fir instead of pine, the Weldwood glue as recommended by you, and latex paint since the alkyd takes a long time to cure. Also, I think Grandfather's memory has been honored enough, and I would use a table saw and a belt sander for sure.
When I took QT to the water for her first trial, it was quite windy and I hadn't rowed for many years, so our path was pretty erratic. For the next trial, I adjusted the oarlock position up the oars an inch, moved their pivots two inches astern and adjusted my seat to get the level oars at belly button height, per your instructions. It was still pretty windy but the rowing went much better. The next time out, the wind was calm and we went for quite a long way, about 5 miles. I was very impressed with the small rowing effort required with this boat, and we covered the distance easily in about an hour and a half.
This testing was all done with my wife and me aboard. As I mentioned to you before, we are both big people. Frankly we had some doubts about quarter inch plywood holding us up, but it seems very sturdy and tolerates us walking on the bottom just fine. Also, we are able to change places and otherwise move around in her OK.
We tried putting our 70 pound grandson in with us and it didn't work well. If he sat in the back, the drag increased noticeably, and if he sat in the front, the stem was immersed and the drag was bad. Our impression was that she does best, given the limited places to sit, with two people of about the same size aboard. I'm sure, though, that all boats need to be balanced to do best.
The project has been loads of fun and the most satisfying thing I've done for years. Thanks.
Paul"
Later Paul reminded me that the idea behind his QT was first to have a boat to carry atop his motorhome.
He added, "QT fits very well on our motorhome. I made a simple bow holder from a short piece of 2x6 bolted flat to the roof. It has an outline of the wales routed into it, and I just hook the bow gusset over it. With lines running from eyebolts in the 2x6 to an eyebolt through QT's stem, it ain't going anywhere. The stern is fastened with lines down to the bumper braces and tied to the ladder to prevent lateral movement. The oars fit nicely with my fishing poles in a 10 inch square compartment which goes all the way across the motorhome. My wife and I can have her ready to travel or row in 5 minutes."
Well Paul certainly did an excellent job. One comment about his experience. Trimming you and your boat for level operation is very important as he points out. Always take the time to do it. I always give oarlock locations on my drawings but they are just suggestions and don't be shocked if you have to tinker with them to get the boat right. Often you can't tell if the boat is trimmed right without having an observer dockside to advise. If you are rowing solo or with passengers, you will need separate oarlocks for each configuration. When Paul tried to row with his grandson making a crew of three, it didn't work because the boy's weight ended up in the boats ends and threw off the trim. The usual solution would be to put the boy between the two adults, in the middle of the boat. But QT may not really be big enough for three, she's only 13' long.
Here are the QT words from the catalog:
"Flat iron skiffs are said to be easy to draw but very hard to get right. QT is my attempt at a flat iron skiff. The prototype was built by Paul Krayniak of Odessa, NY.
I chose a size that will be easy to cartop and yet ample for two adults. The bottom is narrow for good rowing but still wide enough to allow stand-up stability, unlike a dory. The top is wide enough for good spread of the oarlocks. The result is pronounced flare at the midsection. But if the flare is carried forward, the result will be extreme rake at the bow. So I twisted the first four feet of the side planks to reduce stem rake.
This is a simple nailed together job from three sheets of 1/4" plywood. No jigs, no lofting.
Plans are $20 and include a "bonus" blueprint of a yet untested straight tailed version for small outboard (maybe 5 hp max).
IMB: Click here to visit Tim Webber's page and see some photos of the Texas IMB under construction. Then poke around Tim's web page a bit. I heard this week from the Texas IMB builder who said,"I want to let you know that IMB is alive and looking good. She is now right side up and sitting on her cradle. Soon this boat and carrier will be mounted on the small trailer I have ready......"
Twister. Go back to the 30dec97 issue in the index to see this one. The Twister hull is pretty well cut and fitted, ready to tape. Walt lives north of Green Bay, working in an unheated shed. He tells me there will be no more building until things warm up again next year in late Spring. If you live up there and would like to contact Walt, let me know.
Jonsboat: A builder in Florida has started a stretched version of Jonsboat (16' stretched to 19'). This boat was featured in the 15 April issue.
Shantyboats (archived copy)
