(15Jun99) This issue will show how I've rigged sharpie sprit sails on my own small boats. Next issue, 1Jul99, will have some thoughts about reefing sharpie sprit sails.
LARRY MARTIN'S FROLIC2 |
THE MAST...
THE SAIL...
MAST/SAIL ATTACHMENTS...
THE SPRIT...
But it can be overdone from a practical standpoint and here is why. On both Jinni and Birdwatcher I've had the snotter attachment break or rattle loose while underway. It only happens in bad conditions, of course. You need to repair it quickly because you won't have control of anything until you do. If the snotter attachment is more than chest high, you will be in danger at repairing it. Having to stand on a deck to effect the snotter attachment is a total no no as far as I'm concerned. You won't be able to do it in the bad conditions that caused the failure to start with. So that's why I place my snotter tackles somewhat lower than some other designers and builders.
SPRIT ATTACHMENTS...
I'll show some ways to reef a sharpie sprit sail.
FROLIC2
Plans for Frolic2 are $35.
RB42: This is an 18' rowboat meant for two. It's never been in any of my catalogs but the Canadian builder has it complete ready for paint. Imagine the Oracle shown in the 1may99 issue stretched to 18' and you have it.
Mayfly12: A Mayfly12 is going together up in Minnesota. The hull is ready for taping right now.
AF4B: A builder in Virginia is building AF4Breve, a 15.5' version of the 18' AF4. I tried to talk him into building the 18' version but he had two very good reasons to go shorter - a short trailer on hand and insufficient building space for the larger boat. The AF4B is essentially a "scrunched" version of AF4 but comes from a whole new set of drawings.
