(1Jul00) This issue reruns the article about building a kick up rudder. Next issue, 15Jul00, I'm going to take a deep breath and start a primer on sailing for nonsailors.
Chris Flynn took photos of our recent Rend Lake Messabout and presented them in Duckworks Magazine. Click on over for a look at one of the best websites for our type of boating, all put together by Chuck Leinweber.
Rob Cole building Totos way up north. |
SMALL BOAT RUDDERS
RUDDER BLADE...
SINK WEIGHT...
RUDDER STOCK...
TILLER/HOIST LANYARD...
SHEET FAIRLEAD...
HINGES...
THE CARY HINGE...
Here is his description:
I'll start a primer on sailing for nonsailors.
SKAT
SKAT, CATBOAT, 12' X 5-1/2', 250 POUNDS EMPTY
Long time readers may recall this design as being in the prototypes section a while back. One was being built and nearly completed when the builder had to put it aside to work on some realities of life, something that happens to all of us from time to time. I decided to put Skat back into the catalog and maybe a second one will get started. Here is a photo of the first hull partly finished. When completed Skat will be decked from bow to centerboard with small side decks in the cockpit. The two forms you see in the cockpit area will be removed when the decks are in place.
Skat is a small traditional looking catboat based on a similar boat in HOW TO BUILD SMALL BOATS by Edson Schock. My copy is undated but the style of the boats suggests to me that it was written in the 1950's. The books's hulls are plywood but none are done "instant" style. I admire Schock's designs for their simple good looks and wholesomeness. Skat is like the little catboat in that book but is a taped seam instant boat with a gaff rig and kickup rudder replacing the original's Marconi rig and barndoor rudder.
I think a shallow V bottom like this one can outperform a flattie. If sailed flat this hull will have no chines in the water while the flattie will have two. When heeled the V hull will have only one chine in the water while the flattie may have two. If the flattie is heeled so one chine is "flying" the flattie may match the V. This shape was once quite popular because it worked so well with flat panels, the Lightening, Y Flyer, and Wind Mill coming to mind.
The 81 square foot gaff sail works with a 14 foot long mast which should make for better trailering than the original 21 foot mast. I kept the centerboard layout and I think this is just one of two boats I've drawn that had a centerboard. A leeboard won't work with this traditional shape. For a leeboard to work here the entire rig would have to be shifted aft at least a foot.
Construction of Skat calls for three sheets of 1/4" plywood and four sheets of 3/8" plywood. No jigs or lofting required.
Plans are three blueprints plus keyed instructions for $20 until one is built and tested.
Caprice: A brave and experienced builder in Texas is making the 25' Caprice water ballasted sailboat. A big project. Now the bottom and bilges have been fitted and taping begins.
< WIDTH="306" HEIGHT="401">
We also have the start of a Jon Jr, a 12' x 3' personal sized jonboat, down in Texas. Here is the latest photo with the bottom going on.
IMB: Also at the lake Conroe messabout Jerry Scott's prototype IMB got into the water. A full report when I receive one.
Mayfly12: A Mayfly12 is going together up in Minnesota. It is now complete except for painting. Here is a construction photo from last summer.
Robote: Robote is supposed to be a fast somewhat extreme rowing boat based on my old WeeVee design, thus it has a deep V bottom but is stretched out to 14' long with a very pointy bow. It was drawn as a custom job but if it works out I'll put it in the catalog. The boat is now complete and launched but waiting for final photos and test results. Here is a preliminary photo on its first row with builder Frank Kahr at the oars:
