(1jun01) This issue shows you how to do your sail area math. Next issue, 15jun01, will present some thoughts about types of wooden boat construction.
The 12th ANNUAL MIDWEST HOMEBUILT BOAT MESSABOUT...
... will take place on June 9 and 10 at the Gun Creek Recreation Area at Rend Lake in Southern Illinois. Take exit 77W off I-57, head towards the golf course and you will see the signs. Lots of people arrive on Friday and leave early on Sunday. The camping fee is $10 which includes the ramp fee at this Corps of Engineers facility. There is no schedule of events. We have a pitch in dinner on Saturday evening.
Barron Wester's QT power skiff.
SAIL AREA MATH
I repeat this essay every year because it is one critical area where builders have problems when they start to modify their boats.
THREE SIDED SAILS...
FOUR SIDED SAILS...
Another way is to dangle the cutout on a pin stuck through a corner and into a wall marked with a vertical line that passes through the pin point. Mark the line that passes through that pivot corner and a vertical. Then rotate the cutout to hang it from another corner, and mark a second line through the second pivot corner and a vertical. The centroid lies at the intersection of those two lines. Back at the missile factory the designers had a favorite place, complete with pivot pin socket hole and vertical line, to hang these cutouts and that place was known as the "weighing wall". Meanwhile the super computer cranked away next door but its answers weren't to be trusted unless they agreed with the cutout hanging at the weighing wall.
RIGS WITH MANY SAILS...
We'll start to take a look at types of wooden boat construction.
Power QT Skiff
POWER QT SKIFF, POWER SKIFF, 13' X 45", 90 POUNDS EMPTY
QT has been around as a rowing skiff for a long time now and was last reviewed in the 15nov00 issue. But each set of QT rowing skiff plans also included a set of plans for a powered version of QT. I just got photos of a completed power version of QT from Barron Wester of Smyrna, Ga. The photo shows him in his local waters using a 2.5 hp outboard.
The power QT is nearly identical to the rowing QT except that its bottom runs straight aft from the maximum beam, a "straight run" as they say, with no rocker in the stern at all. This is critical in a power boat that will be getting some dynamic lift from its speed over the water (unlike the rowing version whose lift all comes from "displacement" of the surrounding water as the boat sinks to a level where its weight equals the weight of the water it has "displaced"). I think there are two reasons why the straight run is critical for a power boat. One is that as the boat speeds up it tries to climb over its own bow wave and as it does so it lifts its bow. The boat must have a lot of stern volume or else it will bury deeply at the stern and its bow will point to the sky alarmingly. The second reason is that with the typical outboard motor arrangement, most of the boat's weight is concentrated in the stern, the skipper's weight being usually the largest item. Even with no motion a good rowing boat with its fine stern lines can't handle that weight back there - its bow would point skyward and its stern dangerously close to swamping even without starting the motor. The upshot of this is that a good rowing boat can never be a good power boat, and a good power boat can never be a good rowing boat.
By the way, power QT would be limited to about 5hp (maybe less) by the Coast Guard recommendations, and mine too. If you are lightweight it may plane with that power.
Simple nail and glue construction from three sheets of plywood for either version of QT. No jigs or lofting.
Plans for both the rowing and power versions of QT still come in one package for $25.
Caprice: Chuck Leinweber of Duckworks Magazine has finished the prototype Caprice. Here is a photo. Waiting for some shakedown cruises and a report. There is a chance this boat will be at the Midwest Messabout and I'm looking forward to seeing it.
Normsboat: This is an 18' sharpie being built by Cullison Smallcraft in Maryland. You should be able to check on it by clicking through to his web site at Cullison SmallCraft (archived copy, actual site no longer active). He is presenting an excellent photo essay of how to assemble a flattie. This boat has been launched and I'm waiting for photos and a test report.
Vamp: I received word that a prototype of the little rowboat Vamp is completed up in Utah. Hopefully photos and test report soon.
HC Skiff: One of these is going together in Massachusetts.
