(1May99) This issue will show some different plywood butt straps. Next issue, 15May99, will show how to figure the centers of sail areas.
WEB SITE NOTICE...
Craig O'Donnell at Cheap Pages has one of the best boating sites on the internet. He has recently added some more goodies. For example he has the complete online copy of H. Warington Smyth's MAST AND SAIL IN EUROPE AND ASIA originally published in 1906. Smyth travelled the world drawing and writing about the boats he saw at a time when England ruled the waves. And when men were allowed to write about boats like Smyth wrote about the Nordland Cod boat ---"The most feminine of boats, she demands a real man for her helmsman, who knows his own mind and has a strong hand to effect his purpose. Capricious, quick, seemingly, to betray her charge, she yet loves to be ruled strongly. It is only this she wants; and once she finds that she has her master, she will take him through the wildest winter night in safety, yet not without throwing more water than is either seemly or safe." We don't write 'em like we used to!
MIDWEST MESSABOUT NOTICE...
The 10th annual Midwest Messabout will take place at the Gun Creek Recreation Area at Rend Lake in Southern Illinois on June 11,12, and 13. The usual routine is that some folks come on Friday and leave early on Sunday. To get to Gun Creek take Interstate 57 to exit 77 West, head towards the golf course on the south side of the road and follow the signs. This is a Corps of Engineers rec area with a $2 launch fee. Camping is 8$ a night (I think) and that will cover the launch fee. There is no schedule of events - we just wing it. Email me at michalak@apci.net if you have questions.
DON DUQUET & CO. IN TOTO |
Almost any boat you build from plywood will require panels longer than the 8' lengths you will find at the lumberyard. For an "instant boat" the usual manner of joining the panels together to get one long panel is with a butt strap or butt plate. I've tried lots of different ways to make the joint in the 15 or so boats I've built over the years. All the methods worked. I have a feeling that the butt joints on the usual instant boat hull are not highly loaded and not too critical to overall boat strength. Since I've tried several ways and they all worked I've gotten to be pretty nebulous about the subject on my drawings. Lately I've been specifiying a butt plate as something like "Butt plate from 3/4" x 3-1/2" lumber, or equal" which doesn't tell you much. Most builders get by pretty well with just that but recently one builder asked what in the world I meant, and rightly so. So let's start the discussion with one joint I've never tried in plywood.
THE PAYSON TEAL BUTT STRAP...
THE BIRDWATCHER BUTT STRAP...
THE LUMBER BUTT PLATE...
This is what I like to advise now. Not much to it. Very quick and easy to make. Some say it looks too clunky for their tastes.
If there has been any structural problem with the above butt plate it is at the ends of a plate that joins bottom panels, ending short of the sides to allow a limber path. If the ends of the plate are not solidly glued and fastened to the bottom panels the butt plate will eventually loosen at the ends. I think that is due to the rapid change in flexibility in the system where the plate suddenly ends. A better solution might be to taper the end of the bottom butt plates starting maybe 3" in from the end of the plate and tapering down to maybe 3/8" thick at the ends. That will allow a gradual change in the flexibility and prevent a stress riser at the end of the butt plate. By the way, for any bulky butt joint care must be taken in design to see that the joints don't fail in places where the butt plate will be in the way.
I'll show how to find the center of a sail plan's area.
ORACLE
ORACLE, LIGHT ROWBOAT, 15.5' X 45", 80 POUNDS EMPTY
Oracle might have been called Roar3. It's a bit longer and lower than Roar2 so it looks sleeker. In truth it is closer in shape to Toto than to Roar2. I'm pretty sure it will be a visual imrovement over Roar2. Hard to say if it will be a practical improvement.
There are a couple of things I'd like to point out. First involves the way I drew the lines of Oracle. I make card models of my designs which help me to check the panel expansions and allow me to get a 3D check of the shape. The models are done in the same scale as the drawing, in this case 1/8 size and the model is fairly large. So I know that Oracle has nice curves all over. But if you look at the end view in the lines drawing you will see all straight lines!
In a way this is a throwback to the original "instant" boats which had hull panels made from straight saw cuts.But it's easy for a designer to make the jump to more flexible shapes, that is hull shapes which can look like about anything you might imagine made from plywood. Back when I started drawing boats I noticed that some of the nicest shapes in 3D had end views made totally of straight line segments. Don't ask me why. Not only does it give a nice shape, but the designer's job can be simplified. For example with Oracle I might start by drawing the top view. Then I might sketch in the side view needing nothing more than an idea of what the stem, midsection, and stern will look like. Next I draw the end view which will include those three elements all connected by straight lines as you see in the end view above. In normal mechanical drawing it only takes two views to totally define an object. So without even drawing the side view of the boat, the shape is defined. It only remains to go back and figure it out. Of course, if you don't like the resulting side view, you will tinker with it. Then you will have to go back and adjust the end view and the top view, etc., etc.. Happy is the designer who hits it right the first time through.
The second thing I'd like to point out is the locations shown for the oarlocks. I almost always show the oarlock sockets mounted outside the hull on a good pulling boat. That allows better spread of the locks and thus slightly longer oars. It allows you to dip the oars without rubbing them on the wales. The only disadvantage I see is that if you use a boat like this to come along side another boat, you will present to that boat the only metal fittings you have on your craft. So a true tender should have the oarlock sockets mounted inside the wales where they won't scratch anything. Also, any dimensions I show for lock locations are only suggestions. You really should fine tune the socket locations to keep the boat trimmed level at your favorite rowing location. For that matter, I never show seats in my boats having found that a boat with a flat bottom plank like Oracle's will accept a rowing seat/ditty box that allows for endless adjustments and a totally open interior. And once you've found that best location, fasten some cleats to the boat where your feet like to be to act as foot braces.
Oracle is built from the same pile of stuff as Roar2. Four sheets of plywood with taped seams. No jigs, no lofting.
Plans for Oracle are $12 until one is built and tested.
IMB: I heard recently from the Texas IMB builder who said, "I want to let you know that IMB is alive and looking good. She is now right side up and sitting on her cradle. Soon this boat and carrier will be mounted on the small trailer I have ready......" Then I got this photo from Roger Harlow by way of Tim Webber.
Fatcat2: There is an old timer (80 years +) in Minnesota who has completed the hull of a Fatcat2. Fatcat2 is a simple 15' x 6' catboat, gaff rigged and multichined. I think the boat is totally done now.
Frolic2: I recently heard of two of these going together. One is in Colorado and seems to be on the back burner for now. The other is in Oregon and is on the front burner. He started it in January and is about half done, hoping for an early summer launch.
RB42: This is an 18' rowboat meant for two. It's never been in any of my catalogs but the Canadian builder has it well underway. Imagine the Oracle shown above stretched to 18' and you have it.
