The 15aug02 issue reruns an article about making your own oars. The 1sep02 issue will be about boat camping.
Pierre-Yves Gabi cartops his AF3 in Switzerland!
Making Oars
I decided to rerun these rowing articles that first appeared here in the winter of 98-99. I've left out some of the details that appeared in those issues and added other details.
MAKING A SET OF OARS....
I'm going to show drawings for 7' oars which are about the most useful length for me.
WHAT KIND OF OARS....
The long narrow blades go against modern thinking of spoons, but for long distance rowing, long and narrow is the way to go. The average mortal can only pull so much of a load, in spite of what an Olympian might do. The Culler blades can match the mortal's pull. They might slip a bit when starting a heavy boat from a standstill, but once up to speed, the have full grip on the water. They balance better. They are less fatiguing. They have less windage. By the way, the oars of traditional Irish caurrahs have no blades on their oars. Neither do the paddles of some traditional kayaks.
WHAT YOU NEED...
For wood, I use 1x6 pine boards. The pattern shown in Figure 1 will just barely make an oar from a 1x6. I try to buy a single board long enough to get out both oars. For example, for a pair of 7 foot oars, I buy a board 14 feet long if I can. That way the oars will be a close match on weight, stiffness, and color I like to use soft wood like pine, It is easy to work and makes a light oar. It need not be clear wood although clear is easier to work Small solid knots are fine and look good too. I've never worried too much about grain because the sticks get laminated and tend to stay straight. But the straighter the grain the better.
For glue I prefer plastic resin "Weldwood" glue and doubt if there is anything better for making oars. Pour some in a cup and squirt in cold water until it has the consistency of normal woodworking glue like "Elmer's. I've found it to quite true that this glue will not set properly until it is a t 70 degrees F for twelve hours like it says on the can. But don't hesitate to use epoxy if you already have it on hand.
Now let's talk tools. The tool I use the most in making oars is a bandsaw and I hate to say that because it's not a cheap or small thing that everyone will have. The problem is that you've got to saw a 2-1/4" thick blank. Hand saws will work and the effort should get you in shape for rowing. After all, oars were invented long before the bandsaw. But I see Dave Carnell has built oars using his table saw and others have built oars with a sabersaw.
HOW TO BUILD...
First cut the 1x6 boards to the proper length. lay out the centerline with a straight edge. Then draw the pattern for the center piece, the one with the blade, around the centerline. Cut out the center lamination following the line closely with your saw, because the outer laminations of the blank are made from the off fall and there isn't much extra.
A ROWING SEAT/DITTY BOX....
Here is what the seat looks like for real, this one about 15 years old now. Here are some things you might keep inside the seat: spare oarlocks, a knife, some line, sunscreen, Vasoline, binoculars, compass, whistle, and some energy bars. Always take a lot of drinking water with you also when you go rowing.
OARLOCK SOCKETS...
If your hull's side have limited flare, say less than 15 degrees, you can make some cheap oarlock sockets that are as good as store bought. I got the idea for these, plus the oarlocks that follow, from Phil Bolger who used them on his Spur 2 rowing boat that appears in his book BOATS WITH AN OPEN MIND.
Here is how it's done.
What we have here is simply two metal plates bolted to the wale with the proper sized hole (usually 1/2") drilled in each. Phil had his made of stainless steel. I made mine out of aluminum and have had no problems. I used an aluminum yardstick of the type carried by lumberyards for use with drywall as the basic material. I think the metal is about 1/10" thick and about 1-1/8" wide. I cut the aluminum to 3" lengths, stacked them up and drilled the oarlock hole and the bolt holes all at the same time. Filed off any sharp edges. Clamped the plates in the proper position and drilled the wooden wale. Bolted the plates in position and that's it. These work well because the oarlock bears on the metal parts which are about 1" apart, a bit more than the usual shallow factory sockets. So far I haven't worn them out. By the way, it helps to grease any oarlock from time to time, ordinary Vasoline works well.
BOLGER OARLOCKS...
I haven't tried these but Phil swears by them. It is really a thole pin with a bracket to retain the oar. Phil has always said that thole pins are better than the usual factory oarlock where the oar centers directly over the rotating pin. With a traditional fixed thole pin the oar rotates around the fixed pin as it bears against it and Phil says that is a better motion than with the factory oarlocks. The pin shown here could also be fixed, the bracket rotating around the pin with the oar! I should try these.
...boat camping.
Twang
TWANG, POWER SKIFF, 13' X 4', 100 POUNDS EMPTY
Twang is a small light power skiff, light enough to cartop if you keep your mind on weight as you build and if you can figure out a way to carry your motor and fuel in your car. It would also suit well the needs of someone who wants to carry his boat in the back of a pickup truck. She is 13' long, 4' wide, and I'm thinking about 100 pounds stripped.
I've never seen a hull shaped like this before. Look closely at the lines and see that the bottom is dead flat lengthwise for the last 10', and also flat across for the last 7'. That gives the boat good capacity and I'm thinking the ability to plane with a small motor, say 5 hp with a light skipper. So that much is about the same as with my little JonJr. design. But the bow here is pointed and designed to meet a wave with a deep V shape and hopefully be softer riding than a jonboat or flat iron skiff. There is bound to be turbulence where the deep V meets the flat bottom but I'm hoping it won't be a factor on plane since only the aft half of the hull will be in the water then. I could be wrong and we might find out why I've never seen a hull like this. I'm quite certain it is impossible to come up with a new idea about hull shaping because everything has been tried in the past by good people. But new materials and techniques come along so that ideas that didn't work a generation ago might now be valid.
The hull is made with four sheets of 1/4" plywood and I think it will be easily made. The sides and bottom will be a piece of cake. The deep V bow is made from two simple pieces of plywood taped in place. I tried this design first by warping the bottom into the shape of the deep V and got the shape I wanted on the model, but felt quite certain that the amount of plywood torture needed would not please many. As is, there is almost no twisting in the panels. If this little design works I would waste no time trying it at 16' x 5' with heavier plywod. By the way, trying thicker plywood on a design with lots of twisted panels can be impossible. Even going from 1/4" plywood to 3/8" about triples the force needed to twist the panel into shape.
In my opinion these little boats aren't safe with big motors. I'm suggesting 5 hp. They also do quite well with small motors, say 2 hp. The low powered boat would be faster if the stern were swept up to meet the waterline and didn't drag the stern through the water, but only if the skipper sat well forward so that the boat really trimmed that way. Here is what really happens when someone puts a motor on a good rowing boat - one that has the swept up stern. No one ever puts controls on the boat that allow the skipper to sit forward for proper trim. The boat sits very badly trimmed down by the stern to the point where the skipper can hardly see over the bow. And when the power is applied the situation is a lot worse. So if you plan at all to use a motor, build a power boat like Twang and not a rowing boat. If you plan to never use a motor build a good rowing boat. Oars and motors don't mix well at all. Good rowboats never power well and good power boats never row well. In small boats at least, I know of no successful row/power boat. Remember that arm power might be 1/10 of a horsepower, and the smallest motors are ten or twenty times that.
Plans for Twang are still $15 until one is built and tested.
Electron: The California Electron in the water. Right now a four cycle 2 hp outboard has been purchased so the original electric idea may wait a while. I'll have a writeup on this one in a few weeks.
Shanteuse: The stretched (16' to 24') Shanteuse still awailts its windows. Here it is on trials for Florida river cruising.
Sowsear: Haven't heard anything lately of the Pennsylvania Sowsear.
