(1JAN99) This issue will finish the rowing essays with a couple of "how to's". Making a set of oars and a rowing seat/ditty box. Next issue (about 15Jan99) I'd like to update my "materials and tools" essay that comes with my plans sets.
A NEAT WEB SITE....Don Duquet, down in Florida, has a nice web site which features articles from the paper magazine MESSING ABOUT IN BOATS. And there is other stuff there. Click here to read his experience with building and using Toto. A fine tale (but I don't recommend testing a new boat on a windy day). Then poke around the site a while.
Left: DON DUQUET & CO WITH TOTO IN FLORIDA
MAKING SOME ROWING GEAR
But first, reader Lincoln Ross wrote a letter about my last essay:
"Just read your latest essay on rowing. While I agree with most of what you say, I think that sliding seats may be a little better than you're giving them credit for.
In rough water, those long oars can help you stay upright. I've been out in a recreational shell when it was rough enough to fill the footwell with water, and had no real problems. And the reduced windage is nice. I suppose the tied in feet could be a little tricky if you didn't wear a life vest. Where you do tend to flip is right at the dock. I've been out maybe 50 times and flipped, I think, twice. Both times right at the dock. Once next to a Charles River whitefish (ugh!). If you never let go of the oars you don't go over. Sliding seats let you use your largest muscles, so I think power output would be up for most people. It's a better workout. In a really skinny boat it's the only way to actually work hard.
Lincoln Ross"
Thanks much for the info. I agree especially with the comment that a long skinny fast boat will need a sliding seat to reach its top speed.
MAKING A SET OF OARS....
How long?? That's a tuff one and I avoid it by saying on each set of my plans I show the oars I recommend for the boat. All knowing Phil Bolger said in his first book, "Generally speaking, a good deal less than twice the spread of the locks will serve, and I'd prefer to have oars a little short of the ideal than much too long." I like to use 7 foot oars on good rec rowboats like Roar2 or a light dory that tend to cruise at about 4 mph. Slower boats can use shorter oars. I use 6-1/2' oars on Piccup which will cruise at 3 or 3-1/2 mph even though it has more than 4' between the locks. Short oars work well on larger slower boats too, for example 7' oars are fine for Birdwatcher and AF4. They probably move at about 2-1/2 mph. The idea that the longer the oars the faster you will go is simply not true.
Anyway, I'm going to show drawings for 7' oars which are about the most useful length for me.
WHAT KIND OF OARS....
The long narrow blades go against modern thinking of spoons, but for long rowing, long and narrow is the way to go. The average mortal can only pull so much of a load, in spite of what an Olympian might do. The Culler blades can match the mortal's pull. They might slip a bit when starting a heavy boat from a standstill, but once up to speed, the have full grip on the water. They balance better. They are less fatiguing. They have less windage. By the way, the oars of traditional Irish caurrahs have no blades on their oars. Neither do the paddles of some traditional kayaks.
WHAT YOU NEED...
For wood, I use 1x6 pine boards. The pattern shown in Figure 1 will just barely make an oar from a 1x6. I try to buy a single board long enough to get out both oars. For example, for a pair of 7 foot oars, I buy a board 14 feet long if I can. That way the oars will be a close match on weight, stiffness, and color. I like to use soft wood like pine, it is easy o work and makes a light oar. It need not be clear wood although clear is easier to work Small solid knots are fine and look good too. I've never worried too much about grain because the sticks get laminated and tend to stay straight. But the straighter the grain the better.
For glue I prefer plastic resin "Weldwood" glue and doubt if there is anything better for making oars. Pour some in a cup and squirt in cold water until it has the consistency of normal woodworking glue like "Elmer's. I've found it to be quite true that this glue will not set properly until it is at 70 degrees F for twelve hours like it says on the can.
Now let's talk tools. The tool I use the most in making oars is a bandsaw and I hate to say that because it's not a cheap or small thing that everyone will have. The problem is that you've got to saw a 2-1/4" thick blank. Hand saws will work and the effort should get you in shape for rowing. After all, oars were invented long before the bandsaw. But I see Dave Carnell has built oars using his table saw and Bruce ----- built oars with his sabersaw.
HOW TO BUILD...
first cut the 1x6 boards to the proper length. lay out the centerline with a straight edge. Then draw the pattern for the center piece, the one with the blade., around the centerline. Cut out the center lamination following the line closely with your saw, because the outer laminations of the blank are made from the off fall and there isn't much extra.
A ROWING SEAT/DITTY BOX....
I'll review the materials and tools I've used with my own boats.
BATTO
FAST ROWBOAT, 18' X 3', 70 POUNDS EMPTY
BATTO
Might as well finish the rowing essays with Batto. It's sort of a "retro" boat. Every now and then I go over another designer's older design and try to update it to the way I do boats. I always learn a bit.
Here are the words in the current catalog about Batto:
Batto is a close copy of the Pete Culler clipper bateau Otter which appears in John Burke's book PETE CULLER'S BOATS. Batto is only very slightly different in shape and size from the original Otter and is in no way intended to be a parody of it, only a reworking to the type of construction I prefer. Burke points out that the boat is about as close as you can get to a racing shell with traditional hull, and that it was unforgiving and cranky if improperly used and very elegant and fast if properly used. I would prefer it to be thought of an exercise boat meant for one. Supposedly Culler judged the boat to be safe to handle one third of a person by proposed Coast Guard regulations. I found Burke's book to be very good reading.
The big departure I've made from Culler's work is that I've used "instant" plywood construction, something that Culler didn't like at all. He had a long lifetime of experience with traditional methods and tools and materials by the time he built Otter and Burke says he built her in a one week vacation, with lapstrake sides, cross planked bottom, and all the gingerbread. In the photos it is a true work of functional folk art. Batto won't be in the same league as a work of art, but it should actually be a better boat by almost all other criteria. Built taped seam style with no jigs from 3 sheets of 1/4" plywood, Batto will be a 40 hour project for most any man and will be lighter and faster than the original.
Culler used very long special rowlocks to get the proper oar location in the very low and narrow hull. (You won't be able to stand up in it.) That replaced the need for outriggers which, I can attest to, are a pain for a cartop boat. I think the Culler locks are worth a try, if only because they can be easily removed and replaced. For that matter the boat would take a sliding seat very easily. I'm certain Phil Bolger would quickly point out that locks tilted 45 degrees like these aren't worth a hoot. And he'd say that the hull needs more rocker. But I guess that shows how two very experienced designers can have very different experiences. I know for a fact that the narrow Culler oars work very well although Phil never liked them.
Batto plans are $12 until one gets built and tested.
IMB: Click here to visit Tim Webber's page and see some photos of the Texas IMB under construction. Then poke around Tim's web page a bit. I heard this week from the Texas IMB builder who said, "I want to let you know that IMB is alive and looking good. She is now right side up and sitting on her cradle. Soon this boat and carrier will be mounted on the small trailer I have ready......"
Twister. The Twister hull is pretty well cut and fitted, ready to tape. Walt lives north of Green Bay, working in an unheated shed. He tells me there will be no more building until things warm up again next year in late Spring. If you live up there and would like to contact Walt, let me know.
Jonsboat: A builder in Florida has started a stretched version of Jonsboat (16' stretched to 19'). This boat was featured in the 15 April issue.
