(15jul01) This issue will repeat the essay on making a weighted rudder for your small sailboat. Next issue, 1aug01, I hope to review some happenings at our last Midwest Messabout.
SEWN SEAM BOAT BUILDING IN 1909...
...Reader David Beede found an excellent Russian website (in English) put together by Misha Naimark where you can learn how to make clinker boats with no nails, as was done in Northern Europe right into the 1950's. The technique predates the Vikings use of nails. The planks are hewn out of logs and sewn together with tree roots, as the fellow above is doing ( I think he is hammering in a peg that secures the lacing, not driving iron nails). Misha describes doing this without a saw since saws were advanced technology then. So he goes into the woods with an axe, a knife, a drill, a sharpening stone, and he comes out with a lapstrake boat! (And no doubt he is several pounds lighter for doing it.) I'm thinking CLC is making modern lapstrake boats with sewn seams and I'm just wondering...
John Bell's building an AF4.
SMALL BOAT RUDDERS
BACKGROUND...Here is an article I wrote a while back that appeared in the great paper magazine BOATBUILDER. I've included copies of it in my prototypes catalog since then. The article shows how I've made rudders for my own small boats.
RUDDER BLADE...
SINK WEIGHT...
RUDDER STOCK...
TILLER/HOIST LANYARD...
SHEET FAIRLEAD...
HINGES...
THE CARY HINGE...
Here is his description:
I review the happenings at our last Midwest Messabout.
PIRAGUA18
PIRAGUA18, SWAMPBOAT, 18' X 3', 90 POUNDS EMPTY
I reviewed the 14' Piragua last issue. Here is the same boat stretched to 18'. The width of the boat remains at 24" maximum on the bottom flaring to 30" maximum inside the wales, too narrow to stand up in. It is intended to be paddled with a double paddle like a kayak. The stretch creates more weight carrying ability. While the 14' Piragua will take two adults in a pinch, Piragua18 will float 500 pounds before its bow and stern start to drag the water. The empty hull should weigh about 100 pounds leaving 400 pounds for people and gear and that should be enough for two grown men.
I've also shown on the drawing how I would rig a boat like this with an electric trolling motor. A typical trolling motor and 100 amphour trolling motor battery will together weigh around 100 pounds and this hull will handle the weight of the rig better than the shorter boat. I'm thinking that is no need to get a large motor. The smallest I've seen for sale lately was 30 pounds thrust which is usually rated at 1/2 hp. That should drive the boat about 5 mph. Better would be to throttle to about half power which should give about 4 mph. The battery has to be a full sized deep cycle trolling battery. There batteries should never be deeply discharged, in spite of their name, and for long life they should not be discharged more than 70% of their capacity, and they should be promptly and fully recharged after use. At full power the 100 amp hour battery should give about 1.25 hours of endurance for a range of about 6 miles in calm conditions. At half power the battery should give about 3.5 hours endurance for a range of about 14 miles. Note that at high rates of discharge a battery has inefficiencies that prevent it from delivering its full charge. Anyway, power and hull should together weigh about 200 pounds, still leaving 300 pounds for folks.
This hull might be a good starting point for a beginner's sliding seat rowing boat. It has the length and light weight and wide open interior that would take rails for the seat. She's way too narrow for rowlocks mounted on the wales. You would have to add riggers. No doubt the best approach would be a drop in unit that has rails and riggers and foot braces all bolted together. You would have to secure it to the hull somehow but that could be done in such a way that the unit could be removed and the boat returned to its canoe configuration.
Anyway this is powered I think it would be a good camper's boat assuming there is no real rough water about. The ends are boxed in with buoyancy/storage volumes and the center 9' wide open for sleeping. The hatches into the storage boxes are small, only 6" wide, in order to make them less likely to take water in an upset.
Construction is simple nail and glue like the original Piragua. Three sheets of 1/4" plywood will do it. I don't think these boats need epoxy coatings if they are stored under cover. The chine corners need to be armored with fiberglass set in epoxy and the inner seams given a fillet of epoxy putty to keep water from creeping into the seams.
Plans for Piragua18 are still $15 until one is built and tested.
Caprice: Chuck Leinweber of Duckworks Magazine has finished the prototype Caprice. I got a ride and some photos at the Midwest Messabout and will have a full report soon.
Normsboat: This is an 18' sharpie being built by Cullison Smallcraft in Maryland. You should be able to check on it by clicking through to his web site at Cullison SmallCraft (archived copy, actual site no longer active). He is presenting an excellent photo essay of how to assemble a flattie. This boat has been launched and I'm waiting for photos and a test report.
HC Skiff: One of these is going together in Massachusetts.
Mayfly: A prototype of the original 14' Mayfly is going together in New York state.
