(15May99) This issue will show ways of figuring sail area and finding the center of the area. Next issue, 1Jun99, will have some thoughts about making rudders for small sailboats.
MIDWEST MESSABOUT NOTICE...
The 10th annual Midwest Messabout will take place at the Gun Creek Recreation Area at Rend Lake in Southern Illinois on June 11,12, and 13. The usual routine is that some folks come on Friday and leave early on Sunday. To get to Gun Creek take Interstate 57 to exit 77 West, head towards the golf course on the south side of the road and follow the signs. This is a Corps of Engineers rec area with a $2 launch fee. Camping is 10$ a night and that will cover the launch fee. There is no schedule of events - we just wing it. Email me at michalak@apci.net if you have questions.
THE JAMES BROTHERS CAMPING OUT WEST, JEWELBOX AND PETESBOAT |
THREE SIDED SAILS...
FOUR SIDED SAILS...
RIGS WITH MANY SAILS...
I'll show how I make rudders for small boats.
HC SKIFF
HC SKIFF, SAILING SKIFF, 18' X 5', 450 POUNDS EMPTY
HC Skiff is a rework of the "typical sharpie skiff" that appears on page 101 of Howard Chapelle's great book AMERICAN SMALL SAILING CRAFT. I can almost say that if you own only one book about small sailing boats that this is the one to have. The lines of my version are straight from Howard's offset table. I found it all very interesting. For one thing it is by today's standards a long narrow hull, 18' long and only about 4' wide on the bottom. The stem (which is not quite vertical) rides an inch or so over the water, then the bottom goes more or less straight down to the deepest and widest point of the hull which is at about half the length of the hull. Then the bottom sweeps way up above the waterline for a very small transom indeed. There were working hulls. Heavy loads could be carried without immersing the transom, always harmful to a boat with no motor. You just put everything toward the stern and kept the stem just clear of the water. The fact that the widest and deepest point of the hull is at the halfway point should produce an all around better handling boat than one which has most of its beam towards the stern. I think the hull shape has a lot to admire and is little improved upon by any modern flattie skiff thinking. Chapelle says the shape was very common al along the East Coast from 1860 untill 1900.
I used more modern plywood construction on HC Skiff. The old ones were nailed together from 1" boards. Then they were left outside in the water until they died. They must have been very heavy both in their construction and soakage, not to mention the payloads of clams and oysters. My version uses five sheets of 1/4" plywood and five sheets of 1/2" plywood and will weight a lot less than the original. It's done with prefab parts and glue and nails, no jigs or lofting required.
I had to tinker with the sail rig which was of the same style shown here but at least 50% larger. On the old heavy boats that might have been OK but I'm sure it would be way too much for the lighter ply version. I kept the centerboard, large and effective. I added hull air boxes front and stern for a chance at self rescue after a swamping. I kept the large deadwood aft and barndoor rudder. Also added some seats (the originals had simply three thwarts and stern seating).
Plans for HC Skiff are $20 until one is built and tested.
Fatcat2: There is an old timer (80 years +) in Minnesota who has completed the hull of a Fatcat2. Fatcat2 is a simple 15' x 6' catboat, gaff rigged and multichined. The boat is totally done now, waiting for Green Bay to warm a bit.
Frolic2: I recently heard of two of these going together. One is in Oregon , hoping for an early summer launch. The other one is in Colorado, hoping for a late summer launch. The builder sent me this foto in which the boat's Toto heritage is evident. You can see he is using nylon wire ties to fasten the panels together instead of wire twists.
RB42: This is an 18' rowboat meant for two. It's never been in any of my catalogs but the Canadian builder has it well underway. Imagine the Oracle shown above stretched to 18' and you have it.
