(15Sep01 ) This issue will rerun an important issue about some capsize tests. Next issue, 1oct01, will discuss scarfing lumber.
INDIANA MESSABOUT NOTICE: The 10th Annual Lake Monroe Messabout will take place on September 21,22 and 23. This messabout is on Lake Monroe, at the Paynetown State Recreation Area, all this about ten miles south of Bloomington, Indiana. No campsites will be reserved so congregate in the tent area, sites 1-10, 28-32. Pitch in dinner on Saturday night. For more info contact Bob Bringle at rbringle@iupui.edu.
Ken Prims preparing Vamp for its first flight.
KNOCKDOWN RECOVERY
And now on to our story...
AF3 CAPSIZE RECOVERY...
"Hi Jim:
At summer's end he wrote:
"Hello Jim:
Herb"
But a tight well secured cover of the cabin slot would be a good idea in rough going. It should help keep a big wave from sloshing into the cabin and upsetting your day. Remember the capsize test of Normsboat, 18' big brother to AF3, where the cabin slot was maybe 6" above the water in a knockdown.
I'll present some thoughts about scarfing lumber.
AF3
AF3, CUDDY SHARPIE, 16' X 5', 250 POUNDS EMPTY
The AF3 (the original design study was called "Alison's Fiddle") prototype was built by Herb McLeod of Edmonton, Alberta, with 70 hours of labor. He used spruce exterior plywood made at the plant he has to drive past on his way to the lumberyard.
The sail rig is the exact one I used on my old Bolger Jinni and it also found its way onto the Pencilbox design. I align the sail area directly above the trailing edge of the narrow leeboard on sharpies. If weather helm becomes a problem (hardly ever happens) you can dial it out by sweeping the leeboard aft. Traditional teaching would have the sail much farther forward but that guarantees lee helm in a boat like this. I'll bet the old rule about "lead" in sail layouts applies well to the sharp deep cutwater hulls of traditional planked boats.
Also I've shown external chine logs on AF3 and all my sharpies. They are an easy, quick, and strong bottom attachment, but many can't accept their looks. Use traditional interior logs if you wish. Better yet, use epoxy/fiberglass tape chine joints with a healthy interior radius. That makes for a really clean looking boat and the worst rot area in a wooden boat, that chine log, is totally eliminated.
AF3 uses six sheets of 1/4" plywood and two sheets of 1/2" plywood. Plans are $30.
HC Skiff: One of these has been completed and sailed in Massachusetts. Waiting for photos.
Mayfly: A prototype of the original 14' Mayfly is going together in New York state.
Vamp: I got the Vamp photos from out West. Hope to present the design shortly.
