This issue will continue about knockdown recovery. The 1 november issue will continue the topic when we knockdown an IMB!
KNOCKDOWN RECOVERY2
THE CAPSIZE...
We do it all again with an IMB.
Electron
ELECTRON, ELECTRIC CUDDY BOAT, 18' X 5', 900 POUNDS EMPTY
Electron was designed for a man who had done his homework on electric boats by reading Little's great book ELECTRIC BOATS. He wanted the ability to go about 30 miles on batteries. We started with my Fatcat2 design, stretched it to 18' and narrowed it to 5'. His figures showed he would need six trolling motor batteries to get the desired range while using a 24 volt 2 hp trolling motor at half throttle. The batteries will weigh over 400 pounds and the motor about 60 pounds. With wires and such the power system should go about 500 pounds which is why the empty weight of the boat is shown as a total of 900 pounds. To review the raw numbers, on hp is said to be 750 watts and should drive the boat about 4 mph. The batteries are 12 volts and 115 amp hours each, a total of 690 amp hours or 8280 watt hours. Batteries like these should not be drawn down below 70% of their capacity to prevent damage so the total power available is 5800 watt hours. So the system should run at 1hp for almost 8 hours, or over 30 miles in calm conditions. I should think that the wind will be the big unknown in the equation as it is in any boating. You start the design with 400 pounds of batteries in the belly and design around them. The batteries have to go in the middle of the boat for proper trim. The hull lines are kept sleek because we don't have power to burn, as we might with a gas engine. Multichines are used for light weight and good sea handling and speed. The belly needs to sink about 7" deep to give enough displacement to float the 500 pound power system, 500 pounds of people and the 400 pounds of empty hull weight.
The prototype Electron was built by Don Rodgers in California who instead uses a 2 hp four cycle Honda. (Must be aircooled - he said it was noisy.) I think Don said it goes 6mph at full 2hp. To me there is little point in using over about 4hp and that might be the preferred motor since you could run at half throttle at hull speed with some reserve left for tough wind and wave situations. A modern four cycle of tht power will run forever on a little bit of gas, and even a junker two cycle that size can go well on maybe a gallon of gas every three hours or so. A tiller extension is mandatory for proper trim, very easily done. (Don just told me the boat goes 12.2 mph with 10 hp and I'm surprised it was controlable beyond about 8.)
I also think this hull would be a good starting point for a sail boat. The lines are right. You would have to rethink the cockpit, trying to make it more watertight. There is a great temptation to use the batteries as ballast but I'm not so sure this boat is a good candidate for self-righting because its sides and cabin are low. And I suppose a boat with 400 pounds of lead in its belly should have six cubic feet of flotation foam so it doesn't sink if swamped or holed. There might be compromise where maybe two batteries are used, keeping the battery compartment small and yet with enough endurance for 8 or more miles in calm conditions. The weight of the two batteries might steady the boat but it might not be self righting. The drawings show a 114 square foot balanced lug sail, the same as the Bolger Windsprint, and leeboard but the sail rig is untried.
Electron is built from eight sheets of 3/8" and three sheets of 1/2" plywood using taped seams and jigless construction requiring no lofting.
Electron plans are $40.
Sowsear: I'm told the Pennsylvania Sowsear is finished and has been tested. Should have photos soon.
An Australian buider has started a Dorado which is a power version of Frolic2.
