(1Jun99) This issue will show how I've been making rudders for my own small boats. Next issue, 15Jun99, will have some thoughts about rigging sharpie sprit sails.
MIDWEST MESSABOUT NOTICE...
The 10th annual Midwest Messabout will take place at the Gun Creek Recreation Area at Rend Lake in Southern Illinois on June 11,12, and 13. The usual routine is that some folks come on Friday and leave early on Sunday. To get to Gun Creek take Interstate 57 to exit 77 West, head towards the golf course on the south side of the road and follow the signs. This is a Corps of Engineers rec area with a $2 launch fee. Camping is 10$ a night and that will cover the launch fee. There is no schedule of events - we just wing it. Email me at michalak@apci.net if you have questions.
Left: MARSHALL FOOTE'S SPORTDORY NEAR GALVASTON
RUDDER BLADE...
SINK WEIGHT...
RUDDER STOCK...
TILLER/HOIST LANYARD...
SHEET FAIRLEAD...
HINGES...
THE CARY HINGE...
Here is his description:
I'll show how I rig a sharpie sprit sail.
SCRAM PRAM
SCRAM PRAM, SAILING BEACHBOAT, 16' X 6.5', 500 POUNDS EMPTY
Scram Pram is an interesting boat that I designed for Wil Gordon of Houston a few years ago. He built the prototype shown above, including making that multicolored sail. Wil had owned some production pocket cruisers and had sailed in Karl James' Jewelbox. He wanted a huge rig all in one sail for moving in very light winds. We started the design process by enlarging IMB and it turns out that at least two Scrams have been built while the prototype IMB is still abuilding.
The lines show that Scram has a multichined cross section, like my Piccup Pram, and I've found that makes for a very fast and seaworthy boat. The top is built up like a Birdwatcher. Everyone sits inside, including the skipper. The boat can also be steered by sitting in the open top slot as shown in the photo. The top of the cabin has a slot that runs full length. If you sit to the side you are inside under the deck, but you can stand up in the middle. In bad weather the slot is covered with a snap-on tarp. If you have children this is a good boat type because they will never be on deck. If you use tinted plastic for the windows and a white hull, the boat will be cool in hot weather.
But the main advantage for the Birdwatcher cabin, invented by Phil Bolger, is that the crew sits low and the crew's weight acts as ballast, instead of making a boat top heavy as with a normal cruiser where you sit on a raised deck. Sometimes the effect is so strong that the Birdwatcher boat will be quite self righting with no ballast other than the crew weight. So you can get a nice light simple self righting cruiser. With Scram it didn't quite make it. In tests of the prototype, the boat was just barely self righting with a crew of one against the floor when the boat was rolled over 90 degrees by a rope attached to the masthead. But the design has water ballast tanks on the floor to take 300 pounds of water. With the tanks full the boat is so stable that the test crew had trouble rolling the boat 90 degrees with the mast rope. When released, Scram popped right up. The testing was done by Tim Weber of Houston and was written up in this web site last year. You can access the back issues to review. Tim felt that Scram would be OK with 100 pounds of ballast and that there was little need for more than 200 pounds.
A second Scram was built to prototype plans by UT Roberts of Savannah. His boat is shown above. UT's boat had two significant changes. He reduced sail area to 150 square feet from the original 170+. I made the sail shown in the photo and I feel it is quite enough, especially since the boat has a motor well built in and only 2 or 4 horsepower will push it fine on very light days. Very few people have the patience or time to sail in light flukey winds. Almost any boat this size will end up with a motor which will get used a lot. Then a huge sail rig is not the best thing to have. UT's boat also did not have water ballast. I think he has sand bags lashed below seating benches he has built in, a good option probably if the bags are very low down and very well secured. The idea of bench seating is nice but one must scope out the bench height very carefully to get enough headroom. As is, the water ballast tanks have a foot well. If I were building a Scram, and I would do so if I didn't already have 7 boats in the shed, I would build in the ballast tanks and use the smaller sail.
Scram uses taped seam construction with five sheets of 1/4" plywood, nine sheets of 3/8" plywood, and one sheet of 3/16" dark Plexiglass.
Scram plans are $35.
Fatcat2: There is an old timer (80 years +) in Minnesota who has completed the hull of a Fatcat2. Fatcat2 is a simple 15' x 6' catboat, gaff rigged and multichined. The boat is totally done now, waiting for Green Bay to warm a bit.
Frolic2: Good news on the Frolic2 front. The first one has been completed and sailed by Larry Martin of Coos Bay, Oregon, ahead of schedule. He reports an excellent first sail on a very rough day. He sailed from the dock downwind in strong winds and whitecaps, down the lake and beating back. (Larry is pretty experienced but I never advise testing of a new boat, especially of an untried design, in rough going.) We should have pictures in a few weeks. The other Frolic2 prototype is in Colorado, hoping for a late summer launch. Here is one of the latest construction photos. The outside seams have been taped.
RB42: This is an 18' rowboat meant for two. It's never been in any of my catalogs but the Canadian builder has it well underway. Imagine the Oracle shown in the 1may99 issue stretched to 18' and you have it.
Mayfly12: A Mayfly12 is going together up in Minnesota. The hull is ready for taping right now.
