(15apr02) This issue will discuss taped seams . The 1may02 issue will discuss joining plywood sheets.
THE LAKE MARTIN, ALABAMA, SPRING MESSABOUT will take place on April 26-28. For more information try clicking here.
Stop by Dave Grey's website at PolySail Kits Dave sells kits to make sails of heavy duty white polytarp and has done some recent original testing of various tapes used to assemble sails. Very interesting.
My AF4 parked in the weeds last week.
TAPED SEAMS
My own taped seam history started about 1985. I made a Payson/Bolger dory with taped seams even though it was originally designed to be made on a ladder frame with chine logs in the old fashioned way. Payson's book "Build Your Own Boat" had the complete dory plans and also included the side panel expansions! It was easy to build a taped seam version with no ladder frame. Harold used polyester resin in his projects probably for the same reason others have used it - it's cheap and available. So I used it too on that dory. I tried ordinary automotive Bondo to fillet the seams instead of the resin/filler mixes that Payson advised. That boat had but one layer of glass inside and out. I used it for about five years until it got crushed by another boat in a tornado. The transom tapes were ripped (but the polyester resin held), and the boat was sort of opened wide. I gave it to Jim Huxford who repaired it and still rows it. In many ways my boat Sportdory is a rework of that old dory.
Polyester has certainly worked OK for me. My boats are stored under cover as a rule (although some have been outdoors for months at a time). That may be a factor in their longevity with polyester. Where I live you can never expect to get your money back on a homemade boat, even the cost of materials. I think when we started 15 years ago we got polyester for $13 a gallon (good stuff too) while epoxy went for about $70 a gallon. Now we know where to get much cheaper epoxy. So now I advise epoxy although maybe it's only because I've caved in to the newsgroup. Of course if you are using expensive plywood, etc., you need to use epoxy.
THE INNER SEAMS... ![]()
TAPING THE OUTER SEAMS....
FINAL WORK...
YOU'RE DONE!
I'll give some thoughts about joining plywood sheets.
LARSBOAT
The basic hull is taped seam construction needing four sheets of 1/4" plywood for the decked version and three sheets for the undecked version. No jigs or lofting required. Plans are two blueprints with keyed instructions plus Toto's detailed taped seam instructions for $20.
Here is a photo of Paul Moffitt's Larsboat:
And here is Bob Hoyle's deckless Larsboat:
I also drew up a trimaran sailing rig for Larsboat called "Trilars" which is sold separately for $10. It is pretty much a clamp on rig except for the small mast step and partner.
To date no Trilars has been built that I know of but here is a photo of a Trilars model taken at a Texas messabout.
A Campjon is ready for paint in exotic Queensland, Australia. Another is underway in New York with an enlarged cuddy.
