(15Sep99) This issue is a rerun of last year's issue showing Herb McLeod's capsize tests of his AF3. Next issue, 1Oct99, will continue the topic with an essay about emergency flotation.
MESSABOUT NOTICE...
The 8th annual Lake Monroe Messabout will take place on September 24, 25, and 26 at the Paynetown State Recreation Area on Lake Monroe, about 10 miles south of Bloomington, Indiana. There is no schedule of events. Typically, people arrive on Friday evening or Saturday morning. The Messabout begins to dissolve Sunday afternoon. I hope to see you there but I'm not in charge of this one. Bob Bringle is at rbringle@iupui.edu.
ANOTHER MESSABOUT NOTICE...
Craig O'Donnell will be hosting his Sassafras Messabout at Betterton, Md, on September 18 and 19. Contact Craig at dadadata@friend.ly.net. (Craig told me this one is actually anti-organized.)
HERB MCLEOD'S AF3 |
AF3 Capsize Tests
This is a rerun of last year's 15sep issue which featured a capsize test done by Herb McLeod on his then new AF3. I want to keep this one up front because it demonstrates what you need to do when you capsize a sailboat which is not self righting, but rather is self rescuing. That is you can get it back upright and going again if you are properly prepared and if the boat, like AF3, has ample built in flotation or airboxes to keep it floating high on its side as you recover. A few things I'd like to point out. 1) Herb's tests were done in very benign conditions and if you capsize in really bad conditions recovery could be a lot more difficult or impossible. 2) If you tinker with a design such that you remove flotation or airboxes or enlarge hatches or move them off centerline, etc., the recovery system may not work and the boat may swamp to the point where you cannot recover. 3) If you have a design with no flotation or airboxes at all, such as most any traditional open boat, recovery is about impossible because the boat will swamp completely and be unstable even if it doesn't sink.
And now on to our story...
AF3 CAPSIZE RECOVERY...
"Hi Jim:
I now have 14 days of sailing in on the AF3. Alas, no pictures yet of it sailing on the water for the same reason as ever, no one else around to take a picture. Most days I am the only boat on the lake. Had one sail where we traveled 20 miles in one day. We did a 6.5 mile section that day in 1 hour 10 minutes with the small sail (69 square feet) on a beam to broad reach (lots of wind). Also managed to turn the AF3 on its side that same day. The AF3 floated well was easily uprighted, boarded and bailed out. Everything in the cuddy stayed dry and we managed to not loose any of our gear. But that is not what I am writing about....."
< WIDTH="400" HEIGHT="269">
< WIDTH="400" HEIGHT="302">
< WIDTH="400" HEIGHT="261">
At summer's end he wrote:
"Hello Jim:
Herb"
< WIDTH="342" HEIGHT="327">
Herb looks to have gone through all his tests without disturbing any gear because he had it well stowed. Very important. But a tight well secured fabric cover of the cabin slot would be a good idea in rough going. It should help keep a big wave from sloshing into the cabin and upsetting your day. You must remember that in the conditions that might cause a real capsize things will be a lot more trying.
I'll talk about emergency flotation placement.
PICCUP PRAM
< WIDTH="337" HEIGHT="361">
PICCUP PRAM, ROW/SAIL PRAM, 11' X 4.5', 100 POUNDS EMPTY
Here is another rerun, my Piccup Pram design. It was my first design to get built and I still have and use the original. It's had lots of sail rigs but the hull is totally unchanged over ten years. Sometimes I think I had beginner's luck with Piccup. Here is the write up about Piccup in my paper catalog:
Piccup Pram, the first of my designs to be built, was originally to be the best boat I could slide into the bed of my piccup truck. Now I cartop her exclusively.
< WIDTH="432" HEIGHT="498">
When I drew Piccup I had one eye on a Bolger Nymph and the other on a Herreshoff Marco Polo tender. For her size and weight she is very roomy and able to take rough going. The flat pram bow provides capacity equal to a pointy bow hull two or three feet longer. Her multichine shape gives soft shoulders which prevent waves from rolling her as they would a flattie.
Her balanced lug sail, now enlarged to 68 square feet, stows rolled up in the cockpit while her pivoting leeboard and kickup rudder raise instantly for rowing. These lug rigs can be built effectively from ordinary materials including discount store polytarps. Piccup will row 7 miles in two hours in calm conditions and will rig for sail in a couple of minutes if the wind pipes up.
Piccup has a flat bottom panel that keeps draft to 6" with two adults aboard, allows level beaching, and is big enough for a sleep spot. I've camped in Piccup many times. The ends have buoyancy/storage chambers of about 6 cubic feet each - enough for two or three days' supplies for someone used to roughing it. I don't take a rain tarp, being careful to camp on a no-rain forecast. The lug sail can be rigged as a rain fly to a certain extent. A bug net is mandatory.
Construction is taped seam 1/4" plywood, 5 sheets required. All parts are cut to the shapes shown on the drawings and pulled together with twisted wire loops. No jigs or lofting are required. Gaps and bevels are of no consequence. Seams are filled with putty and the wire twists are snipped off. Then the seams are locked together with fiberglass strips set in epoxy.
Plans for Piccup are $20.
Jonsboat: I suspect a few of these have been built but I've never gotten a report. Just got word of at least one more going together and hopefully we'll get a photo and a report.
RB42: This is an 18' rowboat meant for two. Herb McLeod up in Edmonton has it completed. Imagine the Oracle shown in the 1may99 issue stretched to 18' and you have it. Here is a photo of its first time out. In a few issues we'll have a full report. RB42 plans are $20 if you are interested. Six sheets of 1/4" plywood. Herb has completed his testing and tinkering and I'll write this one up as a "done" design next issue.
< WIDTH="400" HEIGHT="194">
AF4B: A builder in Virginia is building AF4Breve, a 15.5' version of the 18' AF4. I tried to talk him into building the 18' version but he had two very good reasons to go shorter - a short trailer on hand and insufficient building space for the larger boat. The AF4B is essentially a "scrunched" version of AF4 but comes from a whole new set of drawings.
