(1JUN98) This issue will show the relationship between leeboard (centerboard, daggerboard, keel, etc) shape and performance. In the 15Jun issue I'll describe how I design the pivoting leeboards I like to use.
MIDWEST MESSABOUT NOTICE...
The 9th annual Midwest Homebuiilt Boat Messabout will take place at the Gun Creek Recreation Area at Rend Lake in Southern Illinois on June 13 and 14. Take exit 77W off I-57, head towards the golf course, and you'll see the signs. Lots of folks arrive on Friday and leave early Sunday. Electric hookups at most camp sites and the fee is $8 a night, which includes the ramp fee at this Corps of Engineers facility. There is also a Super Eight motel at nearby Benton.
There is no schedule of events. We usually have a pitch-in dinner on Saturday evening.
If you plan to attend, drop me a line by the end of May and I'll send you an update. (As I'm writing this several folks have responded. We should have at the meet my AF4 and Toto, Kilburn's Dory, a Woobo and a Piragua, a new Swamp Yankee canoe, a Peep Hen and a Micro, the prototype Fusebox, and at least one Brick. Haven't heard from all of the St Louis crowd (they never call, they just show up).
Left: ROGER'S SKAT UNDER CONSTRUCTION
This sort of analysis flies in the face of some designs. As mentioned earlier, the shallow keel can work very well if given enough area. But I've seen designs with "keel runners" or "chine runners" which I think are just small projections off the bottom. Given what we have seen here I don't see how they can work effectively. I've sailed boats with skids and external chines which approach those things but my boats always had leeboards or centerboards too. If you think the skids and chine runners are effective, you need only take one of my boats out, get close hauled, and raise the leeboard or centerboard to see what happens. You'll slide right off! I don't think those shallow keel and chine runners are effective. (I'd really like to try or see a good test on Matt Leyden's Paradox. That boat has chine projections and nothing else. MAIB ran an excellent series about making a Paradox but, after a year now, no completed photos or test results. My own feeling is that everything about Paradox is optomized for downwind sailing, something the designer is expert at. I'm not making fun of him - few of us have the patience and knowledge to do what Matt has done. But I'm not sure if the builders are aware of what Paradox's limitations might be as far as sailing to windward goes. At any rate, it seems to me that Paradox could be given a more weatherly rig pretty easily with an effective pivoting leeboard and a more balanced lug rig.)
NEXT TIME....
Now is a good time to explain the why's and how's of pivoting leeboards.
Cubit
ROW/SAIL CUDDY BEACHBOAT, 13' X 4'', 180 POUNDS EMPTY
CUBIT
This little jonboat sailer was the smallest "cabin" boat I could think up. The prototype was built to inexpensive perfection by Robert Smith of Pleasanton, California.
Cubit has a slot top cuddy cabin that I originally tried on a revamped Bolger Jinni and which has found its way into a lot of my designs because it has so many good features. This cuddy cabin is about as large as the one on my old Jinni. It's the minimum for one person to spend the night in, with the slot covered over with a bug net or a tarp or even fancy segmented hard covers. With the covers off you can walk around as you would in an open boat. In a knockdown the cabin provides buoyancy up high for self rescue. The cockpit will flood some. The mast steps offcenter and out of the path of the walkway slot.
The open cockpit is short - just enough for two adults. But for better balance it might be preferred that the second adult sit in the cabin. The use of the pivoting leeboard makes Cubit all people space. She has a balanced lug rig which economical, well behaved and surprisingly efficient. She spreads 74 square feet on 11 foot sticks and a 13 foot mast.
The entire boat is built of lumberyard stuff which includes six sheets of 1/4' plywood. If you've been reading slick boating magazines you may have no idea of how inexpensive a boat like this can be. With imagination and normal lumberyard and discount store materials, Cubit might be a $300 project including a polytarp sail (which works fine). This is simple nail and glue construction. Harold Payson wrote the bible on this type of construction in his INSTANT BOATS. Written in 1979, it's all still valid although most of us have gone to latex paints since then.
Plans are three blueprint sheets with basic keyed instructions for $25. No lofting or jigs required.
Anyway..... Anytime a design from the Catalog of Prototypes starts getting built I pull it and replace it with another prototype. So that boat goes into limbo until the builder finishes and sends a test report and a photo. Here are some boats in that catagory (although I been leaving most in the prototypes catalog).
Sportdory was not in the prototype catalog very long but there are two well underway. Both seem to have their hulls taped and getting their gunwales in place. These boats have no interior fitting out to do. But the painting comes next and that takes time. Check out John Bell's progress by clicking here .
Skat - the prototype Skat builder is Roger Palaski. Up until now he was a mystery man know to me only as "Roger", his Skat plans bought for him by someone else. Then I find out he has his own web page with the Skat construction photos on it! Skat is a small somewhat traditional 12' cat boat with a gaff rig. Even has a centerboard, the only boat I've ever designed with one! See Roger's progress by clicking here.
The Way Up North AF3 project by Herb McLeod has been launched. Says he built it in 70 hours although he had a sail and mast ready to go. I got this letter from him-
Launched the AF3 today and it should be on no suprize that it floats, does not leak and better yet sails beautifully. we had only light wind (5mph) but there was always a slight weather helm (a few ounces of pull on the tiller). The boat comes about well and I never got in irons (not even close). On a beam reach I was able to keep up to a Flying Junior that had one sailer and we had two and our dog in our boat. I did not have my compass so I could not check how close winded the AF3 is but the tacks seem to be about 90 degrees. I did not have to row much so I cannot comment other than the oars that I have (Barkley Sound cheapies) are klunky. The lee board works great stays down when in use and at the slightest touch of the bottom pops back up. When the boat is heeled to a comfortable angle the lower leeboard bracket just clears the water (nice design touch).
We took lots of photos so I hope that there is at least one good one in the bunch. I will send you a scan in a week or so as I do not have a scanner and have to send my photos by mail to my son in Victoria BC. He does the scans and then emails them back to me.
I am very very pleased with the boat and will write more as I get to know it better. We named this boat Shorebird as the shallow draft lets us explore the shores of our local lakes.
Herb McLeod
hmcleod@planet.eon.net
Get updates on Herb's progress by clicking here.
Concerning the Texas IMB that is under construction. Click here to visit Tim Webber's page and see some photos of the IMB as of a few weeks ago. Then poke around Tim's web page a bit.
Harmonica (ex Fusebox) is still being fitted out and painted. Plans to have it at the Midwest Messabout. By the way, Tim Webber, who has been sailing the Scram, says the roof and maybe the interior of a boat like this must be painted white to be cool in the summer. All of my boats were done that way and I've had no problem. But my own choice is offwhite. Pure white is just too hard on the old eyes in the bright sun.
Mother of All Boat Links Cheap Pages Eldritch Press Messing About In Boats Shantyboats (archived copy) Backyard Boats The Boatbuilding Community Kilburn's Sturdee Dory Bruce Builds Roar
