(15mar00) This issue repeats the lecture on taping seams. Next issue, 1apr00, will present some thoughts about hull lines.
Tim Webber is kicking off the messabout season with his TEXAS MESSABOUT at Lake Conroe near Houston on April 15. For more details click here.
Lars Hasselgren's Larsboat.
TAPED SEAMS
My own taped seam history started about 1985. I made a Payson/Bolger dory with taped seams even though it was originally designed to be made on a ladder frame with chine logs in the old fashioned way. Payson's book "Build Your Own Boat" had the complete dory plans and also included the side panel expansions! It was easy to build a taped seam version with no ladder frame. Harold used polyester resin in his projects probably for the same reason others have used it - it's cheap and available. So I used it too on that dory. I tried ordinary automotive Bondo to fillet the seams instead of the resin/filler mixes that Payson advised. That boat had but one layer of glass inside and out. I used it for about five years until it got crushed by another boat in a tornado. The transom tapes were ripped (but the polyester resin held), and the boat was sort of opened wide. I gave it to Jim Huxford who repaired it and still rows it. In many ways my boat Sportdory is a rework of that old dory.
Polyester has certainly worked OK for me. My boats are stored under cover as a rule (although some have been outdoors for months at a time). That may be a factor in their longevity with polyester. Where I live you can never expect to get your money back on a homemade boat, even the cost of materials. I think when we started 15 years ago we got polyester for $13 a gallon (good stuff too) while epoxy went for about $70 a gallon. Now we know where to get much cheaper epoxy. So now I advise epoxy although maybe it's only because I've caved in to the newsgroup. Of course if you are using expensive plywood, etc., you need to use epoxy.
THE INNER SEAMS... ![]()
TAPING THE OUTER SEAMS....
FINAL WORK...
YOU'RE DONE!
I'll give some thoughts about hull lines.
LARSBOAT
The basic hull is taped seam construction needing four sheets of 1/4" plywood for the decked version and three sheets for the undecked version. No jigs or lofting required. Plans are two blueprints with keyed instructions plus Toto's detailed taped seam instructions for $20.
By the way, the photo above is of Bob Smithson's Larsboat. He customized the decking a bit. I think he also built the boat of 1/8" ply to save weight. I've forgotten what his boat weighed but he did say it was sufficiently rigid for him.
I also drew up a trimaran sailing rig for Larsboat called "Trilars" which is sold separately for $10. It is pretty much a clamp on rig except for the small mast step and partner. To date no Trilars has been built that I know of.
We also have the start of a Jon Jr, a 12' x 3' personal sized jonboat, down in Texas. Here is the latest photo with the sides in place.
Mayfly12: A Mayfly12 is going together up in Minnesota. The decks are on and he's into the sailing bits. By the way, the sailing bits on almost any sailboat large or small consume about half of the effort in labor and materials. Just when you thought you were about finished! Here is a construction photo from last summer.
Robote: Robote is supposed to be a fast somewhat extreme rowing boat based on my old WeeVee design, thus it has a deep V bottom but is stretched out to 14' long with a very pointy bow. It was drawn as a custom job but if it works out I'll put it in the catalog. The builder has the boat taped together and hopes for trials by April.
