(15mar01) This issue will review taped seam procedures. Next issue, 1apr01, will discuss Birdwatcher type boats.
If you have a long light boat like a double kayak and a short car and need to cartop you might stop by www.veerack.com to see a product invented for just such a problem.
Paul Moffitt's Larsboat
TAPED SEAMS
My own taped seam history started about 1985. I made a Payson/Bolger dory with taped seams even though it was originally designed to be made on a ladder frame with chine logs in the old fashioned way. Payson's book "Build Your Own Boat" had the complete dory plans and also included the side panel expansions! It was easy to build a taped seam version with no ladder frame. Harold used polyester resin in his projects probably for the same reason others have used it - it's cheap and available. So I used it too on that dory. I tried ordinary automotive Bondo to fillet the seams instead of the resin/filler mixes that Payson advised. That boat had but one layer of glass inside and out. I used it for about five years until it got crushed by another boat in a tornado. The transom tapes were ripped (but the polyester resin held), and the boat was sort of opened wide. I gave it to Jim Huxford who repaired it and still rows it. In many ways my boat Sportdory is a rework of that old dory.
Polyester has certainly worked OK for me. My boats are stored under cover as a rule (although some have been outdoors for months at a time). That may be a factor in their longevity with polyester. Where I live you can never expect to get your money back on a homemade boat, even the cost of materials. I think when we started 15 years ago we got polyester for $13 a gallon (good stuff too) while epoxy went for about $70 a gallon. Now we know where to get much cheaper epoxy. So now I advise epoxy although maybe it's only because I've caved in to the newsgroup. Of course if you are using expensive plywood, etc., you need to use epoxy.
THE INNER SEAMS... ![]()
TAPING THE OUTER SEAMS....
FINAL WORK...
YOU'RE DONE!
We'll take a look at Birdwatcher type boats.
LARSBOAT
The basic hull is taped seam construction needing four sheets of 1/4" plywood for the decked version and three sheets for the undecked version. No jigs or lofting required. Plans are two blueprints with keyed instructions plus Toto's detailed taped seam instructions for $20.
I also drew up a trimaran sailing rig for Larsboat called "Trilars" which is sold separately for $10. It is pretty much a clamp on rig except for the small mast step and partner. To date no Trilars has been built that I know of but here a photo of a model of Trilars taken at last years Texas messabout:
Caprice: A brave and experienced builder in Texas is making the 25' Caprice water ballasted sailboat. A big project that looks bigger with each new photo. Into the final details I'm told, for a launch in the Spring.
Normsboat: This is an 18' sharpie being built by Cullison Smallcraft in Maryland. You should be able to check on it by clicking through to his web site at Cullison SmallCraft (archived copy, actual site no longer active). He is presenting an excellent photo essay of how to assemble a flattie.
